Question about Air Tools & Compressors
How to change battery?
I have removed the four screws on the side top near the handle and cannot remove the top easily. Is it necessary to remove all of the case screws to access and therby change the battery.
  • stanhull Nov 18, 2008
    Husky 1.5 gallon FP 207000DB probably made by Hausfield Cambell
Remove all the case screws, except the rubber feet. Remove the handle. unplug both batterys, seperate the two halves of the case. A plastic tray seperating the two batteries will be preventing the removal of the bottom battery bracket screw which is metal. I drilled through the plactic to enable a long screwdriver to remove the bottom bracket screw. An extendable magnet was used to retrieve the screw, although not necessary. The top battery bracket screw can be removedat any time once clearance is gained. . What a PITA, stupid engineering!
Posted on Nov 19, 2008
I recently bought a samsung side by side refridgerator i accidentally scratch my handles, and are deep scratches as i can see the white material beneath the metallic coding.
Hello Dimakatso;
My Name is Peter. I am a retired field service refrigeration technician.
I assume you wish to remove the handles to replace them.
These handles are usually attached to the doors in one of two ways:
1.) There are two 3/32" Hex key screws, one at the top and one at bottom of each handle. Unscrew ( Back off) the screw until the Handle comes off. It is not necessary to completely remove the screw.
2.) There two brackets mounted on each refrigerator door. One at the top & one at the top and one bottom of each handle. There are two screws on the handle, one at the top and one at the bottom. These screw fit into a oversize hole on the bracket. There is a slot below the oversize hole that you push the screws on the back of the handle down into. So, to remove the handle pull up on the handle. You will need some muscle to pull the handle up.
Over time handles with the mounting bracket on the door become loose. You have to remove the handle (pull up) and tighten the bracket mounting screws on the door. Put the handle back on and push down to lock.
Oct 27, 2014 | Refrigerators
Describe in detail how to open up a electro mate 400 B&D
  1. Unsnap the black plastic tray on the bottom. Turn the unit face down. Loosen four screws along the bottom edge.
  2. Loosen two screws in the handle and one screw on each side.
  3. Use flat blade screwdriver to pry up black rubber bumper near the top (back side only) and loosen one screw underneath on each side.
  4. Open the flat panel, remove any contents and loosen two screws at the back.
  5. With all 12 screws loosened turn unit face up with bottom toward you and gently pry bottom apart. There are wires and tubes connected inside so just prop it open enough to work.
  6. Replace battery ($29 + shipping on Amazon, search on battery model like CB19-12 or EXP1218).
  7. Reassemble.
  8. Tell spouse you just saved $150; collect reward.
Sep 17, 2013 | Black & Decker 400 Watt Electromate With...
How do you replace door handle on maytag maf1375 washer
Hi
You have to replace the door lock assembly. For that open the door and remove the four screws that hold the front panel. There are two on the door hinges and two on the other side. Then remove front by rolling the edge out. Now you will need to get the top lifted up. Remove the four screws that hold the soap dish trim on the top. Then there is a bracket on the front corners that have to be removed. Now you can lift the top and see the door lock switches and wax motor. You can remove the three top screws near the timer and flip the top down so you can look at the control board on top the washer.
Check the R-11 resistor to see if it is burnt. This resistor burns out when the door lock wax motor fails.If the resistor is bad you should replace the control board and the door lock wax motor
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 05, 2011 | Washing Machines
I need a manual or step by step instructions to change the belt on my Toro Personal Pace mower
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Read more: http://wiki.answers.com/Q/How_do_you_change_drive_belt_on_toro_lawn_mower#ixzz1MMJlZFMZ
May 14, 2011 | Toro Personal Pace CARB Walk Power Mower
I think my av elements on my husqvarna 36 chainsaw are too soft. The throtle trigger handle seems not to be tightly secure to the main body of the saw. Also the screws that attach the metal handlebar wont...
The screws into the tank to secure the top handle are self tapping, so if they will not tighten then yes the threads had stripped, you may be able to aquire some over sized screws to cure this, the saw has four rubber anti vibration mounts, and two bumper rubers either side of the tank to stop sideways movement, the later machine had a rubber around the right hand side of the top handle also to stop side ways movement, To change the rubbers you need to remove the starter cover, two of the securing screws also hold the l/h rubbers, remove the alloy chain catcher on the r/h side, and the cover plate top r/h side held with a single screw, the tank should now drop far enough to remove the rubbers, they are screw into the tank wit a self tapping screw on the back, you will need a special tool to remove them part no. 502510002, do not pull the tank too far down or you will stretch the fuel hose.
Apr 29, 2011 | Husqvarna Garden
I need to know how to get the drivers side door panel off. My window is off track and I need to fix
how to remove door panel on a 97 expedition, pull up on master window switch bezel careful clips break easily and unplug the connectors, remove triangle trim piece top right side of panel pull out then up, screw behind it remove it, remove red lense plastic piece on bottom of door small screw driver careful breaks easily screw behind it remove it, remove bezel around door handle turn it to get off handle screw behnd it remove it, pull straight up on door handle gently then hard if needed, after it is loose from door remove light bulb socket from behind door panel turn it, unplug power window switch.
thats it reverse to put back on
Nov 25, 2010 | 1997 Ford Expedition
How do I take off the door panel to replace a broken interior door handle
Door handles are fairly easy to replace, you may even be able to do it without removing the door panel. Look closely at the door handle, you will see a Philips head screw, remove this. Gently remove the faceplate to the handle. Behind the faceplate you will see another Philips head screw, (don't get the two mixed as they are slightly different in size) remove the second screw. Now heres where it gets a little tricky. The handle has to slide forward about a quarter of an inch before it can be tilted out enough to see the clips that retain linkage for the lock and latch, you can't get them mixed up because they are bent in opposit directions. You may need to use a pair of needle nose and a small screwdriver to work the clips up and out of the way so the link rods can be removed. Once you see how they come off it will be easier to replace. After replacing the handle and getting the clips back in place, position the handle back in place being careful to align the 3 slots that will lock it in place, then slide it back into position until you can see the hole for the first screw (which is the last one removed. Replace the screw, just don't tighten it to much, it only screws into plastic. Then work the cover back in place and replace the screw.
If you need to remove the panel, look the door over and find the 6, I think that's how many there are, screw covers, 2 on each end of the door liner and 2 under the door handle. The ones on the otter edge''s of the doors have a little plastic cover (about 1/4 inch in diameter). They pop out with a sharp knife or very small screwdriver. You might want to check along the bottom for additional screws I ma have forgotten. Once all are removed you can pry the door out at the bottomfirst, then gently work the panel back and forth to lift it until it clears the window section. That should do the job at this point. Good luck to you.
Jun 24, 2010 | 2001 Hyundai Elantra
Audi TT HID bulb needs replacing
You can change the bulb easily yourself in about five minutes, especially on the passenger side. You may want to disconnect the battery, though I don't know if that is necessary. You may also want to handle the bulbs wearing latex or nitrile gloves so as to not get your skin oil on the glass.
1. Remove the decorative cover that conceals the Coolant reservior. There is a single philips screw near the firewall that holds the cover down.
2. Find the back of the headlight and pull the metal wire clip that holds the back of the headlight cover toward the engine. Remove the cover.
3. Look inside and find the back of the HID bulb--it will be toward the outside fender. Twist the connector until it separates.
4. There is a retainer ring that holds the bulb in. Again, twist that until it comes loose. The bulb should come right out.
5, Put the new bulb in, noticing the notch is on top. Also, attach the retainer ring. It is marked "Top" to help orient it. Reattach the connector with a twist.
6. Make sure everything is firmly in place. Reconnect your battery and test the lights. Finish putting anything else back on.
Good luck.
Mar 14, 2009 | 2005 Audi TT
Printer 1600 JAM
Assuming you cannot lift the rear door and pull out, you will need to remove the back cover (take out the four screws) and take out the fuser module (it has heat temperature warnings on it so let it cool down before handling). The module has two sets of wires on either side that need to be disconnected. Four screws hold the module in place and need to be removed. The paper usually gets stuck in there. After removing the module, you may need to remove the small rear roller from the module by gently prying it up and out after removing four additional screws on the fuser that hold the metal bracket on the fuser in place. Removing these four screws (two on top, two on side) allows you to slide the bracket up and down and more easily access the small roller that needs to be removed so you can get all the paper out (it will likely be accordion-folded and really compressed in there).
Dec 17, 2007 | Dell 1600n All-In-One Laser Printer
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
Chances are the door panels separate as shown in the photo I have attached below. Panel replacement can usually be done without removing the door from the microwave. In cases where it is felt that door removal is necessary, I recommend detaching the door from the hinges. I generally do not advise removing the hinges from the microwave. Whenever the hinges are removed, great care must be taken to put them back in the very same position they were in. Failure to do so can cause microwave leakage, which can cause risk of skin burns, fire, and disruption of nearby electronic devices. You can find exploded view diagrams and order parts here: http://tinyurl.com/gv383 We have critical safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 06, 2007 | KitchenAid KHMS147 Microwave Oven
Air Tools & Compressors Logo
43 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
