Question about Philips SA5125/37 MP3 Player
My philips mp3
When i plug it to the computer it just charge and when i take it out it just shuts off
  • Anonymous Dec 13, 2008
    Thee same **** happens to me.
    I use a wallcharger also and it will come on but as soon as I disconnect it it turns off.
  • 8,596 Answers
This may require replacement, but do the following to make sure it is not a software issue:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Dec 12, 2008
When I try to turn on the MP3 (Philips GoGear Mix) I see a symbol of a battery and then it shuts down. When I plug the MP3 to the computer it shows it is fully charged. What shell I do? Thanks
I have had a GoGear for a while and those things have horrible firmware and are very fragile. I have experienced the same issue myself, so I suggest leaving it plugged in for several hours no matter what the screen says to try and let it charge. It should charge up. If not, try charging via a usb wall charger, which should allow usage of the player while it charges.
Jun 01, 2011 | Philips GOGEAR SA6045 MP3 Player
My Philips GoGear 4GB MP3 player froze up and will not come back.
well if your Philips MP3 GoGear freezes up. find somthing small enough to fit in the reset hole and push it in until it shuts down.if ur light shuts off but is still froze on the same screen hold the power button and it wiil power down all the way.l then turn your gogear on and it will be ready to go TRUST ME I JUST DID IT...HAHAHA
Jul 28, 2009 | Philips GOGEAR SA6045 MP3 Player
Mp3 won't charge or turn on and computer won't recognize it
the mp3 player might be going bad, might have to get a new one
Apr 22, 2009 | Philips GoGear HDD075/17 MP3 Player
How do you charge a 8gb MP3 player???
You should have received a a cell phone like charger with your player or most likely it will charge through the same USB cable that you used to transfer your songs from your computer. If you have the USB cable plug it into your computer. There should be some kind of display bar that shows the player is being charged. I hope I have been helpful
Mar 17, 2009 | Philips Audio Players & Recorders
Philips GoGear SA3125/37 MP3 Player Charger cable
The charger cable is sold by an outside company - Philips can give you the number for that company, or you can order it online.
If you already have a charger cable, plug the mp3 player into your computer - it will charge as long as the hold/lock switch is not engaged.
-Tha Mp3 Doctor
Feb 24, 2009 | Philips GoGear SA3125/37 MP3 Player
Shut down
Hi from your description I think that the battery is flat and needs charging or replacing
Feb 05, 2009 | Philips GoGear HDD6330 MP3 Player
Mp3 won't stay on
Make sure that the hold/lock switch isn't engaged, and make sure it has been plugged into the computer for 3-4 hours to fully charge.
If it still won't work, run a Repair in the Philips Device Manager.
-Tha Mp3 Doctor
Jan 17, 2009 | Philips GoGear SA3125/37 MP3 Player
I plug my mp3 player into the computer to charge and it turns off
Run a repair in the Philips Device Manager - make sure the lock switch is disengaged first.
-Tha Mp3 Doctor
Nov 25, 2008 | Philips SA3125\02 MP3 Player
It hangs on the first screen!
when i plug it in to charge it just stays on the philips welcome screen and just stayz like that wen i reset it does the same thing
Sep 10, 2008 | Philips GoGear Flash MP3 Player
Philips SA5125/37 MP3 Player Logo
53 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
