Question about Zanussi TC7114W Electric Dryer
Replaced my zanussi tc-481w drier belt but it still won't work
The old belt was broken so I got a new one and put it round the tub, however it's not clear where exactly it goes in relation to the alternator. It's very slack and I'm wondering whether it's too long for this machine.
Any suggestions? A diagram would be good:-)
Success! I found a clear explanation of the problem I was having and a diagram when someone recommended typing the model number into the Wiki how web site .
Result! Thanks for your help.
David
Posted on Nov 19, 2008
Zanussi dryer tc
Did you locate the "tensioner" wheel that may have jumped out of the mounting hole...??
There are two wheels, one on the motor and one on the tensioner...
Apr 13, 2014 | Zanussi TC7114W Electric Dryer
Zanussi fj12544 fills but won't wash
see this probably cause:
t doesn't pump or spin
frozen pulley or broken belt, replace
It pumps, but doesn't spin
lid switch defective,motor coupler defective,belt broken,clutch broken,drive motor defective.
It spins only with the lid closed
lid swtich defective.
Jun 18, 2012 | Zanussi ZWF1420W Front Load Washer
How to replace belt on zanussi tc 481w
When the belt is installed, the idler with properly tension the belt.
May 08, 2012 | Zanussi Dryers
My drier tc.481w water not going into tank
remove container/tank and clear drain line that runs into tank, Tim
May 29, 2011 | Zanussi TD4212W Electric Dryer
N need to know how to run new belt round the drum an tensioner on my zanussi conderser dryer tc 481 w
If you look where the tensioner is and release the locking bolt, put the belt on and retension it whilst tightening up the locking bolts.
A similar system to the altenator and fan belt on a car engine.
Mar 11, 2011 | Microwave Ovens
How do i change drive belt on zanussi tumble dryer model number td 4112w
take back cover off ... place new belt bottom first then roll it round tub... WATCH YOUR FINGERS.....if no cover on rear undo two screws on lid (rear).....do as stated above but its harder.07779933829 uk
Feb 23, 2011 | Zanussi TD4100W Electric Dryer
Zanussi tc 481w codenser dryer
this is possibly the belt slipping remove back panel and check the belt tention if not that it could be the bearing needs replacing
Aug 16, 2009 | Zanussi TC7114W Electric Dryer
Belt broken on my wdt1085 washing machine.
take off back plate to washer, wrap belt round motor and spider (6 legged wheel above the motor) and turn the spider thats it
Jun 23, 2009 | Zanussi F1045W Front Load Washer
Unsure how to access drier to put on new drive belt
Here is my own solution...
Disconnect from mains (of course) remove top (2 screws at back near top) Unplug electric connectors (on back panel, top RHS). Make sure note what goes where! Lie unit down on front remove screws (2) holding the drum spindle cover (centre of back) and remove cover pop off the circlip holding drum spindle, and washer unscrew back panel - hex headed screws round outside of back Remove screws at bottom of back panel which screw into the plastic vent housing (3 I think) Lift whole back off. (there's a plastic lip at bottom - need to pull away from this a bit) The drum spindle will be unsupported now, so don't move unit Full access now to drum and motor beneath Get and put on new belt reassemble.
Actually, having got into unit, found could not get belt from local spares shop (it had closed down), so bought new drier!
Dec 15, 2008 | Zanussi TD4212W Electric Dryer
Zanussi TC7114W Electric Dryer Logo
272 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
