Question about Whirlpool LSR9434PT Top Load Washer
WILL NOT SPIN
Will agitate, not spin. How do I remove lid to get at the strike switch to repair it. What next if that dosn't work? Thanks for your time. LADY VICTORIA
    President:
  • 878 Answers
Lady Victoria, you are going to have to remove the cabinet to get to the lid switch. Remove the two screws from the back of the top consol and flip it up. Unplug the lid switch and remove the snap springs. The cabinet will now lift off and you can get at the lid switch. I will attach some helpful pics...Catriver..post back
Posted on Dec 09, 2006
  • Ron Marek
    Ron Marek Dec 09, 2006
    another view
One other thing.If it does not spin or agitate but can hear the machine running it may be a broken coupling
Posted on Mar 22, 2007
SOURCE:
Washer will not agitate or spin
Worn agitator dogs have NOTHING to do with the washer's ability to spin. Spin and agitation is controlled by the drive motor and gearcase (transmission). The washer will still spin and agitate with worn dogs on the cam assembly, but the agitiator will slip or remain stationary. This configuration usually applies only to Whirlpool manufactured washers (includes Kenmore, Estate, Roper, Kelvinator, Kitchenaid and some later model Maytags).
The most common cause of the symptoms you describe is a lid switch malfunction.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between sites so shop and compare.
If you have questions, need additional assistance, please post back with your model number (located on a nameplate along the wash tub opening under the washer lid), so I can provide you with better assistance. I hope this helps you.
NOTE: The problem could also be attributed to a a worn gearcase, but you need to rule out the least expensive and more comon problems first.
Feb 03, 2010 | Washing Machines
Works fine til it gets to the spin cycle, them stops completely
That would be the old lid switch failure. Look for a broken "strike" that is the plastic thingy that pushs against the lid switch, look for a broken actuator, thats the lever that works the switch when the strike hits it. I have here some repair photos that show how to get to the switch on a kenmore. But I have most models covered at my website so take a GANDER.
If you cannot get an answer there then hunt me up. I ain't hard to locate.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 14, 2009 | Washing Machines
My wsher agitates but does not spin or rinse
Check your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, this is commonly caused by a lid switch malfunctuion. I would recommend you check your lid switch first due to the frequency of use and the fact that it is the most common cause of these symptoms and least expensive to repair. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
NOTE: On this type of lid switch the lid hinge has a small rod that is used as an acutator to toggle the switch. In many cases, you can adjust the rod by bending it if the switch is not making contact.
http://www.fixya.com/support/r385198-replacing_lid_switch
If parts are needed, a replacement can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all of them for the best price.
This is a very simple repair, that usually costs about $25 to $35 to repair yourself. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Sep 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
It wont do spin cycle or drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is an excellent description by GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
Sep 23, 2009 | Kenmore 22422 Top Load Washer
Washer fills,agitates butstops instead of going into the drain an
Check your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, I would recommend you check your lid switch first. Due to the amount of wear it is the most common cause of these symptoms and least expensive to repair. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
This is a very simple repair, that usually costs about $25 to $35 to repair yourself. If you have questions, please let me know. I hope this helps you.
Sep 23, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a model 20922990 the machine will not spin on the spin cycle. How do I acess the inside to see what is wrong. This problem just started today.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The following is "borrowed" from another site but the process is the same.
"Begin by removing the cabinet. To remove the cabinet on this design machine. Locate two screws in the bottom front of the control panel. This panel is where you set controls.
Remove the two Phillips head screws and lift up and turn control panel backwards. It will hinge to an up position and stay there. Locate the two brass colored clips that hold the back of the washer to the cabinet. Remove by prying up with screwdriver. Unplug the wires going to the lid switch. Pull forward on the cabinet and the whole thing will disconnect from the base of washer and you can set it aside. After removing the cabinet, remove the motor and pump."
If the washer pump drains (and you hear the motor), the timer is directing power to the motor to reverse itself and spin the pump. (timer, motor and pump should be OK)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore)
Sep 16, 2009 | Washing Machines
Kenmore washer won't agitate, spin, or drain
I would recommend checking your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If not activated by a lid strike, other models have the lid switch located under the washer casing next to one of the lid hinges. It is activated by a rod contacting an actuator. The mounting scews for this type are located under the operator console.
If you determine the switch to be defective, the following link explains how to access the washer interior and replace one:
If the switch requires replacement, a new one can be purchased on line at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of a replacement is $25 to $35.
Let me know if you have any questions, I hope this helps you.
Aug 21, 2009 | Washing Machines
Whirlpool top loading washer will not spin or drain. It does agitate but it will not spin. In trying to look at the lid switch, the striker piece came off. Not sure if that is the original trouble. ...
This problem is commonly attributed to a loose or broken lid switch.
If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Jul 18, 2009 | Whirlpool WFW8300SW
Washer won't drain
The symptoms you describe are typical of a lid switch failure. When a lid switch fails, the washer will fill, but stop at the spin cycle and will not drain. Sometimes it will fill, then stop. The switch is located under the washer top cabinet on the right hand side and is activated by a small plastic piece on the lid (called a "lid strike") through an opening along the right hand side of the casing next to the wash tub opening. First, make sure the lid strike is still intact on the lid. Next, open and close the lid and listen for a "clicking" sound. This is an indication that the lid strike is at least making contact with the switch. Then, check the two screws along the right side of the wash tub opening that hold the lid switch in place. Sometimes the screws come loose or fall out causing the switch to fail to contact the lid strike. In many cases, all that is required is to tighten these screws to realign the switch with the lid strike. If all these preliminary checks fail, the lid switch should eb replaced. The following link explains how:
If you require parts, go to searspartsdirect.com and type in the model number you provided. The lid switch will be listed under the "Top and Cabinet" heading as item number 11. The lid strike is listed as item number 20.
Some other sites to view are repairclinic.com and appliancepartspros.com. Sometimes these sites offer better pricing on parts.
If you have questions, or if the diagnosis is incorrect, please post back and let me know. I hope this helps you.
NOTE: If the wash tub is full, you DO NOT have to empty to complete this repair. Once a defective switch is replaced, the washer will spin out and drain on its own.
Jan 23, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine doesn't agitate
If washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. Note: direct-drive washing machines do not have belts. 1) Check the spin cycle. If this works, the motor is operating and the belt is not broken. If it doesn't, the belt may be loose or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during certain cycles. Press and release the switch: if it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) Call a repairperson; there may be a problem with the controls or the agitator solenoid may be broken.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
Whirlpool LSR9434PT Top Load Washer Logo
104 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
