SOURCE: my 1999 buick turns over but won't start I had
It could be that your fuel pump is not getting enough fuel to the engine to start it. Is your starter turning over or trying to start the engine.
SOURCE: my key is stuck in the ignition on my 97 Saab 900.
Some Saabs lock the gearlever in reverse as a security measure, and won't let you take the key out until reverse is selected.
SOURCE: Ignition switch on my 1987 Saab 900i
You may need to remove the ignition housing assembly to find out whats wrong inside. There are a series of small gears which connect the ignition barrel to the ignition switch & also operate the reverse gear lock mechanism. You'll need a special 3 pronged tool to remove the assembly - available from SAAB dealers.
SOURCE: ignition key won t turn. steering wheel locked
the key may be worn badly or the ignition needs to be replaced.
SOURCE: key stuck in ignition but it will turn, and
you most likely have a bad key switch cylinder assembly. you can try to spray wd40 solvent into the switch before you have the switch replaced,but sometimes it's a switch replacement that repairs the problem. have you inspected your ignition key to look for damage to the key itself? try a spare key to make sure it's the key,and not the key switch. you can also try turning the key while turning the steering wheel at the same time to get the key to work.sometimes the switch locks when parked in a bind,such as on a hill,or against a curb and so on. try this 1st before you have the ignition switch replaced. AAA auto club,if you're a member covers part of the replacement costs for a replacement switch also. you may have coverage through a cell phone also.one more thing to try, if you have a tilt steering column,try to reposition the steering wheel to see if you can get the key to turn. remember never force it enough to break your key off into the switch! thank you for choosing fixya.com!
