Question about Yamaha HTR-5635 5.1 Channels Receiver
HTR 5620 Receiver clicks on and off repeatedly
Hi, I posted this under the 5635 group because there wasn't one for the 5620. My receiver just started cycling on and off when I try to use it. It basically just clicks on/off/on/off every second or so. I can't use it, and I have no idea what to try. Before this started, we unplugged the power strip that it was plugged into (the receiver was off at the time), so I don't know if that could have caused this or not. I haven't tried anything to fix it.
  • Michael Berman Dec 08, 2006
    Based on what I have read on here, I just tried some basic trouble-shooting. I unplugged the speaker wires and turned it on, and it worked fine. I then plugged them back in and it didn't work. I checked all the connections on my speakers, but they were fine. I then tried plugging the speakers into the second set of speaker outputs, but still had the same problem. Does this mean there is a problem with the speakers or with the receiver?
  • 151 Answers
SOURCE: I've got a home theater
YOU SHOULD HAVE A SUB OUT PUT ON THE BACK OF THE AMP MARKED PRE OUT IF NOT CONNECT THE FRONT LEFT AND RIGHT SPEAKER OUT PUTS TO THE SUB THEN FROM THE SUB TO YOUR SPEAKERS.
HOPE THIS HELPS
CABLE GUY.
Posted on Jun 20, 2008
SOURCE: Bi-Amping my speakers with HTR-5850
You can at a minimum, bi-wire your speakers by wiring the speakers with the A and B speaker outputs. The A speaker outputs end up running the tweeters and the B will end up powering the woofers.
Posted on Dec 30, 2008
  • 814 Answers
SOURCE: Yamaha HTR-5830 Video shut down.
You have having a problem with the video amp clipping the signal after it get hot. You have one way to try to temporarily solve this problem. Try putting more air flow over your receiver and cooling down the temperature inside the receiver and see if the video amplifier starts working correctly. If it does then you must put a fan on it somewhere that will keep the air flowing so the video amplifier is not allow to overheat. If this does not solve the problem, then you will need to have the amplifier replaced for it to work correctly. If the unit is under warranty then call this number 1-800-492-6242 to locate a service center in your area. Call them for help with your problem. You can also try looking on the www.yamaha.com website. Put in you model number and check in the frequently asked questions and troubleshooting sections for people who have had similar problems with this unit and see if they printed a solution for the problem. I hope this helps you with your problem.
Posted on May 18, 2009
ripleymojica
  • 643 Answers
SOURCE: Lightning Last Night Nocked The Receiver Out.
leave unpluged overnight. usually capacitors hold charge and will release slowly. try that if doesnt work powersupply is bad.
Posted on Jun 03, 2009
SOURCE: Yamaha HTR-6130 Receiver will not stay on! Shuts
The Sleep Timer must be sert to OFF.
Posted on Sep 17, 2009
How I how do I reset my htr 6060 Yamaha receiver
Willard, Check the attached links,reset receiver.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Yamaha HTR 6060 Owner Manual Resetting The System
Yamaha HTR 6060 MCXSP10 Manual Page 94
Yamaha HTR 6060 Manual Page 104
Yamaha HTR 6060 Manuals Support and Troubleshooting Receivers
Mar 08, 2016 | Yamaha Audio Players & Recorders
Yamaha receiver HTR-3064 turn on but go to protection mode no sound
Htr-3064 reset power on - Fixya
www.fixya.com/support/t22761844-htr_3064_reset_power
Jan 8, 2014 - htr-3064 reset power on My Yamaha HTR-3064 will not turn on at all. ... 'straight' button as you power up to go into "advanced" menu (under DILLIGAF's post.) ... Not sure if I needed to unplug everything, but I was about to .... How do I turn ofprotection mode on my optimus sta 3200 receiver digital No sound.
Turns on but no sound - Fixya
Yamaha HTR-5460 Repair Brief.mpg - YouTube? 15:04https://www.youtube.com/watch?v=keaq2F4LrU4Feb 5, 2011 - Uploaded by Mark ZachariasThe Multimeter Junkie fixes an HTR-5460 with protectionproblems. ... Yamaha RX-V459DAB - Not powering ...Missing: 3064Yamaha HTR-5640 AV-Recei
Dec 21, 2015 | Yamaha Audio Players & Recorders
I have Yamaha HTR-5940. When I turn it on it's automatically turns itself off.
Shorted component/s at its power amplifier section circuit. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 11, 2015 | Yamaha HTR-6030 Receiver
I had a Power surge in Brisbane this week and found my YAMAHA HTR-3064 AV receiver unresponsive. Thanks to the Squish22's post, I tried the above approach, which is also listed for another Yamaha model (RX-V667) Unfortunately nothing happened. Another post suggested holding the 'straight' button as you power up to go into "advanced" menu (under DILLIGAF's post.) This also did not work.
I thought I'd try pressing all 3 buttons and powering up, which worked a treat. so here's exactly what I did:
Yamaha HTR-3064 - Protection mode reset:
  1. Remove the Power cord form mains power and wait 10 seconds.
  2. Plug cord in and turn on wall socket power.
  3. While holding down "info", "straight" and "tone control" buttons, press "main zone" power button. I got a click and it was good to go from there.
I had all of my speakers unplugged at the time and tested off the headphone jack before plugging all the cables back in again. Not sure if I needed to unplug everything, but I was about to dismantle and look for a fuse when I tried this method.
Saved me a new system / service fee. Hope it helps you too.
Thanks Squish22 and DILLIGAF for the head-start!
Jan 08, 2014 | Yamaha HTR-3064BL 5.1 Channel A/V Digital...
Problem with a subwoofer output..
Check your settings in the Receiver Main Menu. Go to Speaker settings, then to Subwoofer, and select "Yes" or "On" or it may say "LFE or Both" choose "Both" Hope this helps. If you still have a problem, post a comment and I can help you some more
Aug 11, 2009 | Yamaha HTR-5730 Receiver
Speaker imbalance in Yamaha HTR-5630
how do i hook up a yamaha natural sound av receiver htr 5630
May 03, 2009 | Yamaha HTR-5630 Receiver
Dec 30, 2008 | Yamaha HTR-5850 Receiver
Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Nov 23, 2008 | Yamaha HTR-6130 Receiver
I've got a home theater in a box with the HTR 5635 receiver. I've moved and lost the set-up directions and have forgotten how to hook up the subwoofer to the receiver. Can you help me?
HOPE THIS HELPS
CABLE GUY.
Jun 19, 2008 | Yamaha Audio Players & Recorders
Powers off when watching dvds
Hard to say if this indicates a more serious problem that should be looked into. If under warranty take the receiver back to the shop and let them worry about it. If warranty no longer valid, you should let a professional Yamaha service person look into it. But first lets see if we can't work around this problem. Is the DVD connected to its own power supply, or connected to the AC outlets in the back of the receiver? in case DVD player's power cord is connected to the back of the receiver, I suggest you connect it independently to another electricity socket, and see if this has any effect on the problem. Another thing to try is to connect the DVD audio cables to the receiver, and the video cables directly into the TV. Even if this helps you solve the problem, you're better off having someone look into it. especially if under warranty, don?t think twice. good luck
Jan 16, 2006 | Yamaha HTR-5635 5.1 Channels Receiver
Yamaha HTR-5635 5.1 Channels Receiver Logo
99 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
