The heater was used for one season and worked very well. I stored it in a safe secure place over the summer. When I brought it out to use,it doesn't want to turn on. When it is pluged in you can hear it accept the power. I checked the internal fuse and it is good. The unit looks brand new, and has never been abused or over heated.
When the furnace is running the light comes on, lights all 4 burners but only lasts a couple...
(More)
When the furnace is running the light comes on, lights all 4 burners but only lasts a couple seconds. This goes on the entire time it is running. Took off the door and followed directions to turning switch to off, leave for 5 min. turn on, replace door and set therm. to low heat. have done all this and as soon as the fan kicks on the flames go out.
I have a 2 year old natural gas, forced air heatinig system. My thermostat is set at 68 and the room...
(More)
I have a 2 year old natural gas, forced air heatinig system. My thermostat is set at 68 and the room temp is only 62. When I woke up thin morning I took the thermostat (honeywell digital) off of the wall and when I put it back on the wall the heating unit automatically turned on. This has happened several times where I had to either reset the thermostat or the system. Can someone tell me what the problem could be?
have a fraser johnston dual rooftop. The burners keeps cutting out every 20-30 second, pilot is on...
(More)
have a fraser johnston dual rooftop. The burners keeps cutting out every 20-30 second, pilot is on constantley, what is the problem?
I have a "Sureset" ceramic heater with adjustable thermostat and two heat settings but...
(More)
I have a "Sureset" ceramic heater with adjustable thermostat and two heat settings but have misplaced the programming instructions. I want the heater to come on in my wine cellar if the temperature dips to 55F and shut off once it heats up to 56F. This is how I maintained a constant temperature last winter and it worked well but I can't recall how I programmed it last year. Thank you
