Epson R200 photo printer needs a service/re-set. Not inclined to pay large sum for what appears to be 2 mins work. Can you tell me how to re-set??
  • 541 Answers
You need this to reset your r200
Posted on Nov 18, 2008
Epson stylus photo R200 status monitor in Windows 7 is'nt highlighted ink is low can't tell which ones
Uninstall the current driver and Status Monitor, once uninstalled connect and power the printer on to install the Windows 7 In box driver. If that does not work then you can tell which cartridges need replacing using the printer itself. Lift the lid and press the red ink button once. The carriage will move to the left and stop by a pointer. This will point to the cartridge that needs replacing. Repeat until it is in the change and then change the indicated cartridge/s and then press again to complete the change.
Jan 27, 2010 | Epson Stylus Photo R200 InkJet Printer
The epson R200 isn't supported in Windows 7. That's why the status monitor doesn't work.
Dec 28, 2009 | Epson Stylus Photo R200 InkJet Printer
I have an epson stylus photo R200. It has stopped working and has alternate red flashing lights. Error message says serviceable parts are nearing end of life. How do I get it to carry on working?
I'm not sure about the servicable parts. You might want to contact Epson.
I have seen "parts are nearing the end of life" which applies to the ink pads that absorb excess ink. In that case, the printer needs to be replaced or serviced by Epson or an independent service provider. If you just get the ink pads serviced, it may still fail soon. Then you can run the resrt utility. For more information and the reset utility:
I hope this helps.
Dec 15, 2009 | Epson Stylus Photo R200 InkJet Printer
Epsom R200 printer - ink and paper lights flashing red.
theres a guide on how to manually reset the counter here
unless you replace or clean the waste pad from here on in regard your printer as a ticking ink bomb. put it on a tray with a lip just incase of an ink overflow and dont put it on the carpet.
Sep 25, 2009 | Epson Stylus Photo R200 InkJet Printer
SSC Service Util for Epson R200
SSC can't reset ink level. Printer read ink level counter in chip, not actually. Use chip with autoreset function.
May 04, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 Can I print envelopes, if so , how?
check the program on the computer on disk and see if it will tell you anything
Mar 20, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 and R320 Status monitor in Vista
I was able to install the original XP status monitor from the CD, onto Windows Vista Home Premium.
On the install cd, you need to open the 'STM3' folder under whatever language you are installing, 'English' in my case. There are several .exe files in that folder:
For each of these, right click on the file, and choose 'Properties'. Under the 'Compaitbility' tab, choose 'Run this program in compatibility mode for:' - Windows XP (Service Pack 2).
Then run the 'STMSETUP.EXE' file, and it should install properly, and work. Although I cannot guarantee that it will work on your system, or that it will not have any negative effects on your computer.
So far, I have not had any trouble with it.
Aug 03, 2008 | Epson Stylus Photo R200 InkJet Printer
Try visiting Epson website...look for support link for drivers...then find your printer and operating drivers and install....install program should provide directions..generally it will direct you to make sure printer cable is not connected to pc until install program tells you to do so. You can also do a google search for "epson stylus photo r200 drivers for vista", chances are you'll find a site from the results...good luck
May 22, 2008 | Epson Stylus C46 InkJet Printer
76 people viewed this question
