I have a peculiar problem. When I shoot indoor the camcorder focuses correctly and functions but as soon as I focus on out door secenes the focus becomes totally blur.
-   How do you change the auto to manual focus on the GZ MG330HU. The manual does not explain how to switch from auto to manual focus.-   keys4031
Jul 31, 2008
-   Camcorder (Canon Elura 100) unexpectedly stopped to focus. It does not focus not in auto not in manual mode (in manual mode it tries to focus but it seems the range is too small so objects are out of focus). Any suggestions?
-   tmp191
Jan 06, 2008
-   When I record indoors is perfect,but when I record outside the images is looks too bright and the camera does not focus or use contrast to correct the problem of lights. Any idea?? I tried everything following the entire manual, but the problem persist. Thanks Cristian -   Guest
Dec 25, 2007
-   I have the same problem as describe by abi6375 and i don't find a solution yet . Help!
Happy new year everybody-   notlim
I would check to see if your camcorder is set for autofocus or manual. If it got changed to manual by accident, that would explain it (you can USE manual, but you'll have to keep adjusting focus). If this isn't the problem I would take it to the dealer you got if from or a repair station.
You should probably check the camcorder's settings , then if it is a hardware issue we can look into it for you. We offer free estimates for camcorder repairs.
Once you have done the "slap fix" on the Canon ZR-100 has anyone had the problem return?...
(More)
Once you have done the "slap fix" on the Canon ZR-100 has anyone had the problem return? So far so good with mine. Just wondering.
