Question about Dell 3100cn Laser Printer
Error message, ''close BTR cover'' for Dell 3100cn
Spoke with a dell rep. who after extensive checks, diagnosed problem as printer possibly needing a new fuse, cost of 11.95. But to send a guy out to do the work would be $250.00. Is there a way to obtain parts and find a local person to do the work?
We are located in Park Ridge, NJ 07656
  • Masterdragon Nov 24, 2008
    My printer is saying the same thing.
    Problem Solver:
  • 4 Answers
The BTR cover is covered the fuser. If you open the rear door, it is located at the upper part, behind the metallic rod. The problem is the cover is installed unproperly: Its metal piece is not touched against the metal piece of the machine, so the machine does not "smell" the BTR cover.
Posted on Jan 24, 2009
  • grouchypc Aug 13, 2011
    What metal piece is not touching against the metal piece of the machine? I realise this post is quite old but it is still relevant.
  • tranhoaithu Aug 13, 2011
    I put it for recycling a long time. However, I remembert it is a thin metallic piece shined (no colored).
    Usually, any problem such as "door not open, cover not open, BTR not open) are coming from the bad sensor. I am working with almost printers like HP, DELL, Canon, Brother, I found same problem with sensor.
    Pls read your manual or part schema to identify it.
Drum cartridge error 004-321 IBT alignment
When I get messages like that I start by reinstalling the cartridge. Also turn the printer off and on again. You can try the trouble shooting on the Dell site for the printer. If all else fails you may have to contact Dell directly. The printer support # is 800-822-8965. When I spoke to them I learned I had lifetime support that I wasn't aware of.
Jun 03, 2014 | Dell 3100cn Laser Printer
Paper cover error message
check the back cover is closed properly or check the cables are well connected to therear cover
Nov 20, 2011 | Dell 3100cn Laser Printer
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
We are getting error code 004-332 Restart Printer on our Dell 3100cn printer. We have tried unplugging and restarting print spooler but it still come up witht message when we try to print
Hi
This error code on Dell 3100CN occurs when toner cartridges are not seated properly and/or are not properly locked in. Turn off the printer and unplug it. Now, you need to open the front door and pull out the drum. Try moving the carousel and check if it moves freely. While moving the carousel back and forth try adjusting the cartridges. try to unlock the cartridges and lock them again.
Now turn off the printer and turn it on after 1-2 min.s.
Daniel Scott
Jun 24, 2010 | Dell 3100cn Laser Printer
Dell 3100cn
the BTR cover is also called " Bias Transfer Roller " cover it should be that roller that seen when open the front cover most likely the Bias transfer roller door sensor in NOT detecting the dorr closed. make sure the tab isn't broken this will produce this error if it is.
Jul 23, 2009 | Dell 3100cn Laser Printer
Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Jan 03, 2009 | Dell 3100cn Laser Printer
Dell CLJ 5110
Pop the lens cover off of the transfer roller, clean all the toner debris out of there and replace the lens, put clear tabe on it, and you are good as new!
Oct 09, 2008 | Dell 5110cn Laser Printer
Close reg cover
After researching the error online, I solved my problem by simply pushing the back cover of the unit closed; I didn't even know it had come open after I removed my jam.
Hope this helps!
http://support.dell.com/support/edocs/systems/3100cn/en/UG/section20.html#638412
Jul 18, 2008 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
541 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
