Question about Lexmark Wheelwriter 1000 Typewriter
Margin problems I cannot set the margins. I can only type a word and then it goes to the next line.
  • Lexmark Master
  • 3,594 Answers
First press code and the R key this turns off the auto return, now space to where you want the rt. margin, press the rt. margin key and all should be good.
DickyO
Posted on Nov 19, 2008
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Aug 19, 2014 | Swintec 7040 Typewriter
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
Return to tab
Don't confuse tabs and margins, after a return it always goes to left margin. Use the tab key to go from the left to the next place where you set a tab
Jan 30, 2014 | Nakajima AE-740 Typewriter
How to clear margin when in use
Left margin...use the code key (colored)
Move the carriage to where you want the margin, use margin release if you have to go beyond the present margin, and use the margin set key to set.
You have to reset a margin. can't just clear one.
Can set margins at each end of the typing line, then you will have no margins.
Hope this helps!!!
Dec 16, 2009 | Smith Corona Wordsmith 100 Typewriter
Can't change the right margin
You must first position the carrier to where you would like the margin to be set, so if you want the margin to the right of where it already exists you must to the the margin and Depless the margin release function (M rel). If the typewriter is in line-by-line mode you may have to select the TYPE mode , before you do this. When the carrier is position to the place you want depress the R margin set function (CODE plus M left)
Nov 25, 2009 | Brother EM-530 Typewriter
How to change the pitch?
Here ya go...
Margins and Tabs
Margins and tabs for both Type Mode and Mem Mode are set in Type
Mode, but can be changed in Mem Mode when text is recalled for
editing. Margins and tabs are set using the typing scale which appears
on the display in Type Mode. A blinking cursor indicates the typing
position. The letter “L” indicates your left margin setting. The letter “R”
indicates your right margin setting.
NOTE: In Mem Mode, the margins and tabs used when the text
is created will be saved with the text and recalled with it,
even if they have been changed.
Margins
In Type Mode, to signal that you are near the right margin, the
typewriter will beep 5 spaces before the margin. In Mem Mode, the text
will wrap automatically when you print.
Margins are preset depending on the pitch setting, which is the number
of characters per inch. They are:
10 Pitch 12 Pitch 15 Pitch
(Pica) (Elite) (Micro)
Left Margin 12 14 18
Right Margin 72 86 108
New margin settings remain until changed again.
1. Move the Mode Selector to Type. A typing scale appears on
the display.
2. Move the cursor using the Spacebar or Back Space to the desired left
margin setting on the scale.
3. Press Margin.
4. Move the cursor using the Spacebar to the desired right margin
setting on the typing scale.
5. Press Code + Margin. A beep confirms each new margin setting.
6. You can change to Mem Mode, if desired.
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
Jun 02, 2009 | Office Equipment & Supplies
Reset left margin
Turn machine ON and return to what is set as the left margin. then press the MAR REL key (upper left side) one time and then press the BACKSPACE the number of times to get where you want to set the left margin.
Once you are at the desired position for the LEFT MAR then press LEFT MAR ONE time and it should be set OK.
Hope this solves your problem, sneaky pete
Jun 12, 2008 | Olympia Mastertype 3 Typewriter
Margin Problems
You are in auto return. Press code and R
This should doit
DickyO
Mar 10, 2008 | IBM Wheelwriter 30 Typewriter
Lexmark Wheelwriter 1000 Typewriter Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
