Question about Brother ML-300 Typewriter
Incorrect characters printing after the third line
I reset the typewriter and it types fine until I start the third line. Then I get incorrect characters. Any ideas?
  • leibfrja Nov 25, 2008
    We replaced correction tape and now our typewriter (even after resetting) prints the wrong characters every time
  • Anonymous Mar 05, 2009
    We've tried to reset the system several times and the typewriter continues to type the wrong characters everytime.
Geno111 doesn't know what he's talking about. Look closely at your correction tape once it has passed the daisy wheel. Does it looked roughed up a little? I just had this same error and discovered that my daisy wheel was hitting my tape when spinning and not allowing it to jump characters like it needed to. I simply put a little double sided tape on the daisy wheel cover between it and the metal tab that holds the ribbon at a certain distance, to increase the space the daisy wheel has to spin. It seems to have worked so far. If anyone has a permanent solution, or answer as to how it spins wobbly, I'd love to hear it.
Posted on May 01, 2009
    Scholar:
  • 183 Answers
Sounds like a bad board, seek a repair shop
Posted on Nov 25, 2008
Whem keys are typed incorrect display of characters. how do i correct it?
REMOVE & RE-INSTALL THE DAISY WHEEL, MAKING SURE THE HOMING PIN IS IN THE HOLE NEAR THE HUB OF THE WHEEL. IF IT STILL DOESN'T PRINT THE RIGHT CHARACTERS, THE PRINTWHEEL MOTOR OR MAIN BOARD COULD BE BAD. TOSS IT AND BUY ANOTHER MACHINE
Aug 18, 2010 | Brother SX-4000 Typewriter
Types funny symbols instead of the number I
The typewriter will print the incorrect letter, or the face of the hammer if it does not spin properly to the correct position. 1. Turn the machine offf for 15 seconds and turn ON, or Depress MODE RESET(the Q key). This will rehome the Daisywheel.I If it prints correctly for awhile then looses its' position, check for ribbon or correction tape interference with Daisywheel movement. If it does not print correctly as soon as you start typing, remove the Daisywheel and inspect the spokes to see if any are bent. Reinstall the Daisywheel and power ON. If the Daisywheel has a bent spoke or two, you can try to straighten them, howvever the cause of bent spokes is a concern. While typing, carefully watch the print hammer movement. It should always return to the same position and not move towards the paper until a letter is pressed. If it does not come to rest properly, the hammer is not in proper timing and may enter the Daisywheel while it is spinning to the character, thus causing damage to the Daisywheel or causing it to lose homing. .The hammer cams would require adjustment ore replacement. If bent spokes is a persistent problem, make sure to get the hammer problem repaired before buying a new daisywhel.
Dec 29, 2009 | Brother SX-4000 Typewriter
Typing characters that are not intended
Try these troubleshooting suggestions for your problem:
Wrong Characters Print or Characters Space Incorrectly:
1. Turn the typewriter off, wait 30 seconds, then turn the typewriter
on again and try typing again.
2. Make sure the LANG indicator is off.
3. Try a new printwheel.
4. Look for objects In the path of the carrier.
5. Make sure the printwheel is changed when there is a language
change.
6. If you are playing back, make sure you use the same pitch
printwheel you used when you typed the text.
You can download the Operator's Guide for your typewriter from here (it takes a little while for the download to begin):
Wheelwriter Typewriter 30 Series II (6787) Operator's Guide
Aug 20, 2009 | IBM Wheelwriter 30 Typewriter
Wrong character
Brother T/Ws olny reset the print wheel when turned off and on. Forst check that the L/O tape is a dry one the sticky ones will give no end of grief. Check the P/W for bent spokes and look for debris in that area. DicktO
Jun 08, 2009 | Brother GX-6750 Typewriter
Wheelwriter II characters above the numbers print incorrect.
You may have an unusual printwheel that has special char. on the P/W, or you may be in the language mode hold code and press "L" key.
DickyO
Mar 10, 2009 | Lexmark Wheelwriter 3 Typewriter
Brother GX6750 typewriter correcting on wrong line
It sound like either the operator is turning the roller (platen) to see where you should correct..or the linespace mechanism is turning the roller from the line of type.Perhaps the detent (by the line space selector lever is set to 0 instead of 1, 1 1/2 or 2
The line of type is important that is stays and not drifts. Tighten the platen knob if the screw in..right to tighten left to loosen.
Hope this helps
Jan 31, 2008 | Brother GX-6750 Typewriter
Access third characters
Some print wheels have them and some dont
Oct 03, 2007 | Brother ML-100 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Types incorrect characters
Have you checked the keyboard switch inside on the right. The US setting is the selection to the rear.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 15, 2007 | Brother ML-100 Typewriter
Brother ML-300 Typewriter Logo
223 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
