Question about Texas Instruments TI-84 Plus Calculator
Linking Problem The problem is rather straightforward: if a link cable is connected to my computer for file transfer, my calculator freezes. If I attempt to do a file exchange with another calculator, it freezes. My RAM is oocasionally reset by this, too. I have been unable to find a solution to my problem thus far and would be glad to have some help.
  • TEMESEJKO Oct 29, 2008
    same thing happened to me did you find a solution?
I found out after this problem happened to me a few hours ago, that it turned out the cable that comes with the ti 84 doesn't set properly in the usb port for the mac and i kinda had to push up on it from the bottom of the fingergrip and help slide it to touch the metal in the port and held it there until i finished uploading my programs.
Posted on May 08, 2012
Does TI-84 Plus is convenient for Survey of Calculus and Finite? Unless, which calculator should I have?
Posted on Apr 10, 2008
Does the cable you are using have a short in it? I would also check the port on the calc itself.
Posted on Mar 08, 2007
Cant transfer files to ti voyage200
The error message is important. It tells the would-be helper where to start.
Anyways, did you try to check if the file(s) you are trying to transfer have a size smaller than the RAM left?.
Did you make sure that the Computer (TI connect) fully recognizes the calculator?.
I use Windows 7 (64 bits) and TI connect works perfectly.
Mar 05, 2012 | Texas Instruments Voyage 200 Calculator
How to download the Texas Instruments TI-83 Plus Calculator
1.Get linking software for your computer, such as TiLP, or TI Graph-Link, and follow the installation instructions to install it.
2.Plug your cable into the computer (where depends on what cable you have)(somtimes your computer does not have the right kind of entrance) and the other end into the calculator.
3.Start the linking program that you just installed. If it detects the calculator, everything is working fine, and proceed.
4.Download calculator software from the internet. You can find many programs athttp://www.ticalc.org
5.Make sure downloaded program is unzipped and located in a normal windows folder
6.Select the program you downloaded in your linking program (how you do this varies between programs) and send it to the calculator. For Windows this can involve finding the unzipped program in windows explorer and right clicking it (from a normal--nonzipped--folder window) and selecting "send to TI device"
7.Use the program on your calculator.
TIPS: If you have a USB cable, you will need either TiLP or TI Connect, no other software supports it
Things you'll need:
-A Texas Instruments graphing calculator
-A link cable for the calculator
-An internet connection
Aug 18, 2011 | Texas Instruments TI-83 Plus Calculator
How to download music to my phone?
You can connect the phone using the linking cable when the phone will be detected. open My computer and see the phone memory. Now copy the files from your music files.
You can also remove the micro sd card and use an adapter to load it to the PC and copy the files directly.
finally activate BLUETOOTH on the phone and the PC and transfer the required files.
Jul 22, 2011 | Computers & Internet
I cant find the software for linking my CFX9850G
Here is the link to the software. You still need the appropriate Computer-Link cable.
Mar 11, 2010 | Casio CFX-9850G Plus Calculator
Urgenttttt --- when i used notefolio on my computer to transfer notes to my calculator TI-89... i could not find transferred notes on my calculator!! where can find it?? or do i have to download...
You need to install notefolio to your TI-89.
You can download the program from:
http://education.ti.com/educationportal/sites/US/productDetail/us_notefolio_89.html
After you download the program file, you can use TI-Connect to transfer the program file to your calculator (after you connect the calculator to the computer with the USB cable). To transfer the files, simply drag and drop the program file onto the TI-Connect icon on your computer.
To learn more about the Notefolio app, here is the guidebook:
http://education.ti.com/educationportal/downloadcenter/SoftwareDetail.do?website=US&appId=6204&tabId=2
Nov 25, 2009 | Texas Instruments TI-89 Calculator
Transfer files
You need to get a usb "linking cable", this cable has a standard usb on both ends and comes with software. Just plug it in to both laptops and run the software to start transferring files. These cables usually cost 20-30 dollars and can be picked up at most electronic or computer stores.
Good Luck
Hope this helps
Jun 27, 2008 | HP Pavilion dv6000z Notebook
Linking Problem
Make sure the cable is the right kind. just because it fits doesn't mean it will work: a gameboy charger fits in the graph link spot (don't ask how I know this), but it will kill your calculator (or at least batteries, once again, don't ask).
Apr 30, 2008 | Texas Instruments TI-84 Plus Calculator
I want to be able to transfer files to my Casio fx-9860G AU calculator from my computer. I have instaled the program but can not go any further. I have a file saved on my computer that i want to transfer....
Dear Abbcraftyash,
you open de FA-124 or the link program you have, then link you calculator to the computer with you usb cable, then click on connect calculator wait... a then you can transfer you a files... If your calculator is new, into de box of calculator there is a guide explaining all the steps... http://world.casio.com/calc/download/en/manual/ «« In this link you have guides about all calculators of casio.
Cheerup and Be Happy Always
Mar 10, 2008 | Computers & Internet
TI-84 PSE: Stuck on waiting... please install operating system now screen
The best way to solve this problem is to get a 2nd TI-84 to link into with the linking USB cable. Then turn on working calc press the 2nd button then link button (or the XTON) variable button. Scroll up to option G: SEND OS "DO NOT HIT ENTER YET" and then remove and replace one battery from the non-working unit. NEXT press enter on working unit to SEND OS.
Oct 18, 2007 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
392 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
