Question about Sungale DVD-2026 DVD Player
I have connected the dvd2026 to my samsung hdtv using the Pr,Pb,Y
I chose "Component 1 - DVD" in the Menu Input Source List on TV. I get Component1 DVD upper left corner of screen and "NO SIGNAL" shown on the center of the screen. My DVD2026 unit is on with a DVD disc in it. I've tried different cables and the screen shows the same. I've lost the User Manual fot the unit.
2 Suggested Answers
SOURCE: Where do I buy a remote for DVD2026
Original remote for Sungale dvd 2026 is hard to find. Right now I am selling one RC on Ebay. It is a second hand but in working order. I am selling RC because my dvd was damaged in a blackout
Posted on Oct 14, 2009
How do i connect my dvi to vga to my misubishi ws-65313
you can't, DVI is a digital video source and VGA is an analog video source. however there is a VGA to component RGBHV cable that you can use. the Mitsubishi TV is very limited to the resolutions the VGA output can be. only 1080I, 480P or 480I. HD component video input in the menu you must change the source from Y /Pb/ Pr to RGB.
Jun 07, 2014 | Mitsubishi WS-65313 65" Rear Projection...
How do i change the input
The 27" TV uses the same instructions as the 20", and I found the manual for you at the link below. Answering your question directly, here is the section of the instructions about changing input:
Changing the TV's Input Normally, your TV displays the signal coming through the antenna terminal. However, if you've connected another component to your TV(such as a VCR & DVD) using the Video/Audio input,you will want to be able to view the signal from the component.To do this, you will need to switch from the ' TV ' input to the 'AV1-AV3, CVI' Input, as follows. 1 With the TV on, press the MENU button twice, then " Set-Up " menu will appear. 2 Use the WCHV buttons to select " Input ". 3 Press the CVOLB buttons to change the input source from ' TV ' to 'AV1, AV2, AV3, CVI'. 4 Wait 20 seconds, or press DISPLAY button or MENU button to return to normal TV viewing. * CVI means the Component Video Input (Y/ PB/ PR) from the DVD player etc.* Users can also select these input modes with the TV/AV button or the INPUT button on theremote controller. * On the AV1 mode , if you connect the S-VHS jack to your TV, "AV1" is changed to "S-VIDEO".
The link to the manual is below.
Jun 01, 2014 | Daewoo DTQ-27U4SC 27" TV
What channel to set for dish network
Depending on the type of cabling your using the input may vary. If you are Connected using a digital cable such as an HDMI or component (y/pb/pr) cable then you want to set the TV to the HDMI or component input by pressing input or source on your TV. If this is connected using coaxial cable tune the TV to channel 60, 62, 73, 75, 3 or 4
Daniel Busa
DISH Network
Customer Service
Apr 21, 2011 | Vizio L32 32 in. LCD HDTV
I've tried connecting a Sony DVD player to my TV using Pb Pr V cables. I get a picture, but no sound.
The cable u are using it is the S-video cable?Yes,this cable dosen't support audio.Must used a RCA component cable like R,W cable connected between the tv and the DVD player to get sound.
Mar 14, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How do I change the settings to 740 p or 1080?
Hello
1Connect the video outputs (Y, PB, PR) of the digital
set-top box to the COMPONENT IN VIDEO
jacks on the set.
Connect the audio output of the digital set-top box
to the COMPONENT IN AUDIO jacks on the set.
Turn on the digital set-top box. Select Component 1 input source with using the
INPUT button on the remote control.
- If connected to COMPONENT 2, select
Component 2 input source.
Feb 20, 2011 | LG 42LC2D 42 in. LCD HDTV
Y/Pb/Pr outputs are green; needs
There is no calibration for the component video that I know of, check your cables you may have a bad Pr cable or the Pr/Pb ones may be mixed up.
Y (the green one) is for luminance, plug in ONLY this connector and you should see a black and white picture.
Now connect the Pr. You will now see red tones.
Now connect the Pb. And you will see blue tones.
Reverse the Pr and Pb and see what happens.
Oh and make sure you don't accidently have one plugged into a composite video or digital audio port.
Still not looking right?
Go into the input menu of the TV and change the component (or colourstream) input from RGB to Y/Pr/Pb. (most TVs do not have this feature.
Hope this helps!
Jan 24, 2010 | Samsung SIR-TS360 DirecTV DTV Receiver
Dvd won't send picture/audio to tv
for video, 3ways and any of this should work.
Step1, video out of dvd to video in on top at video1 section on tv. or
Step2, svideo out of dvd to svideo in at video1 section on tv. or
Step3. using component video DVD unit component video out to TV unit component video in at video2 Y to Y input of TV Pb to Pb input of TV Pr to Pr input of TV
for audio, connect left/right audio of dvd to left/right input of tv. Input section of TV is in the middle. on tv back panel from left to right is antenna input, IN section - this is it, use this for all your connections. let us know if you have any issues. thanks.
May 02, 2009 | Panasonic DVD-S27 DVD Player
When componet is hook up for hd
My first guess would be that the component connections are not matched. Check the component method and make sure that both the source and the TV are set the same. There are two methods:
1) RGB
2)Y,Pr,Pb
If the set is set for RGB and you are sending Y,Pr,Pb the picture will look a bit purple.
Dan
Jan 28, 2009 | RCA HD61W66 61" Projection HDTV
Monster Component Cable labled Y/Cb/CR to TV that has Input Y/Pb/Pr
Y PB PR is the analog version of the Y CB CR color space; the two are numerically equivalent, but Y PB PR is designed for use in analog systems whereas Y CB CR is intended for digital video.
Aug 31, 2008 | Televison & Video
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
Sungale DVD-2026 DVD Player Logo
16 people viewed this question
Top Sungale Televison & Video Experts
Henry  Thomas
Henry Thomas
janman
Are you a Sungale Televison and Video Expert? Answer questions, earn points and help others
