Question about Astoria Argenta AEP-2 Coffee Maker, Espresso Machine
Pressurestat defect ?
Hi, on my astoria argenta automatic 2 head, the security reset on the pressure had tripped after we moved the machine. now a have problems to set the pressurestat. what is the best settings start at 1bar and stop at 2bar ? it seems very hard to set the pressurestat, Is it possible that it's defect ? Or the security reset swich is defect ?
Thanks for the advice
  • 22 Answers
Yes, your pressure stat should turn off once in the "green" area. In most cases a pressure stat works or it doesn't. A lot of times carbon build up on the contacts is the issue. They are sensitive and can break off easily when your cleaning them so be careful. Also make sure the machine is turned off before doing any work (220v = ouch!).
Posted on Jul 16, 2009
Why is water leaking from pressure release valve?
there can be two reasons I can think of that water drips from that valve :
1: thermostat for boiler is defective and not keeping boiler at proper temperature
2: minerals in water deposited inside valve and keep it from sealing off well
Dec 01, 2015 | Astoria Argenta SAE-2 Espresso Machine
I replaced the pump and it's working, however, when I turned on the machine and the boiler came up, there's a stream of pressured steam coming out of releasing through the top of the machine. Any id
Hopefully, your pressure gauge is working, and if it is at 1.2 bar or so, then you have a failed anti-suction valve or boiler safety valve.
The ASV is the smaller fitting; it might be stuck, so you could try tapping the little button. The boiler safety valve is another matter - it will open at some point past 1.8 bar, which means the pressurestat is shot or its adjustment has been tampered with.
25401838-vippk3d42tdcmss1ngrlvpy2-1-1.jpgBoiler Safety Valve
It's most likely the ASV - they do get stuck open as well as closed...
Feb 05, 2015 | Astoria Argenta SAE-2 Espresso Machine
I have a Astoria Argenta and one of the groups is not working. If there is a blockage, how do i get to the problem.
basicaly all you can do is unplug machine, turn off the water and cool machine to cold. then take apart the group head working back to the boiler till you find the blockage.
Aug 31, 2011 | Astoria Argenta SAE-2 Espresso Machine
How to set the timer
Look behind the right steamwand, you will see a little toggle switch with the on label on the left. Move switch to on label then press program button, all light on keypad will be on, press button until desired amount then press same button or stop button, continue until all buttons are programed.
Jan 10, 2010 | Astoria Argenta AEP-2 Coffee Maker,...
I have an Astoria Argenta SAE1 Jun espresso machine. It has started tripping the circuit breaker. It does this when it has reached operating pressure (or nearly so). It does this without anyone touching...
Your problem could be one or two items (element or pressure stat or both). Remove the screw in the top of the P.stat(black or gray rectangle box with electrical wire going in from bottom about 4-6 inches long), lift the cover and check the terminals(turn power off). Make sure that there are no loose connections on the terminals.
On the element remove the wires that are connected to it and test with an Ohmsmeter.
Feb 20, 2009 | Astoria Argenta SAE/JUN Espresso Machine
I need a new pressure guage for an Astoria A2 - coffee machine
here is the site where you can get your presure gauge and other parts for your machine.
Jan 19, 2009 | Astoria Argenta AEP-2 Coffee Maker,...
Hot water no steam low psi
Boiler pressure gauge should be showing in the green zone which should get you 195+ degrees.
Nov 17, 2008 | Astoria Argenta SAE-2 Espresso Machine
Astoria Argenta AEP-2 Coffee Maker, Espresso Machine Logo
171 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
