Question about HP Computers & Internet
When we turn the laptop on, it goes to startup screen and then gets stuck in a cycle/loop of loading (including which startup mode you want)
  • 35 Answers
Most likey a Windows fill of some sort is corrupted. The best solution would be to just reformat the computer and lose all data.
Alternatively you could use a Linux Live CD to boot from the CD-ROM and access the hard-drive to perhaps save any documents. If you don't know how to do this yourself I'd recommend carrying it to a facility that is fluent in computer support. Try a local college's IT Department.
Posted on Nov 19, 2008
Automatic repair
hi Andrew.
"Upon the 'Preparing automatic repair' window, press-and-hold Power button 3 times to forcefully shut down the machine. The system will enter boot repair page after 2-3 times of reboot, choose Troubleshoot, then go on to Refresh PC or Reset PC."
Get Rid of Infinite Preparing Automatic Repair Loop - EaseUS
https://www.easeus.com/resource/fix-preparing-automatic-repair-loop.html
How do I bypass startup repair?Fix #1: Boot into Safe ModeInsert the disc and reboot the system.Press any key to boot from the DVD.Choose your keyboard layout.Click Repair your computer at the Install now screen.Click Troubleshoot.Click Advanced options.Click Startup Settings.Click Restart.More items...Startup Repair Infinite Loop: Fix for Windows Vista, 7, 8, 8.1https://neosmart.net/wiki/startup-repair-infinite-loop/Search for: How do I bypass startup repair?
How do I boot my laptop up in Safe Mode?Open Windows in safe mode using Command Prompt.Turn on your computer and repeatedly press the esc key until the Startup Menu opens.Begin a System Recovery by pressing F11. ...The Choose an option screen displays. ...Click Advanced options. ...Select Command Prompt to open the Command Prompt window.More items...HP PCs - Windows Safe Mode (Windows 10, 8) ' HP® Customer Supporthttps://support.hp.com/bg-en/document/c03439317Search for: How do I boot my laptop up in Safe Mode?
or go to this link if you need more help.
laptop preparing automatic repair Google Search
Nov 28, 2017 | Computers & Internet
Aspire 5475 freezes on startup
It is most certainly a driver, but if you cant access the safe mode also that could be a hardware issue.. Try to troubleshoot with a windows installation cd. Put it in and boot the pc. It will start the windows instalation, you choose repair computer and not install windows. The command prompt will open, try to troubleshoot from there.. Thanks!
Mar 19, 2013 | Computers & Internet
XPS M1330 laptop is stuck at update 3 of 3. It is in a loop between the update and restart.
Search Results
Latest Vista Update stuck in Stage 3/restart loop - Microsoft ...
https://answers.microsoft.com/...update/...update-stuck...3restart-loop/2f70b13c-9db4-...
Jul 26, 2009 - I have Vista Business system on a Toshiba notebook, latest Service Pack and with allupdates. ... I just booted it up to find the Stage 3 page of a Windows update. ... Have tried using F8 to get last good installation, and to stop auto restart, without success, it just keeps returning to ..
Mar 21, 2017 | Dell XPS M1330 Notebook
Computer won't startup gets stuck in driver loop
if you have a PC then when it has the codes there will be options so you click on "start windows normally" because it is in safe mode that happens after your computer has dump crashed. so if you change it that might help! good luck
Oct 05, 2012 | Sony VAIO VGC-RA820G (027242657700) PC...
Compaq nc8230 stuck in startup loop after system restore to earlier date
on startup time press F8 for no of times.From option click repair and continue with instruction,When asking for password ,change user name and click enter
Mar 13, 2012 | HP Compaq nc8230 Notebook
Laptop goes into loop upon startup...
How did you manually configure it to go into safe mode? Did you edit boot.ini? if so try editing this back to normal. You could try hitting F8 on startup and doing a different Safe Mode startup to break the loop. From there you may be able to get it stable enough.
Another option would be to make a Bart PE boot disk and use that to edit Boot.ini
Dec 17, 2009 | IBM ThinkPad T42 Notebook
Start up problem!!
When you boot up start pressing F8 and you should get a Windows startup page with more options. If you do select Safe Mode
When windows has loaded, goto MSConfig and select Diagnostic Startup. Ok and reboot
See if windows boots normally.
Apr 26, 2009 | Acer Aspire 6920 Notebook PC
Gateway laptop mx3414-black screen cannot load windows
Try going into safe mode upon startup by hitting the F8 button. If it does then hit safe mode to get into your computer. Go to start>accessories>system tools>system restore. Follow the wizard to restore your computer to a date earlier than when you started having problems. Let me know if you have any problems or questions.
Mar 19, 2009 | Gateway MX3414 Notebook
Stuck in demo mode
to deactive demo mode press menu on the remote...then w/that screen up push the screen mode little gray button at the top of the remote...note that this will not change anything on the screen...i know weird huh...now type in the numbers 9012 you should now be at a new menu the top opption is demo mode...choose it and then choose on or off...good luck i see this i an old post but i hope it helps someone...
Jul 08, 2008 | Sony DHG-HDD250 200-Hours Video Recorder
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
