Question about Ovens
Stovetop electric ignitor
Can I just cut wire to one stovetop elect. ignitor?   Can't get to back of stove to disconnect.   It will not stop clicking when oven is on.   All ignitors stopped working some time ago,  which was good because that clicking had been annoying me for a long time back then.   Well, for some reason  "their back".    I figure I should shut of elect. before cutting it,  but anything else?   I don't want to just disconnect elect for good because I use the clock and timer.    Just want to keep sanity  click.....click....click....click.....ahhhhhhh!  lol       Can't afford to have any repairs.
Thanks for any help.
    Top Expert:
  • Ovens Master
  • 51,161 Answers
Cheaper , safer to just get in an accredited electrician to fix the problem
why have something that is just a clock
Posted on Mar 24, 2017
  • 1314 Answers
SOURCE: Phantom ticking
wait about three days to see if it stops this is typical when you clean one this way as water can get in the ignighter switches if not you have to replace the switches which are on the knob shaft behind the panel and come in sets of four and its not hard
Posted on Jun 20, 2008
  • 1314 Answers
SOURCE: Bake ignitor Location
ok jimmy not as bad as you think you access it through the oven cavity remove all the racks look for two screws on the bottom panel i believe they are at the front remove them then remove the bottom panel next you will see a lame spreader which is an angled plate remove it then you will see the burner bar at the back is the ignighter just match it with the new one
Posted on Feb 11, 2009
  • 117 Answers
SOURCE: My stove works and so does my broiler. I replaced
If you use a multimeter, you can test the gas valve where the white and yellow wires connect is where your terminals for bake on that valve are. If you have continuity there, then check to make sure that igniter is wired ok.
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
  • 289 Answers
SOURCE: I have a Magic Chef stove Model # 31001SAW. It is
if the ignitor is not a brite red than it is not putting out the 3.5 amp's neaded to open valve.you can check the valve with a continueaty meter.remove the two wire's from the valve and check valve with meter,if valve check's good than ignitor is bad.
Posted on Nov 18, 2009
meztang
  • 112 Answers
SOURCE: stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 17, 2010
Stoves Q720 GRF DO main oven ignitor clicks / sparks continuously
Might be the PC board, or it might just be the switch behind the oven knob - try disconnecting the wire leading to that switch and see if the clicking stops. If it does, the switch is bad. If not, suspect the electronics.
Aug 23, 2014 | Ovens
Ignitor on stove won't stop clicking
Contact a professional to have the ignition diagnosed for replacement. Do not use the unit before then for safety reasons.
Aug 25, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
How do i replace oven element
Is it gas or electric ? If elect take two crews off and pull old element out carefully so u want unplug the two wires off .then unplug each wire and make sure it doesn't **** back in .if that happen u well have to take back off to get to wire. Make sure u unplug the power before u start LOL. If u need to clap wire first to make sure u don't lose it. Then plug in and push new one back in .. if gas take bottem plate out in side of the oven .two screws .one one each side or it could be a slide tab .then take off heat flame plate and u well see the ignitor .ether round or sq looken .two black 1/4 nut.they like to strip on u .its ok get them off and put alittle bigger ones in.check .match plug ends of the new to old see if match .if not cut plug of new ignitor and put old plug from ignitor and wire back on the new ignitor and install just how u took of old on off the gas tub
Nov 10, 2011 | Ovens
I've got an amana gas oven range and just had the ignitor replaced. Everything seemed to work great afterwards for about 2 hours but then the breaker tripped. I let the oven cool down before I reset it...
What you want to check or have checked is if the wiring on the new igniter was accidently not properly insulated and some or the wiring is bare and touching metel shorting the breaker each time the oven is turned on.
Aug 16, 2011 | Magic Chef 9512 Electric Single Oven
Hi there. there is no spark to ignite the gas in oven.
You will need to replace the spark module if you don't hear any clicking, or there is no spark present when trying to ignite the gas.
To test the Spark Module:
When properly operating, the spark module repeatedly produces a spark at the ignitor accompanied by a sharp snapping sound.
  1. Turn off gas and power supply to unit.
  2. Check wiring diagram to verify all terminals and wire connections are correct and tight with no cuts in the wiring.
  3. Prepare to measure voltage on spark module from terminal L to N.
  4. Turn power supply back on.
  5. Turn top burner to LITE position.
  6. If no voltage is present on the meter, this will indicate the electrical circuit is interrupted before the spark module
  7. If voltage is present, then check ignitor.
  8. If ignitors are ok; then replace spark module.
To access the Spark Module:
  1. Turn off electrical power and gas to the range.
  2. Disconnect gas and power from unit.
  3. Remove screws securing top surface burners.
  4. Remove surface burner and disconnect spark ignitor wire from surface burner.
  5. Raise and remove maintop from unit.
  6. Remove screws securing spark module bracket.
  7. Disconnect wire terminals from spark module.
  8. Replace and reassemble in reverse order.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
May 18, 2011 | Amana Ovens
Oven wiring diagram or help?
I suggest you post this under Inglis to have a better chance of having an answer
Dec 31, 2009 | Stoves 720EF Electric Double Oven
I have a whirlpool gas stove, the bake or broil will not light.
Check to see if the electric ignitors are connected at the ignition module, located under the top surface panel. It is possible that the wire(s) that go to the oven ignitors has burned off or become disconnected from the main spark module,
It is also possible that the electrodes have failed and need to be replaced. These are the two (2) devices that produce the spark (and make the clicking sound) inside the oven compartment.
If those are OK, then check the thermostat, as it could be faulty and preventing the oven from functioning.
If you can smell gas when attempting to turn the oven (bake or broil) then the valves are good, if you don't smell any gas, the gas supply valves (one for each bake and broil tubes) need to be checked.
You might also try lighting the oven manually with a long match or grill lighter to rule out faulty gas supply valves or a faulty thermostat, which if you can manually light the oven, it would prove that the ignitors must have failed.
Here's the exploded line drawings for your stove along with the parts list, just click on each section to see the parts. You can order replacement parts from them as well.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=gw395lepb02&pop=flush
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Ovens
Oven will not work - Hi/Lo broiler works fine
you have a bad bake ignitor. it is mounted to the long tube in the very back wall of the tube. usually held on by 2 1/4 inch bolts. usually if you replace the ignitor you have to cut the old one off and hard wire the new one in depending on what the new connection on you ignitor look like.
Jan 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore oven 362.75275690 won't fire...has new ignitor
if you get 120 volts to the ignitor, then the ignitor will glow ,if not you have a bad ignitor. the valve should have continuity through the the 2 connections.. its poosible to have 110v to ground at ignitor, the only way you get 110v you need to check power across the 2 wires to the ignitor( not to ground), and this will not happen with a bad safety vavle
Nov 23, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
35 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
