Question about JVC HD-56G786 56" Rear Projection HDTV
TV won't turn on, possible lamp failure.
We were watching TV just the other day and the screen just shut right off. I am guessing the lamp went out as the screen has been dim on anything other than HD lately. I have looked at D-M for a replacement bulb but I cannot find specific instructions on how to replace the bulb myself. I am pretty tech savy but I don't want to ruin something trying to figure it out myself as this was an expensive TV. Please let me know what to do or where to go. Thanks.
  • mbark2004 Nov 18, 2008
    I went direct to JVC and downloaded the manual and ordered the part early this morning from DM after posting this question. It seems extremely simple as indicated in the owners manual for the product. Thanks anyways.
  • JVC Master
  • 5,568 Answers
I would suggest, since you have some technical background, that you download the manual for your set.
This site seems to have the best prices of any around:
JVC HD-56G786 Service Manual
Posted on Nov 18, 2008
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
The screen went black
LCD sets use either a fluorescent backlight or LEDs if newer. If your set uses the fluorescent type, either the lamp itself or the inverter that produces the 'strike' (high) voltage for it has failed.Inverter failures are pretty common but the lamp life in in 5-digits of hours (probably >10,000 hrs)
Dec 31, 2011 | Element ELCHW402 40 in. LCD HDTV
Our tv recently displayed projection lamp was about to go out and needed changed, so i purchased a new lamp assembly and replaced it. tv worked good as new for a few days, then in the middle of watching tv...
Most often, I find when servicing these televisions, the lamp has failed but it was due to poor fan circulation. This television has at least 3 if not 4 fans. If you take off the back and find these fans are filled with impacted dust, the fan may be causing the failure. Also check to be certain your door safety switch is making good contact. These tips should ber of assistance but check your fans. A clean inside of a tv is a happy tv!
Jul 11, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
I have a sony kp41t15 projection screen tv..the other day i was watching my tv is and just went black on me..shut it off for 5min or so and..still was black..but i can hear sound..the weird thing is once...
The tv projection lamp on the tv have not been change like the last 1 1/2 or 2 years?Yes.Than the tv projection lamp is the problems,it should be change.
Mar 16, 2011 | Sony KP-41T25 41" TV
Sound but no vision, black screen
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 25, 2009 | Sony Televison & Video
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
JVC HD-56G786 56" Rear Projection HDTV Logo
203 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
