Question about Troy Bilt 31cc Quickshift Blowervac, Model No. Tb310qs
Troy built leaf blower
Will not start
  • 1 more comment
  • jcvettss Dec 31, 2008
    my blower wont stay running. It idles for a fews minutes but then once you apply gas it stops running.
  • Anonymous Feb 08, 2009
    HAVE SPARK, HAVE FUEL (CLEAN) WILL NOT START.
  • Anonymous Mar 30, 2014
    troy built backpack blower starts easy and stalls looks like oil in breather
  • 163 Answers
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
Posted on Nov 29, 2008
Which gas line goes to the top of TB 320 BV troy built leaf blower. 41DS320G966 carburetor 753-04338?
I suspect it is the one from the gas filter in the tank. If that doesn't work switch the lines around. Hope this helps. If not let me know if it has a primer bulb or not and I will try to help. Hope this helps.
Nov 20, 2015 | Troy Garden
Why will my blower only run on full choke
try getting a new carb 25 or 30 bucks rebuild kit about 18 bucks so it one or the other, good luck.
Jun 17, 2014 | Troy-Bilt Troy-built Tb2bpec 27cc 2-cycle...
Troy-Built blower fan off centre
Fan may be worn where it sits on the shaft. May need to replace it.
Aug 28, 2013 | Troy-Bilt Troy-built Tb2bpec 27cc 2-cycle...
The bolts holding the fan to the housing came off and it won't start. Is it worth trying to repair or just trash it and buy a better built blower
Troy built is a very good machine but you might have answered your own question especially if the machine is very old.
Nov 18, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
My troy-built blower will not start
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 26, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
The leaf blower won't start and I did change the spark plug and last time it run for like 30 sec. before it shut down again.
Main cause of small gasoline engine failure is carburetor clogged. Try spraying carburetor cleaner into carburetor and intake. Check if unit has air cleaner. If engine starts briefly with cleaner then carburetor needs manual cleaning. Carburetor removal and overhaul.
Jul 10, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Hello, My 31 cc troy built blower won't start. It's got spark. When I pulled the brand new plug it appeared to be completly dry. I sprayed ether in the cylinder and put the plug back in and it started...
If the either burned, then you have a fuel problem. Make sure the fuel filter (in the tank) and the lines are all clear. If so, then you my need to rebiud the carburator.
Jan 19, 2009 | Troy-Bilt Blower/Vac 31cc, 200 MPH, 405...
Troy Bilt 31cc Quickshift Blowervac, Model No. Tb310qs Logo
667 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
