Question about Lexmark X5150 All-In-One InkJet Printer
LEXMARK X5150 CARTRIDGE ERROR
I have a Lexmark All-in-One X5150 printer. All of a sudden I started geting a connumication errors. I fixed these a couple of times by rebooting the computer. Now I am getting cartirdge errors (50C with a message to look at my user guide). I have an old color cartridge that I have not changed in years since we only do black and white prints. I tried the suggested fix in the User Manual which did not solve the problem. I got a new black cartridge and it did not solve the provlem. I tried cleaning the contacts in the printer cartridge buckets and on the cartirdges and that did not work. I am out of ideas. Can you help me?
    Problem Solver:
  • 7 Answers
Try this --
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges
Posted on Dec 04, 2008
Error code 0504
Problem Error: " Hardware Error 0504 " on the LCD Display Solution When you try to run the Clean option from the Ink Cartridge menu, the following message may appear: Hardware Error 0504.
To resolve this issue:
  1. Take both cartridges out of the printer.
  2. Switch off the printer using the power button.
  3. Disconnect the power cable from the back of the Lexmark X5150.
  4. Leave the power cable disconnected for 30 seconds.
  5. Reconnect the power cable and switch the printer on again.
  6. Reinstall the cartridges. (Follow the instructions on the LCD screen or refer to the following document: http://support.lexmark.com/index?page=techlibraryKB&linkSelected=node2^subnode0&channel=techlibrarykbchannels&locale=EN&userlocale=EN_UK
Sep 02, 2011 | Lexmark X5150 All-In-One InkJet Printer
Says erorr 50c on my lexmark x5150
The 50c error indicates a problem with your cartridge. This article will help you determine and resolve the issue: Cartridge Error 50C and Other Errors on the Lexmark X5100/X6100 Series LCD Screen.
Apr 20, 2011 | Lexmark X5150 All-In-One InkJet Printer
Lexmark 5150 has stopped printing. press print and get error code0502 how do I fix the problem
The 0502 error code can be caused by either faulty cartridge or a dislodged encoder strip (transparent strip) in the cartridge area. Refer to this article in the Lexmark website on Error 0502 on the Lexmark X5130/X5150/X5190 Pro LCD Display. This will help you determine and resolve the problem. Thanks.
Feb 16, 2011 | Lexmark X5150 All-In-One InkJet Printer
Printer won't print--error 0502. What is this and how do I fix?
After months of use, your printer might get the habit of stopping in the middle of a page and showing "Hardware Error 0502" on the LCD display. If you leave the printer alone for a while, it might start printing again. Then again, it might not. Pretty annoying.
The Lexmark support site will let you power off, remove the power cord for 30 seconds, take out the cartridges and fiddle with some encoder strip. This whole procedure might take you up to 30 minutes and it will not help (been there, done that).
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
Clean that with a paper towel. The towel will be black from the ink residue, but you will be able to print again.
Feb 09, 2011 | Lexmark X5150 All-In-One InkJet Printer
Printing stops and gives error code
The error is caused by either the cartridges or the encoder strip. Here's a link to the Lexmark website to guide you on what to do. Just click on this link: http://bit.ly/affECc .
Mar 31, 2010 | Lexmark X5150 All-In-One InkJet Printer
Errir 50C
Try these solutions from Lexmark online support: (apparently one of your print cartridges has shorted)
Lexmark X5150 Error 50C
Jan 09, 2010 | Lexmark X5150 All-In-One InkJet Printer
Hardware error o504
It shows color cartridge is missing because either the cartridge is not well placed or it is not there.
  6. Reinstall the cartridges. (Follow the instructions on the LCD screen or refer to the following document: How to Install the Cartridges in the Lexmark X5150)
Jan 11, 2009 | Lexmark X5150 All-In-One InkJet Printer
The computer tells me problem communacating with the computer
I'm looking for a way to hook up lexmarkt620 printer to my computer. I did not recieve any download cd or floppy disk for my computer.
Dec 29, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
366 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
