Purchased my Philips TV 2 years ago( 20PF4121 ) 20" LCD and every time I switch it on the green power light keeps flashing and it won't switch on. Any advice please.
  • jasper07 Nov 18, 2008
    Thank you Ronnieh, is this likely to be expected?
  • Theeduy Mar 09, 2009
    Genius:
  • 2,920 Answers
There are 4 capaciters on the corners inside the back of the tv if they are popped up they need to be replaced
Posted on Nov 18, 2008
  • Ronnie Houston Nov 18, 2008
    yes it happens alot and the cost to replace them is about 400.00 or so
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Jul 18, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
Bought in Dubai 3 years ago Pan.Viera LCD 32"\r\nStandby light flashing red/green. Have to switch on with on/off button after a few minutes switches off itself..........then back on itself
Power LED Blinking timing chart
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
blinking
1 dg board, (stv 5v sense time out)
2 d board
3 d board
4 p board
5 d board
6 su sd sc boards
7 su sd sc boards
8 ss board
9 panel config
10 digi board-
11 pb board
12 h board
13 dg board
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
I have a Sylvania LC195SLX TV that when I try to power on the "power on" light (green light) flashes several times and then the tv just goes back to the "stand by" light (red light). ...
The power supply is down . Sylvania power is very simple went you take the back off you should see the two bad capsitators on the board.Just replace them with same value .
Mar 01, 2011 | Funai LC195SLX 19 in LCD TV
My power comes on, then the green LED light switches to red, and flashes 6 times over and over. I tried the fix on youtube with the IC capacitors for the 50PF9731D/37 even ordered the $1 capacitors but...
I am definitely a girl explaining this because I don't know the correct parts of the tv. Here goes. We had the same problem last year, called philips they advised I do a software update on the tv because that fixes everything....wrong. The light still flashed and no picture. I called them back and they said I had to find a philips tv repair to take it into....got lucky because there was one close by. Come to find out it was some board inside that cost $400 to repair. I thought cool it's cheaper than a new tv! Worked great until about 2 weeks ago the tv turns on and the light is green and picture pops up a minute later. Oh boy more problems! As I sit here right now my tv no longer has a picture. The green light is on but nothing. It's funny because we had it repaired this time last year. I'm fed up and buying a new tv!
Nov 29, 2010 | Philips 50PF7321D 50 in. Plasma HDTV
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
Oct 11, 2017 | Televison & Video
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Akia 27 inch tv wont turn on
Power packs can be repaired, and most time it is simply capacitors. I don't charge an arm and a leg
Mar 26, 2009 | Akai LCT2715 27 in. LCD Television
Red light flashing on tv
My 37" TV Will not yurn on . The green light goes on for 2 seconds then goes off and red light starts flashing. What Repair/Part is needed.
Aug 31, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
335 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
