Question about Craftsman 4 Cycle Blower/Vac
My string will not pull its like its stuck need help thanks
I have a craftmans and its about 5yrs old 200mph
  • Anonymous Dec 01, 2008
    my string is hard to pull, goes back in slowley
  • 163 Answers
It might have vapor lock, try removing the spark plug and spray a little penetrating oil into the cylinder, let it sit for a couple minutes and try pulling the cord again with the spark plug still off.
Posted on Nov 29, 2008
Cub cadet just dropped dead?
like a car engine broken rod--piston ring--wrist pin --blown gaskets
May 18, 2017 | Cub Cadet Garden
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
How do i remove the head to replace the string on a Murray M2500 trimmer?
How do i remove the hend of the weedeater it is stuck on there. I believe it is stripped
Sep 08, 2014 | Garden
How do I take apart craftman 25cc gas weedeater to replace the string?
Same problem here......need to replace the trimmer string......some of you guys and probably some ladies know this...Ple Don't know which way to turn the head to get it off, or if I also need a tool to remove it. Please help!
Aug 21, 2011 | Craftsman 25cc Gas Line Trimmer
HOW TO PRELOAD THE PULL STRING ON CRAFTMAN MODEL358791050
You hand winde it in a CCW direction BEFORE installing the rope all the way until you feel significant resistance. (It really helps if there are 4 hands doing this). You then align the pulley knot hole with the rope guide but letting it rotate CW until it just lines up. Have that 2nd pair of hands GRASP the pulley tightly. Then pass your rope throught the rope guide and into the knot hole of the pulley. Tie 1 small tight knot and PULL hard on the rope to seat the knot in the hole. Let go of the pulley and the rope will spring wind into the starter recoil assembly. Sounds easy.. but can be quite tedious.
See this link for pictures.
http://www.ereplacementparts.com/article/6299/How_to_Fix_the_Starter_on_a_Ryobi_Trimmer.html
(Ryobi) but the concept is the same.
Thanks for choosing FixYa,
Kelly
Jul 20, 2011 | Garden
I CAN'T FEED THE ATENNA CABLE THROUGH THE CHANNEL. IS THERE A TRICK TO THIS?
if you haven't already pulled the old cable out you can tie a piece of string or small wire to the end of the old cable before you pull it through (make sure the string is plenty long). then as you pull the old cable out it will pull the string through the channel. when you see the string untie it from the old cable and on to the new cable then pull it back through the other way.
Jan 04, 2011 | Honda Civic Cars & Trucks
I was given a B&D 2250 machine (used) and the kneading blade seems to be fused to the bottom of the machine. I have soaked it in hot water and scrapped out dough from beneath the blade but it is still...
I buy and sell bread machines and have run in to your problem many times. Just log on to you tube and type in,,,,,,,,,,,How to Remove a Stuck Bread Machine Paddle or Kneading Blade"
You will need ...2 hotpads, an old shoelace or string about 3 feet long and 2 old milk jugs, detergent botlles etc......something that will provide weight than you can tie the string to. Tie the string tightly around the post and knot it tight.....the string goes in the little gap between the bottom side of the paddle and the pan. The other end is tied to the milk jugs....watch the video and it will make sense....
Nov 27, 2010 | Black & Decker B2250 Bread Machine
How do I replace the string on a Craftman Weed Eater model number 358.791030?
how do you fix it when the pull rope breaks ? how do you take it a part to puted a new rope on ?
May 15, 2010 | Craftsman 25cc Gas Line Trimmer
The string in the spool of the weed eater is stuck. How can I remove the string and how can I avoid this problem in the future? I'm using the pre-cut strings. Thanks
Sounds like one of the loops is over the one being fed out. Does that make sense? I hope so. If one of the windings of string is over another, it makes it hard to unwind. Maybe if you were to put on a glove and really pull on the string, it would start to unwind. Other than that, pull the head and check the string. Good luck...Lee
Sep 20, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Craftsman 4 Cycle Blower/Vac Logo
367 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
