Question about Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television
Vertical lines Vertical blue lines across entire screan equaly spaced about 1 cm apart. I contacted Sony via email and they suggest that it could be the Optical blocks but but the samples they show seem to be more random,where as my problem is more uniform and covers entire screan.
  • Chris Mankowski Mar 03, 2008
    We have vertical lines as well, red, blue, green, no picture, just the lines and no sound. Is our problem the same solution? 2K to fix?
    Sergeant:
  • 308 Answers
IF the area of the OSD (on screen display) displays the same vertical blue lines as the rest of the screen, then it is most likely the optical block assembly at fault. It's part number is A1606006A and should cost close to $2,000. I'm assuming the set is out of warranty. I know many people are hooked on Sonys, but as a technican that works on them, I wouldn't want one in my home.
Posted on Dec 09, 2006
My tv sony kv-xa21m61 display too bright and many horizontal lines. no picture
Vertical retrace lines is the problem. Thin white lines runs across the entire screen, at about an inch apart to each other. Check its video output supply voltage. Reduce the screen voltage to a little bit down and check. If you still wish to know more about this fault, check this site. Pull up older posts there.
Feb 09, 2013 | Sony KV-XA21M61 21" TV
I'm getting 2 grey vertical lines on the entire page of each print. They are spaced 5.5cm from the right hand side and 5 cm from the left.any suggestions on what I should try to clean on my Epson...
Please do the following:-
1. Switch off the printer and remove the toner.
2. Swap with some white cotton waste.
3. Then reinsert the toner and try again.
4. If you are getting the same problem, please replace a new toner
Jul 23, 2011 | Epson ACULASER CX11NF All-In-One Printer
Vega kdf-e55a20: All I see are Vertical colored lines across the entire screen. Could you tell me what the problem is and a potential solve?
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine,found the one you need here http://www.discount-merchant.com/SONY-1-788-156-11-p/1180225.htm?Click=48173 Have a blessed one!
Apr 21, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue Vertical Lines on the screen
It means the optical block is going bad. Contact Sony support. They will sometimes warranty these even after the 1yr warrany has expired. Have your model and serial numbers handy.
May 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
NEC px-42vp4g/s 42in.plasma monitor PDP:np42b3mf01...
I have the same problem with vertical coloured lines on my NEC PX-42VP4G/S. The photo only shows a black background just so it's easier to see the lines in the photo but normally the picture is OK except for the vertical lines which aren't always in the same place.
If anyone can advise on exactly what I need to replace then I would be very grateful.
Regards, Simon.
Apr 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Panasonic PT-50LC14 has evenly spaced vertical blue lines aproximately 1 cm apart
it's not the light engine it'sd the bulb, replace that first, then clean it all out then go from there........
Nov 07, 2008 | Panasonic PT-50LC14 50" Rear Projection...
White lines equally spaced 1" apart.
This is probably caused by the small signal board. It controls and decodes the picture information before it is sent to the display panel. It can be fixed by a quailified technician and if you contact philips (this is who makes magnavox) they will tell you the closest certified technician. Hope this helps.
Mar 29, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Blue vertical lines
Yes...your light engine/optical block is shot... 1500 dollars.
Jan 25, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television Logo
274 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
