Question about Kitchen Appliances - Others
Computer board has 4 blinks
Motor is running without termostate and no gas flow
Video card error.. reseat the card or cards memory.. if that doesn't do it, then you need to replace the card.. also make sure your cmos settings are correct for your video.
Posted on Nov 22, 2008
Nail gun will not fire green light on gas ok after drop on congrete floor
A quick diagnostic check. First remove gas cell press nose against solid surface to dispose of any gas that may be in chamber.
1. Insert battery - LED should flash.
2. Press nose against solid surface - LED should be lit permanently (if still flashing possible fault moulded circuit board or fan motor micro switch lever, if flashing red green high possibility motor fault). Listen to hear fan running if not heard fan blade may have fallen off motor.
3. While still pressed against solid surface press trigger and watch LED - LED should blink off then light again (may flash red on guns newer than 2006) If does not blink fault either Spark unit (controller) or moulded circuit board trigger micro switch. To test for LED blink again release pressure on nose then press again. The blink indicates that a spark has been sent to the spark plug.
4. If 1 to 3 are OK problem most likely gas related or leak in seals. Ensure driver blade not still forward a possible fault of sticking forward after being dropped is nose slightly bent this traps the driver blade when first fired and does not return. (jammed nail gives a similar fault.) If nose is the fault it will require a new sleeve.
The moulded circuit board is normally cheapest then spark unit and sleeve roughly about same price the motor is most expensive.
Hope this has been some help to you.
Jan 13, 2015 | RTO PasLode 900420 Impulse Framing Nailer
Furnace problems
On - OK
1 Blink - Ignition failure. Check Gas flow, gas pressure, gas valve, flame sensor.
2 Blinks - Closed pressure switch. Check pressure switch (stuck in closed position).
3 Blinks - Pressure switch - failre to close. Check venter, pressure switch, vent blockage.
4 Blinks - Open limit switch. Main limit or aux limit are open. (My comment - Means overheating in chamber. Often result of blocked intake air. Bad filter. In my case, plastic wrap had been sucked into the intake. )
6 Blinks - False flame sensed. Check sticking gas valve.
Rapid continuous blinking - Incorrect twinning, incorrect primary polarity. Reverse transformer secondary leads, reverse primary wires.
Closed pressure switch can be from dirty combustion vents, bad chamber pressure - like missing screws, maladjusted gas pressure, failing pressure switch, loose hoses, moisture in the hoses or fan blades The switch need to be closed to ge the unit to work
Jan 23, 2008 | Goodman GMS90703BXA Heater
My car sounds bad. it smells like gas when started. and it runs bad. also the check engine light is blinking
Check engine light is blinking a code, a auto parts store can read codes for you most the time its free, sound like maybe a few diff things, the EGR valve maybe stuck open or shut, or a O2 sensor, or Mass Air Flow Sensor, they do make a mass air flow cleaner thats the only thing you can use on it, the mass air sensor is just after your air filter on the tube that runs to the motor, the O2 sensors are on the pipes before and after the converter. Egr vents the non burnt gas back in your motor to re burn it the pipe coming off the manifold back up to the top of motor should see a egr would have a round diaphram looking thing on it. start with the codes being read at auto zone or O''rillys. i know on that that Rodeo you have to change the PCV valve about every 15,000 mi it vents the air out of the motor, run about $3, worst case senario it jumped time,
Mar 09, 2011 | 1998 Isuzu Rodeo
Control lights ( temperature readings etc ) are consistently blinking on and off, accompanied with a beeping sound
Main control board is over
temperature. Look for blocked condenser air flow or inoperative condenser fan motor.
Refrigerator over 48°F or
freezer over 15°F for 3 hours.
Run diagnostics and test operation of all components.
Both thermistors failed.
Run diagnostics and test thermistors and thermistor leads.
No feedback from evaporator fan
motor. Run diagnostics and test fan motor and/or wiring. The manual is HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 29, 2010 | KitchenAid KSSC48QMS Side by Side...
Won't ignite
Be sure that that PVC vent pipe going outside is not plugged or trapped with water. If the vent pressure switch is not tripping the furnace will not ignite. Also be sure that you don't have a gas leak somewhere causing weak gas flow to furnace.
Dec 21, 2009 | Goodman GMS90703BXA Heater
GMPN 100-4 furnace. Blower motor runs when not calling for heat.
The board is bad. The unit thinks a flame is present, so it tells the blower to come on. Replace the board.
Oct 07, 2009 | Goodman Heating & Cooling
My bmw 325i as heating problem,we replace the water pump,termostate,and radiator,but its still running hot ,any suggestion
my 1990 325i bmw is running hot
it seems to have a lot of air in the cooling system
i replaced the head gasket, water pump and thermostat
how do i get the air out of the system
Sep 16, 2009 | 2001 BMW 325
PTG-74PVN Error Code -0 14 and LED on the controller board flashes 4 blinks every 6 seconds. Fan turns on few seconds after power up then stops. No fan, no spark, and no fire when water flows. Where can I...
code 14 is a big deal shut that thing down! you will burn it up if you keep running it, your over heat wrap on the heat exchanger is too hot. call rheem they can walk you through it
Aug 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
