Question about Whirlpool Duet GHW9150P Front Load Washer
No power what so ever
Went to do wash again and no power what so ever. Checked breakers and outlets definately the machine will not power at all. No lights, sounds or action.
  • 41 Answers
If there is proper voltage at the outlet, then your main control board is probably bad. Joe
Posted on Nov 18, 2008
Testimonial: "Pretty straight forward, but dead on advice :]"
Washing machine lights went out and now water is coming out of the door when opened. checked fuse in plug but still machine wont work
Turn fill water off soon.
Sounds like a major problem.
are you sure you have power at the outlet? check with other
appliance. Be careful water and electricity do not mix!
Check circuit breaker in the main panel. If poped try to reset
If pops again, call electrician.
Owner's manual troubleshooting?
No help, Call MFG customer service number.
Warranty? follow that route.
Feb 27, 2015 | Washing Machines
Washing machine stopped no electrical power at machine
Did you check the circuit breaker? Testtheoutlet with a voltage meter.
Dec 11, 2014 | Washing Machines
No power to Whirlpool awo/d5727. I have checked the fuse and the socket but still have no power.
You say you checked "socket" and the "fuse," did you mean the AC wall outlet (115V) and a fuse or breaker in the main power panel?
Nearly all circuits involving water are protected by a Ground Fault Interrupter that can be servicing several wall outlets (perhaps one not near the washing machine) or can be located as part of a circuit breaker in your main power panel.
The GFI outlets will have one or two push buttons located between the outlets and a combination GFI/overcurrent breaker will also have at least one button where others will have none.
If you find one that is tripped, try resetting it. If it will not reset, unplug the washing machine and try again.
If it now stays on, your machine may have an electrical path causing it to trip and using an unprotected outlet may be unsafe and an indication that the appliance itself may have electrical leakage which could be otherwise dangerous.
The circuit breakers in the main power panel can also fail (they didn't 20 years ago) and we have replaced 3 in a home only 5 years old already so they are not made well anymore.
Jun 22, 2013 | Whirlpool Washing Machines
Where is the master overload breaker on a Fisher Paykel WL26CW1 washing machine?
if it was left switch on at the wall when the power came on again it probably blew the computer board due a current surge
Feb 15, 2018 | Fisher and Paykel WL26CW1 Top Load Washer
Dryer won't heat model fex832cso
This could be any one of several problems, have you checked your power outlet from the breaker box?
Have you checked the breakers?
If you have proper power at the outlet possibly the heat element is gone.
This is a difficult machine on which to change the element, unless you feel really confident I would call a repairman.
good luck
Quentin
Sep 02, 2009 | Frigidaire FEX831CS Top Load Stacked...
No power
No error code like PF Some times unplug for 2 hours.to 6hours for it to reset.
Jan 13, 2009 | LG WM-2277HW Front Load Washer
KENMORE Elite HE 3T
no but there is a control bd it is probably gone
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 60 series washer
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Dec 07, 2007 | Kenmore 24032\24036 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
54 people viewed this question
Dan Webster
Dan Webster
Sal De
