Oven or self cleaning does not work.
SOURCE: self cleaning hotpoint stove
Sometimes in self clean it can burn out the element. Need to check the element with an ohm meter and see if it shows resistance. If it shows open then the element is bad. If it shows resistance then the element is ok. Next see if you are getting 220 volts to the element when in bake mode. If you are not getting 220 volts then the control is bad.
SOURCE: have a magic chef oven, f1 display after self cleaning
Your sugestion does not work.I press CLEAR/OFF and power off several times, the F1 error and beeping is continue every 2 minutes. Any other suggestion?
SOURCE: frigdaire gallery stove
lock mechanism is acting up. happens sometimes. you can get to it from the back and get the thing open to use until you get the part
SOURCE: I have an electric Maytag,digital
Hi Mearill,
Happy to help you!
At this site you may download a manual !
http://www.maytag.com/support/manuals_literature.jsp
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
SOURCE: Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
