Question about Brother MFC-8440 All-In-One Laser Printer
I have a brother mfc-8440
It will not receive or send faxes. it says busy on both ends. what can i do to fix this problem?
I would try to plug a regular phone in the jack to see if you are getting a clear signal/dial tone to the machine, if not, you may need to have the phone company come check it out.
Posted on Dec 18, 2008
Brother 7340 not sending or receiving faxes line busy
sounds like the modem on your printer has failed depending on how old it is most likely it would be cheaper to buy a new printer
Mar 24, 2014 | Brother MFC-7340 All-In-One Laser Printer
I am unable to receive fax. I have tried to fix
try this go into maint. mode * 2 8 6 4 quickly. then hit 9 twice. it resets with out losing any quick dials or tti
Apr 12, 2010 | Brother MFC-8440 All-In-One Laser Printer
Cannot send and receive fax
send or receive... probably have checked this but gotta ask... there are two phone plugs on the back, 'Line' and 'Phone' or 'handset', if you plug the wall into the 'handset' connetor it will hangup on itself when it tries to connect.... Is it dialing then failing, or piking up and then failing?
Peace
Feb 27, 2010 | Brother MFC-8440 All-In-One Laser Printer
Two fax machines on one line, one won't send
Buy a double outlet RJ-11 adapter.
Set the one you use for sending only to MANUAL RECEIVE.
Jun 22, 2009 | Brother MFC 8440 All-In-One Laser Printer
Brother MFC-8440, send fax ok, but no receiving fax
The manual has step by step instructions, I'll include a link for the online version. Section four runs through setting up recieving, if it's on a dedicated line follow the first set of instructions to set up automated answering. If it's a shared line(phone/fax) then continue down to the next section.
Note: for a shared line you may need to contact your line provider for a second number that has a "dedicated ring"
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000219/MFC-210C_UsaEngUsr_B.pdf
Hope this helps FixYa,
Chris
Apr 11, 2009 | Brother MFC 420CN All-In-One InkJet...
Fax Reserved
try unpluging the machine and the replug and let the machine reboot. brother tech
Jan 07, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc-8440 printer/fax
you need to buy the left cover hinge, how ever so that you can use the machine, by the cover there is a sensor button, tape it down and you can still use the adf
Nov 13, 2008 | Brother MFC-8440 All-In-One Laser Printer
Sending and receiving faxes problem
you may have a scanner problem, this should be checked by a locaal brother serice cemter. thanks brother tech
Aug 28, 2008 | Brother MFC-8440 All-In-One Laser Printer
Receiving Faxes
here is the manual try the troubleshooting sectiomn
http://www.retrevo.com/s/brother+8220++fax++manual
good luck
Dec 19, 2007 | Brother MFC-8220 Fax
Brother mfc 8440 "printing" problems
Hi
I recently had this problem - tested fuser and all sensors.
The fix is to reset the memory.
To do this, enter the Maintenance mode. Menu, * 2864
(enter the number quickly)
then type 01 ( zero one ), this will reset all memory including the user settings.
Finally type 99 to exit Maintenance mode.
The printer will restart and the error will be gone. Test out with copy and printer reports
Hoping this fixes your problem
Regards
Lindsay
Nov 15, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
