Question about GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker II makes horrible loud vibration noise
What do you think is wrong?
  • GE Master
  • 5,568 Answers
If the vibration is there with the magnetron off, using only the timer section with power set to 0%, then the cooling fan likely has a bad (sleeve) bearing and needs to be replaced.
If the vibration occurs only when the maggie is running (heating water for example) then the noise is probably from loose laminations in the power transformer due to sloppy manufacturing. You can quiet the beast if you remove the back panel and pour about a teaspoon of epoxy glue across the laminations of the transformer. Normally, when transformers are made, the final step is to dip the whole thing into a type of lacquer that seeps into the laminations and keeps them from resonating at line or some related frequency.
I would expect the problem to be caused by the fan(s), especially if this is a unit that also has range hood function too.
If you are in the US, check Johnstone Supply for a store in your area. They are wholesalers to the service trade but I have never been turned down when buying appliance parts there and the savings can be as high as 60%.
Posted on Nov 18, 2008
JVM2070CH001 GE Microwave. When operating makes a very loud humm noise and does not heat.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 '
May 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Makes loud noise and does not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
Dec 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver II making loud noise and is not heating up food
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
It is making a lound noise and no longer heats
heatman101
dgh
Oct 24, 2009 | GE Profile Spacemaker II PEM31 Microwave...
It made a loud noise and was starting to smoke.
Sounds like the magnitron is shot, I wouldn't attempt to use it anymore. When a magnitron goes bad it actually gets much stronger than the unit is made to handle.
Aug 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Loud noise like tray vibrating. does not cook.
Call GE answer center 1-800-626-2000 ask for tech help, Have your Model # orr your data plate ready.
May 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1800 - turntable issues
check capacitor and motor drive of turn table.
Jan 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
189 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
