Question about HP OfficeJet 6110 All-In-One InkJet Printer
Scanner doesn't initialize on HP 6110 all-in-one
My scanner never completely makes the run from initialization all the way across the glass. It stays in one place for a period of time and then tries to retreat, unsuccessfully grinding against the return bumper as the wheel cogs grind.... How can this be fixed?
    Novelist:
    Scholar:
  • 111 Answers
HP.com doesn't have any answers to this question on their support pages, but it sounds like a mechanical problem. Sounds like you'll need to take it in for service.
Posted on Nov 18, 2008
HP Color Laserjet 4730 MFP scanner not initializing
open the scanner's glass cover ,,, there is a white sensor on the backside of the glass ,,, clean it with a little wet fabric ,,, then change the scanner unit's place to be exactly under the sensor ,,, close the cover ,,, turn on the power ,,, and give me a good rate ,,, :)
Sep 22, 2013 | Office Equipment & Supplies
Hp office jet 6100.
is ther firmware update to it go to www.hp.com suport area download latest drivers ok save to hardrive then remove old ones then install new ones from add remove in control panel ok after new driver hold power in unplug it then plug back in hold that power for 10 sec manaual reset also in the settings
Jan 31, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Initializing scanner
Update the firmware
Restored factory defaults
Initialization of the hard disk.
If it still doesn't work try to clean the scanner head under the glass. Clean the lens with some alcohol but be careful not to scratch the lens.
Mar 12, 2013 | HP LaserJet M5035 MFP Printer
Nois from the scannermecanism under initalizing
The problem is not in stop sensor.It's in scanner section.The scanner is not initialization couse inside in section has a to much ash on mirrors and the scanner lamp.Replace the scanner section or clean up it.
Sep 28, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scanner not reconised
There is 3 reasons for this problem:
1. Logic board ***'y is defective.
2 .Scanner section is defective.
3. Inside in scanner section has a to much ash and need to be clean up.
The last is most unlikely.
Sep 28, 2009 | HP OfficeJet D135 All-In-One InkJet...
Scanner will not initialize properly, can make
If the scanner is not positioned correctly ,indiferent to make a copy to use the ADF or make to the original glass the copy problems is identical.Clean the scanner glass,original glass and the white level band,the erase lamp and check the OPC drum.If the problem persist need to perform the FD and CD adjust for the paper tray.Make someone copies use the A4R tray,and A3,and see the different.
Please answer to help you.You need the position correctly the problem source.
Aug 21, 2009 | Sharp Office Equipment & Supplies
Hp 2115 - clicking noise from carriage, can`t print test page
I have an HP 6110 is always has a grinding noise.No functions work. HP just want me to buy a new machine. They are bad quality 3 in one's. That is for sure.
Jun 28, 2009 | HP OfficeJet 6110 All-In-One InkJet...
After putting it on, does not continue starting.
if the scanner is the problem, scrap printer...sorry!
Feb 26, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Loud ratchet noise
Have you been using ink cartridges other than store bought? Reason I'm asking is that i used a refill kit, and tried those half price refill places, only to find ink was leaking out when not in use & clogged up the ends where the cartridge moves across. take a flashlight & look at the ends of the track that the cartridges slide across on, you may see a build up of ink, that won't allow the cartridge to travel as far as it needs to go to run properly.
Nov 06, 2008 | HP LaserJet 3330 All-In-One Printer
Hp officejet 6110
Assuming that your OS is Vista, here are the steps that may help you resolve your issue.
Oct 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
98 people viewed this question
Ben Johnson
