Question about GE Profile Harmony DPGT750GC Gas Dryer
Unpredictable heat For Master_Tech: I've read your solutions to similar problems, but cannot follow a thread to resolution. I need help. My dryer is operating with heat flow that has become unpredictable over the past 2 weeks. I can get clothes dry, but it takes multiple cycles. Sometimes the heat comes on intermittently over a 30 min cycle; sometimes the heat only comes on for the first min of a cycle and then not again; and finally, sometimes the heat does not come on at all. There is a consistent noise that is new and is hard to describe (maybe plastic on plastic grinding). I've cleaned the ducts from the front of the dryer all the way to the outside of the house, and didn't want to go further without better instruction. Thank you, drakesnest@q.com
  • drakesnest Nov 19, 2008
    I have also posted this under my premium problems, if you can find it there.
    Genius:
  • 1,239 Answers
Hi i think you have problem with thermostat. t hermostats, the dryer temperature control switches, are controlled by the temperature inside the dryer or by the heat of the motor. One or more thermostats on the panel can be adjusted to control the temperature in the dryer. Operating thermostats sometimes stick, causing control problems. These thermostats are usually positioned near the exhaust duct bulkhead or the fan housing of the dryer. Remove the back panel of the dryer to get at them.
Before you make any checks, try tapping the housing of the thermostats lightly with the handle of a screwdriver. This may jar the contacts loose. Temperature control switches are located behind the dryer control panel, and the panel must be removed for switch testing or replacement. Here's how to test and replace the thermostat:
Step 1: To check the control panel thermostat, make sure power is off to the dryer. Test the thermostat with a VOM set to the RX1 scale. Clip one probe of the VOM to each thermostat terminal. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
Step 2: If necessary, replace the thermostat with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 3: To check an operating thermostat, first make absolutely certain that the power to the dryer has been turned off and the dryer is cool. Then disconnect the leads to one side of the thermostat. Test an operating thermostat with a VOM set to the RX1 scale; clip one probe to each terminal of the thermostat. Disconnect the leads to one side of the thermostat so that the meter won't give a false reading. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
thank you .............please rate it
Posted on Nov 30, 2008
My kenmore He4 dryer will not heat.
I have a Maytag 9200 which is similar. There are a few ways to troubleshoot the problem. There is a sensor inside the drum which detects whether the clothes are wet, that sensor can be broken. There are two "fuses" which prevent the dryer from overheating and the third possibility is the heating element is burned out. The sensor/fuses are very inexpensive, as is the heating element. I've found it's less expensive to purchase all, and replace each until the problem is solved. In all, if you are able to do the work yourself, it's going to be less than the cost of a "housecall", or diagnostic fee. If the dryer is older, it's often less expensive, or logical to replace it rather than fix. Ebay and Amazon are great places to purchase the required parts...
Here's a previous solution offered.
http://www.fixya.com/support/t149478-kenmore_he4t_dryer_no_heat
Aug 07, 2012 | Kenmore Dryers
Cold air from my tumle dryer. I've taken off the back of my Creda TCR2 and the elements look fine - not tested the wiring but was wondering where the thermostats were as I've read that you are...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Dryers
I have a Whirlpool electric dryer MOD WED5540S!) SER MU2124790 TYPE DWJR-ELE-2406026-FM54 the dryer runs good, but will not heat. I have checked the air flow and its clear. I've checked all...
Limit thermostat , heres how you check thermostats Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. I strongly recommend that you test your thermostat at room temperature.
Jul 13, 2011 | Whirlpool WED5500S Electric Dryer
Whirlpool duet dryer won't heat. I've figured out that I'm going to have to take off the front panel (not the back like the guys at the shop said) in order to get out the components that are causing this...
If this is a Whirlpool Duet series ELECTRIC dryer, you are correct. Whoever told you the heating components are in the back of this dryer are WRONG. To access your heating circuits you need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the dryer. With the screws removed, the heating circuits are visible on the right hand side under the drum.
Your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
3. Hi-Limit Thermostat
4. Internal Bias Thermostat
5. Thermal Fuse
The heating element will be located inside the heater box. The Hi-limit Thermostat and Thermal Cut-Out (TCO) are the two components that are mounted on the outside of the heater box on the left hand side. The TCO is the component furthest to the back of the dryer. The Hi-Limit Thermostat is located adjacent to the heating element terminals.
The Thermal Fuse and Internal Bias Thermostat are the two components mounted on the blower fan housing directly under the drum. The Thermal Fuse is the smalll plastic component with two wires attached to it, while the Internal Bias thermostat has four wires.
For clarification, you can refer to the following websites to assist you in locating and properly identifying the components of your dryer:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
All these sites should have helpful exploded view parts illustrations.
In addition, each one of these appliances comes with a tech sheet inside the unit to assist you with troubleshooting. To access, you need to remove the top panel of the dryer by locating and removing the three screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off. The tech sheet should be affixed to the internal cabinet wall on the right hand side. Included in the tech sheet are diagnostics procedures, error code explanations, troubleshooting data and wiring diagrams.
If you need assistance on how to troublehshoot a dryer no heat problem, the following links can also give you some guidance:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
The MOST common causes of heat related problems:
1. Blown Thermal Cut-Out.
2. Missing 1/2 your input voltage at the wall receptacle (the dryer will still run with half the voltage missing, but won't heat - double check your source voltage at the receptacle and/or your circuit breakers.
3. Bad power cord, causing 1/2 the input voltage to be missing.
4. Blown heating element.
Read through all the information provided and let me know if you have any questions, or need further assistance. Please include your MODEL NUMBER (located inside the door opening) when posting questions. I hope you find this information helpful.
NOTE: Take all resistance readings with the dryer UNPLUGGED and the component under test isolated (meaning disconnect any wire leads to ensure the accuracy of your readings).
Before assuming you have an INTERNAL problem with your dryer, make sure you are getting the proper voltage from your wall receptacle and terminal block. This can save you from unnecessary disassembly.
Apr 10, 2010 | Dryers
Kenmore Elite HE3 Gas Dryer no heat
Verify the glow bar ignitor is working. Also ohm it to specs before you replace a gas valve coil.
Mar 02, 2009 | Kenmore Dryers
Dryer will not heat
The following link explains how to troubleshoot and dryer "no heat" problem and the common causes:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Read through the link thoroughly, paying particular attention to the section that discusses proper ventilation. Most dryer heat related problems are caused by insufficient air flow which, in turn, causes the dryer to overheat to failure. More commonly, the Thermal Cut-Off (TCO) fails. You will need to check all the components mentioned in order to be sure. If you haven't had your dryer ventilation cleaned or inspected in a while, now would be a good time to do so. Failure to correct any potential existing problems, can cause premature failure of any parts you replace.
If you have questions, or require additional assistance, please let me know, so I can provide you with a viable solution. i hope this helps you.
Jan 22, 2009 | Whirlpool LER5636P Electric Dryer
Dryer will not heat
Jan 22, 2009 | Dryers
Kenmore model 76712 does not blow heat just cold air
Jan 22, 2009 | Kenmore 75962 Gas Dryer
Dryer tumbles won't heat
The problem could be related to one of the following; Not enough power from the house, a bad or broken heating element, a bad thermal fuse, or a brake in the wiring.
Solution
Check the house voltage for 220-240
Do a continuity test on the heating element.
Do OHM reading on thermal fuse.
Check wiring to heating element.
Aug 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer not heating up
Hi Mally Try the following thread - http://www.fixya.com/problems-solutions/t103658,p117053/Bosch-Dryers.aspx It might also be relevant to your problem. Another pointer - - There might be a heat-sensitive fuse in the exhaust section of the dryer. The fuse is designed to turn off the heater element if the exhaust temperature gets too high. If this fuse is defective, it will keep the heater element from getting current. Good luck!
Jun 22, 2006 | Candy CNW156 Front Load Washer / Dryer
GE Profile Harmony DPGT750GC Gas Dryer Logo
143 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
