Question about Empire DV-215 Direct Vent Natural Gas Heater
Black Soot coming from heating vents Powered by Gas
I have Black Soot coming from the heating vents in my apartment.
Why?
My heat is gas heat/forced hot air and the vents are up high, so this light black dusint is covering everything.
I am a renter, so is this my problem or should I notify the Landlord?
How do I rectify the problem?
Is there a safety hazard here?
  • 1 more comment
  • Anonymous Jan 04, 2009
    I hope someone can answer this soon. I am having exactly the same problem and my vents are also high up so everything gets a slight tint of black soot
  • awright912 Jan 09, 2009
    I have black soot coming from my gas heating vent also. My vents are located on the lower wall near the floor and the carpet and everything around the vent is covered with a black dust. I also rent and am wondering who is suppose to take care of this-me or my lanlord?....
  • Laura Homan Kozak
    Laura Homan Kozak Apr 15, 2013
    Are you burning candles..............................
  • 3 Answers
Danger..........You guys both have a problem with incomplete combustion and or a possible heat exchanger breech..carbon monoxide is a very great possibility...don't mess around with it call the fire department and force the landlord to repair it.
Posted on Jan 17, 2009
Why does my pilot light keep going out when heating is on ?
Water heater and house heater are sharing the same vent?
Then vent is bad, and heater is pushing combustion by-product down into the water heater and blowing out pilot.
Call technician immediately to avoid CO poisoning.
Look for black soot on top of water heater... test the vent:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#vent
Read about Carbon Monoxide poisoning: symptoms and first aid
http://waterheatertimer.org/Is-natural-gas-clean-burning.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 08, 2014 | Water Heaters
Why us black soot coming out hayward heater
check gas pressure if incorrect it will soot up and overheat and start to self destruct correct gas then have heater cleaned
Sep 15, 2012 | Hayward Pool & Spa
Black smoke is coming out of the vent why
check gas pressure if too low it will soot up and overheat clean heat exchange after adjusting gas pressure
May 06, 2012 | Raypak 130,000 BTU Natural Gas Pool...
I have a black soot on all my walls through the whole house especially the exterior walls. I believe it is caused by my propane fireplace. Im not sure if it is not ventilating properly or what the problem...
Is a Vented or Vent-free gas fireplace? I really suspect it's Vent-free (ventless) as a vented unit, unless the direct vent is clogged exhaust everything, including 85% of the heat out side.
Here are the things that will cause a Vent-free Gas Fireplace to soot.
  • Not having the fireplace cleaned and serviced, at least annually by a qualified technician.
  • Misplaced logs that impinge the main burner flames.
  • Running a ceiling fan at the wrong speed and in the wrong direction while fireplace is burning.
  • Burning scented candles while burning the fireplace.
  • Low Gas Pressure to the burner.
Here are the solutions to the above listed causes:
  • Have the fireplace cleaned and serviced.
  • Check your Owners Manual concerning the proper placement of each log,
  • Run the ceiling fan Counter Clockwise and at the slowest speed. The fan on the side of the switch should be in the UP position for Winter and Down for Summer.
  • Scented candles soot any way. Add the warm moist heat of the Gas Fireplace and they'll soot 50 times worse. The scent is not natural, it has an alcohol base like after shave & cologne. Stop burning scented candles. It has been proven that they greatly contribute to indoor air pollution.
  • Low gas pressure causes incomplete combustion, which causes the burner to soot. Have it checked by your propane provider.
Based on my 15 years in the hearth and home business and having sold and installed hundreds of these appliances, I am will to bet, it's a cleaning and servicing issue or misplaced logs.
Hope this helps you solve your sooting problem. I woud really like to know how it works out for you.
Please let me know at americanhearthandhome1@yahoo.com
Thanks ... Rich
Feb 16, 2011 | Heating & Cooling
Can a gas heater after years of good use - start emitting carbon dioxide? What about black ashes or soot?
yes yes yes. if you are having black soot build up in the burner compartment you have a problem.the air/fuel mixture has changed. you need to stop using and get the heat exchanger cleaned. this can be done with a long bottle brush coat hanger or such. remove the burners and away you go clean clean clean what a mess.anyway once cleaned reassamble burners and check all gas fittings for leakage with soapy water. after main burner comes on make sure the flames are straight up and not floating around and a nice blue in color some orange is ok but no yellow. normaly a plugged heat exchanger does not mean a bad heat exchanger. watch the flame before the fan comes on and after.the flame should not change. if it start to waver you may have a nother problem and you should not use and call a heating company
Jan 27, 2011 | Dayton Gas Furnace Heater
We own an apartment building that has the old radiator steam heat powered by a gas bolier .. It heats 11 apartments and 3 store fronts. recently 1 of the apartments called and said that they were not...
the steam is not flowing to that radiator because of a blockage in the pipe or radiator, the valve may have an obstruction or the radiator is water bound. Remove the vent and see if the heat improves. If not, you have a blockage in pipe or valve.
Jan 08, 2011 | Heating & Cooling
I have black soot coming out of my gas wall heater and the vent on the roof is all black too. Not sure the age of it, could be up to 50 years.
You need to have a service company come in and service your heater. #1 it needs to be cleand. #2 They need to do a thorough check out of your heating system. I can not stress this enough; your flue and heat exchanger are blocking up and you are at risk for carbon monoxide poisining.
Oct 07, 2010 | Heating & Cooling
Black soot causing whites to be gray
I too have the same problem with my Admiral dryer. Have come to the conclusion that the soot is making all my clothes greyer, but just noticed it with my whites. Took apart my dryer today and first of all found that the outlet below the lint vent was plugged. There is no soot on the outside of the drum or the dryer housing...however there is soot within the metal tube that surrounds the gas burner. Seems the gas is not being burned properly or the plugged lint trap was not letting the burned gases escape??? Laura
Jul 17, 2010 | Maytag PYG2300A Gas Dryer
Clothes dryer produces black soot when drying and leaves clothes darkened
lint build up is on heat element canister. take dryer apart on clean with a good vacumm cleaner. unplug first.
Mar 02, 2010 | Dryers
Empire DV-215 Direct Vent Natural Gas Heater Logo
3,031 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
