Denon D-90 Hi Fi - have lost interconnetion leads
Hi I have a Denon D90 system with seperate tuner amp, cassette, and cd player but in a house move I have lost all the interconnection leads (2) they are 13 pin and 15 pin straight through ribbon cables and plugs.
I am being told these are obsolete -help!!
Notwithstanding the cost of replacement (I am a pensioner) I have really looked after this system from new and it worked fine till we moved it would be criminal to have to scrap it for the sake of two leads.
Please help.
Don
  • 1 more comment
  • donald_higgi Nov 18, 2008
    Please help someone! I can't believe I spent all that money on a Denon system after reading hi fi reviews and it has neen made obsolete by a simple set of leads.
  • jmscwood Dec 12, 2008
    I have the same problem. Have found the part numbers but am always told the cables are obsolete.
  • obriens Dec 26, 2008
    I have the same problem, does anyone know where we can get these leads from?
Gents - not sure where you live, but try these UK links. The D65 was a similar system produced a year or two earlier, if the cable is 15 pin my bet is it is the same cable. Good luck, better look after my cables carefully!
http://www.chsinteractive.co.uk/electrical-components/misc/d90-cable-system-connect-13pin.htm
http://www.chsinteractive.co.uk/electrical-components/misc/d65-cable-system-connect-15p-d.htm
Posted on Feb 12, 2009
Idealistic graphic equaliser model 31-9081
Connect your Denon outputs to the Realistic main inputs.
Connect your Realistic main out to the Rotel tuner in.
Connect your Technics out puts to the Realistic Tape 1 inputs.
Connect your tape 1 out puts to your Rotel cd inputs.
And you should be good to go.
May 02, 2016 | Audio Players & Recorders
How do I hook up spaekers to a Denon TU-550 Receiver and get sound results
what you have is a tuner. it is just a receiver, not one with an amp included. you will need a amp to get this to operate. the tuner is one of the best they made. it is a keeper. i would get a quality amp and use it. this is what was refered to in the past as seperates. purchase seperate tuner, amp, and may an eq.
Jan 31, 2015 | Denon Audio Players & Recorders
Looking for either a code for a universal or a replacement rem for this unit ?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 22, 2014 | Prestige Fearless Leader Box Set Box New...
Following a split from my boyfriend I really need some help in how to connect up my hifi system. It's all technics Tuner Receiver ST 610L Equaliser SH GE70 Amp SU V470 CD Changer SL...
the amp should have an in and out for the cassette player also,, so you would go from the Out on the receiver, to the in on the cassette,, and out of the cassette to the in on the receiver, I don't have nor can I locate that EQ , but basically,, you need to come out of the eq and back the same way you would a Cassette player,,
Jun 14, 2011 | Technics SH-GE70 Home Equalizer
I have the Denon Personal Component System UD-M10, It is a mini size and includes a tuner/amp, 3disk CD changer, and a bi-directional cassette tape player. It was bought about 2001. The CD changer stopped...
Your suspicions about a broken belts are probably exactly right.
Here's what you can do or attempt to do.
Make sure the machine is unplugged.
Remove the cover of the unit. You may be able to manipulate the cd changer mechanism so that you can replace the belts connected to the door mechanisms. Since I am not there and I don't know how your unit is constructed I would advise to be VERY patient and exacting while doing this.
DON'T FORCE ANYTHING. And use good lighting so you can observe how it functions.
I have replaced a lot of belts on various types of CD transports and there is a certain similarity they all have. Inevitably they all have some small belt that rotates a gear mechanism that moves the transport drawer or section in and out.
Of course you can get it serviced by a professional, who will do as I suggest. But if you are confident that you can do it. Have at it.
The only problem I can imagine is locating an electronics supply house in your area.
You may be able to get a full set of belts from Denon.
I hope this helps you.
Best Regards,
Mark
Jan 21, 2011 | Denon Audio Players & Recorders
I´ve forgotten in what order I should connect my old (80´s) separate modul hifi system´s remote cables. It shuts down imadiatly when you try to start it with the remote. If I disconnect the...
I would have thought that it should go from the amp to the tuner,then the tape deck and finally the CD deck.
I'm suspecting that your tuner is faulty and thats whats causing the system to shut down
Aug 27, 2010 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
I am trying to connect a Kenwood CD Player to the Denon amp. I am using normal av cable and connecting the output from the CD player to the ''CD'' jack of the Denon amp (no 2). I am not able to get the...
I agree with this answer:try to connect the CD Player output to the working input on the Denon Amp( say tuner remove it temporarily).
try if it works, then you have a good CD player
if not check if there is volume available on CD player , turn it a little bit higher, using remote control
check if the CD is reading the disk
check also the connector you are using
check if there is a known working CD audio inside the player
if still having problems state the model of your CD player
hope this helps, thanks for using Fixya!
Aug 22, 2009 | Kenwood Audio Players & Recorders
Using remote to play video DVD
You need to bypass your A/V tuner for your video connections (if possible). Plug your video directly into the TV and audio into the tuner. This will also give you a cleaner signal/picture as it does not have to processed by your tuner BEFORE it goes to your tv. Think of it as cutting out the middle man. Your tuner is best left for powering your speaker and not controlling your video despite all of the available connections in the back of it.
I would also get rid of your VHS and cassette players as they are dead technology. Clean up your system and remove the clutter. This will lessen your chance of getting interference. Good luck!!
Oct 01, 2008 | Toshiba 32D46 32" TV
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
Connect 5 piece Sony seperates stereo system
OK, this is pretty easy to do. First connect your leads from the component outputs(i.e., tape, cd, phono, etc) to the recievers corresponding input for the device. Then connect the recievers outputs to your equalizer, if it is a seperate eq. Then the outputs of that to your amplifier, then your speakers to that. Be sure all of your wires are connected with the proper polarity. These instructions may be a little different for your exact setup but basically follow the same order minus any device you dont have.
Feb 03, 2008 | Audio Players & Recorders
1,356 people viewed this question
 Grubhead
Grubhead
