On my 2002 Expedition the following has been happening. Whatever button I push on the climate control system, heat, AC or vent the airflow only comes out the top windsheild defroster section and won't come through the passenger vents or the bottom vents only the top. The system is heating and cooling correctly but the air direction is messed up. What can it be?
SOURCE: 2002 Ford Expedition Climate Control System
you have a loss of vacuum. There is a small diameter black plastic tube from the engine compartment that feeds the climate controls. Check at back of control head, or there is a plastic connector under dash were other color tubes join to operate the other actuators of the system the black tube must have vacuum when engine is running. check under hood the black tube is spliced. separate the tube and check for vacuum The tube enters the firewall near the heater hoses.
