Question about Toshiba 36AF62 36" TV
Toshiba 36AF62 36"
My remote dosent work all the time and iam sure its the tv iam wondering how to fix it
  • 2 more comments
  • johnny noname Dec 09, 2006
    i have tried 3 other universal remotes. i think its the sensor in the tv and iam wondering how to replace it
  • thomasj3 Feb 19, 2008
    I have the same problem using different remotes intermittent response.
  • Anonymous Dec 27, 2008
    Same problem - it doesn't matter which remote I use.
  • Anonymous Apr 02, 2009
    we have had the exact same problem - at first it was intermittent, but now it is constant and no remotes work with the TV - everything must be changed manually. finally we bought new a TV
    Sergeant:
  • 308 Answers
The most likely problem is worn contacts in the remote itself unless the batteries are weak or not making good contact in the remote. You could try a inexpensive programmable remote or order another original Toshiba remote part number 23306263 (I found one listed on www3.sears.com for $28.96 plus shipping). Sometimes remotes get liquid spilled on them and some of it will seep inside and cause problems later like the one you are experiencing.
Posted on Dec 09, 2006
I have an old remote that works for a VCR and I did have it working for the TV but one day someone was playing with buttons and it stopped working. I was wondering how to program my Toshiba vc 260 remote...
Try the following procedure:
1. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
Feb 28, 2011 | Toshiba Vc-260 Remote Control
I want to set the remote to change volume on TV,we can change the channels using the Time Warner remote but cannot change the volume using thesame remote, we have to change the volume on the Toshiba...
I am not familiar with the Time Warner remote, but Tivo remotes require pressing "tv power" and the "Tivo" button at the same time to program them.
Maybe you are pressing one a little ahead of the other.
Oct 18, 2009 | Toshiba 26 26AV502R 26 in. LCD HDTV
Our daughter gave us a Toshiba TV and remote. We plug in the TV and hook up the cable,and try to turn on the TV but nothing happens. We can turn on the TV with the TV button,and it works fine,but we would...
If the remote is the original Toshiba remote, it obviously should work the TV. Have you checked to make sure it has good batteries? Also, if old batteries leaked in it at any time there may be corrosion on the battery contacts keeping it from working. Make sure the metal contacts look shiny, not crusty and corroded.
If the remote still doesn't work there are two possibilities. One is that the remote is just bad. You can get a universal remote, set it for Toshiba and try it. It will at least control power, channel and volume functions. If the universal remote doesn't work, the remote sensor in the TV would be the probable cause. Like any other part, they can sometimes fail.
Apr 11, 2009 | Toshiba Televison & Video
How do I stop the menu loop?
press mute on the remote once and then press and hold mute and menue at same time.
An S' will appear on screen.
now you are in the service menue
press key number 9 on your remote this will perform a self Diagnostics
if this dosent work
press and hold volum on front of tv set then press 9 onthe remote.
power set off then on
youe should be reset.
Jan 13, 2009 | Toshiba 27D46 27" TV
Kidz Remote Toshiba TV Code?
Hchuppa I was wondering if you could display the codes for the tv plz?
Aug 15, 2008 | Televison & Video
Masterplug tvr c4n remote(universal)
Try these simple trick to find out your remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
otherwise, the problem with the Remote sensor or related components of the TV.
Jul 13, 2008 | Philips Magnavox Learning Universal Remote
Audio trouble with my tv
use your remote . manually fine tune your tv.
May 05, 2008 | Toshiba 27A33 27" TV
Coding to the dvd player remote.
not sure you could code it to the dvd remote or not but you can get a replacement remote from here that would work on your tv
http://replacementremotes.com/store/productdetailp.cfm?productid=17889
riz.
Oct 21, 2007 | Sony DVP-NS55P DVD Player
Remote will not control TV (but will control other devices)
Your remote control could still be the problem. Try another Toshiba remote on your TV or try your remote on another Toshiba and see what happens. Don't ever look past the easy repairs.
Mar 16, 2007 | Toshiba 36AF53 36" TV
TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Jan 11, 2006 | Toshiba 43H70 43" Rear Projection...
Toshiba 36AF62 36" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
