My IPAQ 110 Classic Handheld PDA is locked up. It won't accept a hard reset. It also doesn't turn off. I get a blank screen.
    Master:
  • 505 Answers
KEY POINTS TO REMEMBER!
1. Regularly "BACK-UP" your IPAQ 11x using a program like RESCO BACK-UP or SPB BACK-UP.
2. Be sure to always "BACK-UP" to your "SD Card" as your "MAIN MEM" will be wipred during the "CLEAN BOOT" process.
Procedures for "CLEAN BOOT" and "RESTORE."
1. Hold the "Windows Flag", "OK", and "VOICE" buttons down at the same time.
2. While continuing to hold down these buttons, press the "RESET" button for 3-5 seconds.
3. While still holding these buttons, let go the "RESET" button.
4. Finally, let go the "Windows Flag", "OK", and "VOICE" buttons.
5. The iPAQ will go into "CLEAN BOOT" mode and will "START-UP" again.
6. Use your "BACK-UP" program to "RESTORE" your system and program files and settings.
Note: After the "RESTORE" is complete, the IPAQ will automatically "SOFT RESET" again, but when it "STARTS-UP" again, you should be back to normal.
Note: I have encountered a reoccurring fault with MS Voice Command after
a "CLEAN BOOT" and "RESTORING". Just reinstall the MS Voice Command .cab file again.
Thanks
Posted on Nov 18, 2008
    Scholar:
  • 181 Answers
Shut off the device completely for sometime.then ON it and then check out.many a times it gets stuck.
  • 19,396 Answers
Do hard reset again, if this does not work, then the internal disk is faulty and must be replaced.
I post instructions again
How to Hard / Soft Reset the iPAQ 110 / 111 Pocket PC @ Pocket PC ...
  • Ginko
    Ginko Nov 18, 2008
    Another trick, if you are using an SD card, the SD card may be defective, in this case take out the memory card and perform hard reset without the memory card inside.
    If this does not work the device must be taken apart by a technician to test and eventually replace the solid state disk, or the board.
When I connet the Ipaq 2490, teh screen lights up
press & hold power, press & hold calender, press & hold mail, press & hold reset small hole at base of unit, screen will blank, device will now hard reset.
Oct 13, 2009 | HP iPAQ HX2490 Pocket PC
Hp ipaq h6315.can't use the stylus, it's lock.
hi thanks for using fixya!!
Try to make a hard reset of your ipaq, then try all over.
Regards!
Apr 24, 2009 | Computers & Internet
Pda ipaq 1710 not starting up
press the 1st and 4th button on the shortcut menu on the front and press the reset button. This will go through a complete hard reset and deactivate the battery. IT will take your PDA back to factory default mode. It saves you a lot of trouble. GOOD luck. If my explaining it to you didnt help then google "complete reset pda ipaq 1710". :)
Jul 16, 2008 | HP iPAQ RZ1710 Pocket PC
Ipaq 3115 screen
You need to open your PDA and check for a false contact between the connectors of the LCD screen and the main board.
Other cause may be that the LCD screen flat ribbon cable is defective.
Either problem requires to open the PDA to check it.
If you have experience in opening electronic devices then you can try it. Otherwise, I do recommend you to have a experienced technician in checking your PDA.
Best regards,
Apr 25, 2008 | HP iPAQ RX3115 Pocket PC
HP IPAQ 111 Handheld PDA
If you want to "wipe" the PDA heres how:
-you may need two people to do this,
-hold all three buttons together: START, OK, VOICE
-keep holding these buttons and push reset for 3 seconds
-let go the reset
-then let go the 3 buttons
-the Ipaq will go into CLEAN BOOT mode and start over again
Let me know if these worked.
Feb 11, 2008 | LG KU990 Viewty
Locked out of my ipaq
  • press and hold the Calendar and WiFi buttons
  • while holding those buttons down, press and hold the reset button for ~2 seconds
  • When the HP iPAQ screen begins to fade, release the Calendar and WiFi buttons first, then remove the stylus from the reset button.
  • Press reset again.  (Or, plug the device into the AC adpater.)
  • The Pda is now hard reset and restored to defaults stored in the rom memory. the password and everything else should be gone and it should work as if you had just opened it for the first time.
    Jan 16, 2008 | HP iPAQ rx1950 Pocket PC
    Rx1950 freeze on soft reset
    You can do a hard reset by doing the following...
    01) Press and hold down the "Calendar" and "iPAQ Wireless" buttons.
    02) While holding down these buttons, use the stylus to lightly press the "Reset" button/hole on the back of the iPAQ until the screen goes blank.
    03) Release the "Calendar" and "iPAQ Wireless" buttons.
    04) Press the "Reset" button/hole again (so that it resets/powers on.)
    Nov 01, 2007 | HP iPAQ rx1950 Pocket PC
    Dropped PDA
    First of all, you must dissasemble the pda if you have some experience with that. There are some possible problems, one regarding the display connector to the motherboard and the other to the motherboard itself.Probably the display connector isn't atached firmly to the motherboard. There is a worse scenario where you may accidentaly burned some dc convertors on the mainboard when attemting to power on after the pda was dropped. If you can, dissasemble the pda, check the connectors, remove and reconect the back-up battery, and then, just to be shure, perform a hard reset.
    Jan 11, 2007 | HP iPAQ rx1950 Pocket PC
    Password forgotten
    To do a hard reset:
    Press the Power button to turn the Axim unit On.
    Press and hold the Power button down while using the Axim stylus to
    press the Reset button at the same time.
    Release the Power button and the Reset button.
    TheTo clear all data in the memory screen appears.
    Press the Contacts button on the Axim to delete all of the data in the
    memory of the Axim handheld.
    5
    Press the Mailbutton on the Axim to cancel the operation without
    losing data.
    Sep 14, 2005 | Philips Nino 210
    Keeping Programs when updating ROM
    Save the programs file to your Ipaq Storage Memory, which is part of the memory on you PDA that will not lost its files when you do a rom update or hard reset.
    Sep 11, 2005 | HP iPAQ HX4705 Pocket PC
    Computers & Internet Logo
    65 people viewed this question
    David Payne
    David Payne
