Question about Toshiba 2060 Copier
Spanner Icon Shows on the pane
The Copier cannot copy . it shows a spanner icon on the panel and doesn't allow paper to pass.
  • 2 more comments
  • evosapu Nov 18, 2008
    i need the re-setting code
  • graham waddell May 11, 2010
    with spanner on display, press and hold yellow clear key and 8 button down and it will give a 'c' code on the display that tells us where the area of fault is.
  • Cynthia Heimsoth
    Cynthia Heimsoth May 11, 2010
    The spanner icon indicates an issue that normally needs a technician. As Rama said, if you press and 8 at the same time, you should see an error code. Write this error code down, and post it to the site (or mention it to the technician the next time you see him). One question: when was the last time your copier had a preventive maintenance? That's a very common reason for there to be "a spanner in the works"! (Sorry, I had to . . . *blush*)
  • Ramanathan R May 11, 2010
    Hi
    you can see " 8 " press this and also the clear button. both key should be pressed. you can see some error code blinking on the display after two to three seconds. . depending on the error code only i can say you. sorry for this .
  • 76 Answers
Its a maintenance service indicator
Posted on Dec 08, 2008
Dorsoduro service spanner
Hi, Swimboy84 here is how to reset/adjust Engine Service Interval (Wrench icon)
Upon selecting this item, there are two possibilities. If the Wrench icon is active, you will have the opportunity to clear it--proceed directly below. If the Wrench icon is not active, then skip over the next section to "CHANGE ENGINE SERVICE INTERVAL".RESET WRENCH ICON:
1. The display shows CLEAr and no.
2. Press and release SCROLL to alternate between no and yES.
3. Select yES if you wish to reset the wrench icon.
4. Press and hold SCROLL for 4 seconds.
5. WS appears in the display.
6. Release SCROLL.
If you selected no, you will not proceed to the next section; the display will revert to the Service Setup Menu.
CHANGE ENGINE SERVICE INTERVAL:
To get to this point, the Wrench icon must not be active or you just now reset it, as above.
1. The display now shows either CLK or km/h (or Mph).
2. The display now shows the number of hours between Wrench icon reminders. The factory setting is "0044".
3.The 2nd digit of the hours value will be blinking:
In addition, the display also shows the Oil Can icon above the word "OIL", and the "CLK" indicator is present. The presence of "CLK" indicates the interval occurs based on time (this can be altered for the Wrench icon, but not for the Oil Can icon).
For more information about your issue, please visit the websites below. Good luck and have a nice day
DOWNLOAD 2011 Aprilia Dorsoduro 750
Sep 30, 2012 | 2011 Aprilia Dorsoduro 750
I can't change from Japanese to French. Please,show me how . Thank you
To change the language to French;
  • Press TOOLS (The spanner symbol on the bottom right corner of the screen which shows WHERE TO and VIEW MAP) This may take some trial and error if you don't speak Japanese but should be possible)
  • Press SETTINGS (The spanner icon) or LOCALE (the blue icon) on some models that don't have a settings menu)
  • Press LANGUAGE (the lips icon)
This brings you to a screen with 3 items; VOICE, TEXT LANGUAGE and KEYBOARD. Press each one in turn and select Francais. With the VOICE setting you may have to select a name rather than Francais. If so select the name of a person from a French speaking country.
I hope this solves your problem.
Jun 02, 2011 | Garmin nuvi 205W GPS Receiver
New Garmen is in Spanish. Want to change to English. Purchased in Ontario, Ca. at Costco.
  • Press TOOLS (The spanner icon at the bottom right of the screen which shows WHERE TO and VIEW MAP
  • Press SETTINGS (The spanner icon) or LOCALE (The blue icon) on models that don't have a settings icon
  • Press LANGUAGE (The lips icon)
  • This brings you to a screen with 3 items; VOICE, TEXT LANGUAGE and KEYBOARD
  • Press TEXT and change it to AMERICAN ENGLISH
  • Press VOICE and select a voice from an English speaking country
If you don't speak Spanish there may be a bit of trial and error involved but I hope I have given you enough information to solve your problem.
May 22, 2011 | GPS
How do I chang my voice to a man's voice on my 4.3 in garmin gps
  • Press TOOLS (The spanner icon on the screen that shows WHERE TO and VIEW MAP)
  • Press SETTINGS (the spanner symbol) or LOCALE on models that don't have a SETTINGS icon
  • Press VOICE and select a man's voice from an English speaking country. If you select one from a country that doesn't speak English you'll change the language of the voice prompts.
May 13, 2011 | GPS
Can I program my nuvi255wt to drive through the city only. I just want to be able to use the nuvi255wt to drive in the city and I do not want to be directed towards the highway. I do not want to take the...
  • Press TOOLS (The spanner icon in the bottom right corner of the screen which shows WHERE TO and VIEW MAP
  • Press SETTINGS (the spanner icon) or LOCALE on models that don't have a settings icon
  • Press NAVIGATION
  • Press AVOIDANCES and select HIGHWAYS or MOTORWAYS
This should stop the satnav using highways.
May 09, 2011 | Garmin GPS
My garmin 1300 is not in english is there a way to change it . my email bac1@cox.net
  • Press TOOLS (the spanner icon bottom right corner, on the screen that shows VIEW MAP and WHERE TO)
  • Press SETTINGS (The spanner icon) or LOCALE (the blue icon) on models that don't have a settings icon
  • This brings you to a screen with 3 items. VOICE, TEXT LANGUAGE and KEYBOARD
  • Press VOICE and select an English speaking voice to get spoken directions in English
  • Press TEXT LANGUAGE and change it to ENGLISH to get text in English or if you're in the USA change it to American English.
Feb 21, 2011 | Garmin GPS
How do I change the language to english on my nuvi 265T gps
  • Press TOOLS (the spanner icon) on the page which shows WHERE TO and VIEW MAP
  • Press SETTINGS (the spanner icon) or LOCALE (the blue icon) on models that don't have a settings menu
On this screen you'll see 3 items. Voice, Text Language and Keyboard.
Press the VOICE icon and select an English speaking voice. Press TEXT LANGUAGE to change the text to English.
Jan 22, 2011 | Garmin Nuvi 265T GRM0057610DVKIT GPS with...
I am in spanish how do i get english
  1. Press TOOLS (the spanner symbol in the bottom right corner of the screen that shows WHERE TO and VIEW MAP)
  2. Press SETTINGS (the spanner symbol) or LOCALE (the blue symbol) on models that don't have a settings icon
  3. Press LANGUAGE (the lips icon)
  • Press TEXT LANGUAGE and select English
Dec 30, 2010 | Garmin nuvi 205W GPS Receiver
Panasonic DP1820E check printer E02-02 red spanner
yep!
e2-02 means there is a machine error of lifting motor assembly for tray #2.
For sure this time you can't use your tray #2.
you may check it sometimes there's just a paper clogged at the rear of the paper tray. just remove your 2nd tray to see if there is a paper clogged inside. Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
Mar 14, 2010 | Panasonic Workio DP-1820E Copier
150 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
