Question about Dell Inspiron 9400 Notebook
How do I add a dell external monitor to a dell inspiron 9400
Add a external monitor to a dell inspiron 9400
  • saterstrom Apr 19, 2009
    I've attached this secondary monitor successfully in the past, and I used it as a display screen when I gave photo or powerpoint presentations. Suddenly, however, it has changed and the monitor comes on briefly when I power on, then shuts down and indicates no signal. If I select "extend onto this monitor" from the Display menu, it shows my desktop photo but operates as an extension, and I can move my cursor from one to the other, but I still cannot get my desktop icons or presentations onto the monitor. Something changed, but I don't know what. Can ya fixit?
  • Anonymous Mar 22, 2014
    want to add an external monitor using VGA port on B570
  • 461 Answers
Simply use the external video port. It may require an adapter depending on the monitor you plan to use.
Posted on Nov 20, 2008
I accidentally disabled my laptop monitor while trying to use another one. How do i turn it back on? dell latitude 610
You should be able to disconnect the external monitor, and then restart the computer to recover your defualt monitor.
If not see if oyu can move your mouse around enough to see the mouse on the second monitor, from there it depends on which operating system you have. That particular dell has XP...
So you would right click, go to properties, Settings tab, then click on the monitor you want to activate. Look for the check boxes, and click extend my windows desktop onto this monitor, then check the use this device as the primary monitor.
Jul 16, 2011 | Dell Inspiron 9400 Notebook
Own a Dell Inspiron 9400 notebook in 2006. CD burner doesn't work - skips. Can I get an external CD/DVR RW?
In short, yes you can. A USB external drive will set you back about £30.00, however, if you look on ebay, you will probably get a replacement DVDRW for about half the cost
Mar 26, 2011 | Dell Inspiron 9400 Notebook
Have a Dell Inspiron 9400, when running off the battery the LCD is perfect, as soon as I plug into power the screen goes black. Ive tried multiple power supplies and still the same result?????
you may need to change your power settings. it sounds like when you plug it in it goes into a mode thinking there is another monitor hold the FN key and press a key usually f5 that looks like a computer monitory. anyway plug in the pwoer cable, and hold fn and press the key that looks like a computer monitor maybe twice until the monitor comes back on let me know if that works!
Mar 17, 2011 | Dell Inspiron 9400 Notebook
Bios Password dell inspiron 9400
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
May 14, 2010 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 laptop display problem
First power the system on using Fn+Power and see if the diags run and you have video. If you have video in the diagnostics, then I'd suspect the video card as the failure point.
Also connect an external monitor and press Fn + F8 to activate the VGA port If you get video on an external monitor, I'd suspect the LCD as the failure point.
Dec 26, 2009 | Dell Inspiron 9400 Notebook
Need help for my Dell Inspiron 9400 Laptop
Try booting in Safe mode, see if you get video
If you do, reboot in VGA mode, then adjust the refresh rate accordingly
A replacement LCD is about $200 on EBay
Sep 09, 2009 | Computers & Internet
Dell Inspiron 9400 display goes blank after a few minutes
If the issue occurs in the safe mode, then I'm suspecting a failure of the LCD backlight. (It warms up and quits) Also see if video stays on using an external monitor. If it does, then the LCD is most likely failing.
If video goes out on an external monitor as well, then the Video card is failing due to overheating. Make sure all vents are free of dust (Clean with canned compressed air) and the all fans are functional (Run the fan test in diagnostics) If fans check up, then video card is failure point. If fans fail diags, replace affected fan 1st
May 21, 2009 | Dell Inspiron 9400 Notebook
Compatible CD/DVD Writer Models for the Dell Inspiron 9400
Replacements are UC823 and TS-L632 / TS-L632D , TS-L632D/DEKH.
If you had problem with TS-L632 you may need to update the bios.
Replacement here:
UC823 - DVD+RW 8X Optical Drive
Feb 08, 2009 | Dell Inspiron 9400 Notebook
Disabling Multi Monitor
rin disply proteies drag secdary window over primary one ok to set as new defult
Jan 27, 2008 | Dell Inspiron 9400 Notebook
I accidentally disabled my display trying to add a separate monitor on my laptop, please help?
Is it disabled through the bios ??or display settings. If so try going into safe mode, and change it back
Nov 10, 2007 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 Notebook Logo
861 people viewed this question
Alun Cox
