Question about GE 27GT722 27" TV
Can't get channels I just got cable
I just had cable hooked up and I can not change the station on my RCA tv it will only pick up one channel. I have a regular remote withput guide plus on it so Itried to do it from the TV and it will not w what can I do?
    Problem Solver:
  • 9 Answers
Call your cable company! Whoever installed your cable did not set up your remote or give you one of their remotes. Most of the time your tv must be set on channel 3 or 4 and your tv has to be set to cable. Then you can use your remote or the cable company's remote.
Posted on Nov 18, 2008
  • Brenda Webb
    Brenda Webb Dec 30, 2009
    You didn't mention if you are using a box or a direct line in.
I have a hdmi rca tv, unhooked the digital cable box for awhile went to hook it back up and can't get any channels scanning picks up nothing what should I have the setting set to? Hdmi set to cable
If you have a cable box the channels are selected via the cable box remote and the TV is set to an HDMI video input. The specific input is identified where the HDMI cable connects from the box.
Use the video input remote to select the HDMI for the cable box.
Scanning is for identifing the over the air stations that use the coax input noted as antenna (ANT IN) on the back of the set.
Hope this helps?
Mar 13, 2016 | RCA Televison & Video
Got new didital vizio modejE601-C3 today it is hooked up to cable but will not pick up digital channels and will only pick up 1 analol channwl3
if you have a cable hooked to it,then you need to pay for a cable tv subscription,you cannot get free digital channels on it,you shouldnt get any analog channels unless a station hasnt changed to digital,you need a cheap hdtv antenna to receive digital channels over the air.
May 25, 2015 | Vizio Televison & Video
Why can't i pick up channels using a RCA converter box, amplified HDTV antenna on my rca XL 100 analogue TV
If you live a good distance from the TV station you may need a better antenna. Did you do a channel search on the converter box? You'll need the remote for the converter box to change channels, not the TV's remote.
Jul 16, 2014 | RCA Televison & Video
I have a RCA LCD TV model no. RLC3708A and when hooking it up when I took it out of box, I got to
I think you are confusing the channel on the tv and the channel of the cable company that is not something that you can pick up with the scan tv, scan tv is good for picking up local channel meaning air channel that we get with a antenna only not the cable chanel
Jun 24, 2012 | RCA Televison & Video
Need to program channels
This is a LCD tv right?U want to hook up free air or pay cable tv.Go in ur tv menu goto setup,go down to CH.press than pick AIR or CABLE.Than just pick one press scan u will get all free air channels or get all ur pay cable channels
May 26, 2010 | Vizio L37 Television
Dont know how to get cable channels , i just get local channels.
Hello.
It sounds like you need to change a setting before running the auto or channel scan. On the same menu screen that has the option for running the channel scan, you should see a setting that has next to it the word "AIR" or "ANTENNA". If this isn't changed to "CABLE" or "CATV" then the TV will only scan for a limited number of channels because it assumes you have an antenna hooked up to it instead of a cable line. This is the same for all TVs. Anytime someone runs a channel scan on ANY TV and they only pick up a limited number of channels, they need to change the setting I've described. And remember, it will be on the same menu screen that you go to in order to run the channel scan.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
P.S. On some TVs, autoscan is called autoprogram.
Jun 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
Channel selection
What you need to do is take the remote, go into the menu, find channel scan and do a channel scan to find all the available stations available on this system. Make sure the TV set is in the cable mode and not antenna mode or you wont get any stations above channel 13.
Sep 18, 2006 | RCA F27628 27" TV
Open Questions:
GE 27GT722 27" TV Logo
109 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
