Problems Overload Protection Being Invoked - Parasound HCA-2003
I have a Parasound HCA-2003 that I recently purchased used. The area of problem appears to be in the overload protection. The amp has been tested to prove it wasn't the amplifiers themselves - they appear to be OK. It's just these overload circuits that appear to be causing the amplifer from properly working.
I've had it in a shop for over 8 weeks now. I'm frustrated with the level of - or, lack thereof, service so I've requested that they return my amp to me.
  • wayneernst Nov 19, 2008
    I was careful with the connection of the speaker wires. Actually, I used banana plugs for my connections.
    Problem Solver:
  • 6 Answers
You may want to get an Ohm meter and check between the outputs of the amp yourself. 0 ohms means a short somewhere.
You should also check to se when you're hooking the speaker wires in that they're not frayed and touching hot to ground or hot to the amp casing. hope that helps!
Posted on Nov 19, 2008
2003 ford mustang gt anti theft light flashing engine will turn over but will not start
From my experience...
A non PATS coded key SHOULD not turn the STARTER...!
If ANTI-THEFT were invoked... you can attain a not start condition which the Owners Manual says must be cleared by the dealer.
A working PATS key should disable the anti theft... by turning the ignition on... ELSE try your other key.
The SecuriLock [PATS]
passive anti-theft system is not compatible with
non-Ford aftermarket remote start systems. Use of these systems may
result in vehicle starting problems and a loss of security protection.
Owners Guide (post-2002-fmt)
USA English (fus)
OWNERS MANUAL
Ford 2003 Mustang Owner Manual
SHOP MANUAL
Ford 2003 Mustang Workshop Manual
May 17, 2017 | Ford Cars & Trucks
Overload led on 2 channels
Hi Oranzky,
Will the overload LED's light up with the Speakers disconnected?
Nov 11, 2007 | Audio Players & Recorders
What kind of pre amp do i need to operate my parasound HCA-2205A high current power amp
Any preamp should work. A preamp goes into your system between the amp and the other components which plug into it- CD player, FM tuner, Turntable.....etc. It's takes their output signal, processes it as my be Volume, bass, treble... and then send a sufficient signal to the amp to drive the amp to power your speakers. As long as the preamp output is enough for your Amps input any will work as most will be.
Nov 02, 2014 | Audio Players & Recorders
How to fix 2 fuses on the left of the amp? the right side work well.
Fuses only blow if there is an overload somewhere. The most likely cause being a transitor that has shorted out. Easy to spot with a multi-meter on the ohms setting. As it will be liked you have touched the test leads together!
Aug 21, 2012 | Parasound HCA-1000A 2-Channel Amplifier
Amplifier wont turn on. the orange ac light is on but nothing else
Check internal AC fuse. If intact, amplifier may be in protect mode due to fault.
Oct 27, 2011 | Parasound HCA-1000A 2-Channel Amplifier
I have an overload indicator on channel 2. I opened the lid and swapped the channel 2 module with the channel 5 module and the overload light followed the card and showed up on channel 5. Parasound said...
I believe that the output transistors may be bad. Without seeing the actual card, there is no way to tell. If the parts are under warranty, request a replacement board. If I remember correctly, the board is the field replaceable unit (smallest orderable part) anyway. If not, you will need instruction from Parasound about what to do next.
Dan
Sep 03, 2010 | Parasound HCA-2205AT 5-Channel Amplifier
Noisy transformer
Normally, power transformers don't hum loudly unless there is a problem in power supply circuit. If all seems normally operational, the problem may be simply anchor screws that hold transformer to frame may be loose. Try tightening them
Apr 29, 2008 | Parasound HCA-855A 5-Channel Amplifier
257 people viewed this question
 Grubhead
Grubhead
