Question about Toshiba 2060 Copier
The machine shows spanners - Toshiba 2060 Copier
  • Anonymous May 19, 2009
    When I send it will carry the paper and bring it out plain then the symbol of spanner will show, and it will show press info and when I press info it will say call for service 040-........... (I mean it will give me some numbers)
    thanks.
    Lawal Sulaiman
    Usmanu Danfodiyo University, Sokoto-Nigeria
    lawalsulaiman@yahoo.com, lawalsulaiman@udusok.edu.ng
    08064861567
    Problem Solver:
  • 15 Answers
If you press the ' clear ' and ' 8 ' button, at a time both has to be pressed continuously then after two to three seconds you can see some code like "c44", "c43", c26, "c01".
the spanner means it is call for service. you have to call a service engineer if the symbol is blinking even though you may clear some of these with the codes.
These spanner blinks then it is saying that some part has gone bad and it need the replacement , service, reset of the code. any one of the three.
Posted on Nov 19, 2008
Display shows Check Printer E 04 01
an E4-01 is a fuser warm up error...this is usually caused by a bad thermistor but can also be caused by a bad fuser lamp or thermostat
Apr 02, 2014 | Panasonic Workio Dp 8020e
How to raise and lower the pedestals
If you are referring to the adjustable height feet under the machine I would suggest what is called a Headset Spanner for bicycles. The space under the washing machine at its lowest height is very limited, only a few millimetres. The Headset spanner is very thin and can access the adjusting nuts at this height. These spanners are about eight pounds from Halfords and usually have four different nut sizes on each spanner, two at each end. If you can borrow a head spanner so much the better. These spanners are used to tighten the large nuts that hold the handlebars (headset) to the frame of the bike.
Dec 26, 2013 | Washing Machines
How do I remove the spanner not from the shaft on my kenmore 110.9228110
Right hand threaded nut holds tub in place is direct drive, top loading washing machines. To remove the spanner nut you will need a spanner wrench
May 31, 2011 | Kenmore Washing Machines
My fisher and paykel washing machine is not starting a cycle as it is not getting any water. The pipes are turned on and is properly connected. It results in service light(spanner icon) flashing with a...
Hi just read your posting.Now when the machine beeps do any lights light up to indicate an error code?You have mentioned the spanner shows up but do any others light up as the machine is beeping?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel WA37T26G Top Load Washer
SPANNER SIGN ON TOSHIBA E STUDIO
Press the clear and 8 keys at the same time. The service code will appear in the corner of the screen. Report back with the code and we can diagnose from there.
May 12, 2010 | Office Equipment & Supplies
Changing the disc
There are two methods in changing a disk.
somewhere on the machine you will see an arrow showing you
the direction the disk travels when being used, the nut that holds the disk
on always undoes opposite to this.
normal method
unplug grinder, use the 2 spanners supplied with the grinder.
one will look like a normal spanner but thinner, this goes on the nut over the disk.
the other spanner has 2 nodules which fit in the holes on the nut under disk.
whilst holding the disk stationary with the thin spanner, rotate the noduled spanner
in the oposite direction to the disk rotation when being used.
on some models of grinder, a button on top of the grinder must be
pressed in, this stops the rotation of the disk when replacing disk.
This button performs the same function as the flat spanner.
emergency method
If you cannot find or have lost special spanner(s)
pushing the palm of your hand firmly onto the disk surface and rotating
the disk with a sudden **** in the opposite direction to that when being used
may loosen the nut. if the nut is tight hold the disk firmly and use an old
screwdriver in one of the holes and tap nut loose with a hammer on screwdriver.
last resort........if possible break the disk using pliers and remove all pieces.
putting a new disk on is opposite to method that you used to remove one.
Oct 18, 2008 | Makita 9553NB 4" Angle Grinder
Re start problem
What is the Manufacture of the machine and the model number.
Without this information, there is no way to supply any suggestions.
Get back to me with those 2 items.
Thanks
Mac
Mar 28, 2008 | Office Equipment & Supplies
SPANNER SYMBOL ON MESSAGE PANEL
What SC code is the machine giving? Watch the LCD display and the machine will give an SC Code. Let us know this and we may be help to further.
Mar 10, 2008 | Ricoh Aficio 1018 Printer
442 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
