Question about Dishwashers
Does Not Drain ... We Don't even Use it
We bought this house in March '08. The inspection went well, dishwasher worked. (Kenmore Ultra Wash, Model #665.17034400) I usually do my dishes by hand, so I did not notice that the dishwasher was retaining water until about 2 months later when we smelled a "retention pond/horrible odor" smell and had to figure out where it was coming from. I have searched high and low, went through the Owners Manual, and realize that there is a Drain Air Gap and I cannot locate it. I am seeing that it should be next to the faucet, on top of the sink. If that is the case, we don't have one. Could it be located anywhere else? Why is our dishwasher filling up with water when we don't even run it? I do know that when we do dishes a little bit of water goes into the dishwasher; that, I am guessing, is not the norm. But, like I said, we bought this house as is. Luckily this is an issue we can fix, but trying to locate a Drain Air Gap since March has become exhausting. Can somebody help me, please.
I know you're probably not needing this anymore, but for anyone else who has a similar problem...
Your dishwasher is installed wrong. You should never get water back into it from washing dishes in the sink. (of course - unless it is installed wrong) The "drain air gap" that you should see on top of your sink is to prevent water from back-flowing into your dishwasher. Sometimes plumbers put in a "stand pipe" (a pipe that goes way up in your sink cabinet underneath, but just is actually the pipe from the dishwasher and they loop it up higher than the bottom of the sink level in the cabinet. That way if you see water in your sink, most likely you can figure out why it is backed up before it gets higher than the stand pipe and goes into your dishwasher. Since you don't see the air gap device on top of the sink then I'm guessing whoever installed your dishwasher either put in a stand pipe and didn't put it up high enough, or more likely didn't put one in at all and therefore you are getting back-flow into the dishwasher.
dh
Posted on Aug 23, 2009
Kenmore ultra wash dishwasher odor
Is the drain line going over an upper edge before connecting to the sink drain line? Also try to make a rinse with white vinegar.
Jul 06, 2015 | Kenmore Dishwashers
Power went out and now dishwasher will not restart
Try unplugging your dishwasher and waiting 30 seconds, and then plug it back in. See if that helps.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Nov 23, 2011 | Kenmore Dishwashers
I have a Kenmore ultra wash dishwasher model 665.17604 that will not drain. Any suggestions?
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Mar 13, 2011 | Kenmore Dishwashers
I have a Kenmore ultra wash model 665, stock# 15951. When the tub starts to fill the water runs out the drain.
This means there is either an air gap in the drain hose or the drain hose loop is less than 32" high preventing back flow
Sep 18, 2010 | Kenmore 24 in. 15159 Built-in Dishwasher
Wont do anything, not even drain
Try unplugging the unit for 15 minutes then plug it back in. If that fails it sounds like the inline fuse which means you will have to pull out the dishwasher and look near the pump is blown and fuse needs to be replaed
May 26, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher will not turn on
Bruce, It would be great to know the model number of your your Kenmore Ultra wash dishwasher, please look on the right hand side of the door for a model/serial number if possible.
First steps: With no power, please check how the dishwasher gets power. If it is plugged in to an outlet under the sink, please confirm that it is plugged in fully. If that does not fix the problem and if it is plugged in, remove the dishwasher plug and plug in any lamp or small appliance and make sure it turns on.
If no power at the outlet, check the house circuit box for a tripped breaker/blown fuse. Also, check if any of the outlets have GFI (Ground Fault Interupt) circuit protection. Reset that outlet (even if it is not not the same outlet as the dishwasher is plugged in to.
Next steps: If the dishwasher is connected to a live circuit but still does not work, a component in the dishwasher has probably failed and a service call is in order. Or replacement of the dishwasher, depending on its age.
Please accept this solution soon after walking through the steps - or add a comment with an update and I will try to help more.
Mar 28, 2009 | Dishwashers
Will not drain
can you see the check valve? may have something blocking it closed.
Oct 29, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher does not drain
Some Kenmore DW have a check valve attached to the sump that may have a blockage. Remove toe panel, look for a long, white, plastic fitting attached the front, right side of the sump. Remove the drain hose from the valve. Unscrew the valve from the sump and inspect for debris inside the valve.
Jun 14, 2008 | Kenmore Dishwashers
Dishwashers Logo
241 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
