Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Computer says my 500g HD is only 170g.
My computer won't recognize that my HD is 500g. I've tried the disk fix and it won't work. Where do I go to reset my computer to recognize the larger capacity?
Any help is greatly appreciated!
Thanks in advance!
Craig Wilkerson
  • Anonymous Nov 21, 2008
    its a pain
Hi mate, i fixed it this way
right click on my computer > manage > disk management > (box bottom right you should see the rest of the drive space unalocated) click the unalocated drive box > create partition > the rest is history.
hope this helps mate.
Posted on Nov 22, 2008
My LG 500g cell phone won't connect to my computer to transfer music
see in connectivity settings for pc connectivity and change it to what you want.
Oct 19, 2012 | LG 500g TracFone
My LG 500g cell phone won't connect to my computer to transfer pictures.
Completely shut of your LG 500G and remove the back. Take out the battery (and SD card) and then put them back in. Make sure your SD card is seated correctly. Turn your phone back on and connect your data transfer cable to your phone and computer. You should then be able to see your phone on your computer (under My Computer). This has worked for me when I couldn't see my phone on my computer. Hope this helps.
Mar 04, 2012 | LG 500g TracFone
I have a Compaq Presario Desktop Computer SR1150NX. I've added a new WD SATA 1 Terabite HD. but the system does not recognize it. I updated the Bio's but see no way to activate the SATA ports. The...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 11, 2011 | Computers & Internet
My system does not recognise my LG HXD5 500G HARDDISK
how come that your system does not recognize the disk? what does appeared on your system? please let me know something first.
Mar 22, 2011 | OEM Systems WD 25 SERIAL HD 160GB...
Hitachi external hd 500G is not recognized by windows
Are you running Windows 7? If so go to Start,R/Click computer,Click manage,In left pane click Disk management,Look for the new drive near the bottom of the screen.You'll need to format it and give it a drive letter,just left click it it'll move to the top portion of the window,left click in upper window and format.thats it your done,takes about 3 mins tops.
Hope this helped
May 27, 2010 | Hitachi 200GB External USB 2.0 Hard Drive
Light goes on, but is not recognized by computer
Try using another USB cable or try connecting the HD into another computer. If same problem occurred, then the problem is isolated with the HD.
We can only save the HD by reformatting it once it showed up in the Disk Utility or on the desktop. Unfortunately, there's nothing that we could do if the HD is not mounting on the screen of the MacBook and not showing in the Disk Utility.
The only hope that we could think of is once the HD is detected by another computer. Meaning that we could still reformat the HD.
But if not, then you need to get a new one. Good luck!
Nov 22, 2009 | Western Digital WD Passport 250GB Portable...
Computer doesn't recognize my external HD
Test the HD on a different computer, if you get same problem, then the disk can be faulty. Backup your data ASAP, then replace either exernal hard disk enclosure, or the hard disk drive, depending on what is faulty.
If you get no problem on other computers, then the system is causing the problem. In that case try doing a system restore to a recent date before the problem started. If that does not work, then you will have to reinstall the system.
Mar 25, 2009 | Hitachi (DK23BA-20) 20 GB Hard Drive
WD 500g hard drive computer cant read it
i suspect ,if there was no bad sounds on the drive when it was wrking ,that it must be the circut board on back of drive . i ,m in the same boat myself & i,m trying to track down same type of c/board.i do not think this is mechanical bit, electrictal
soretoe
Jul 17, 2008 | Western Digital Caviar SE16 (WD5000AAKS)...
I ve just bought a lacie desktop hard disk 500gb and its not doing anything
New hard drives are "Raw" and have to be formated for any Operating system to recognize it. If the Hard drive is installed I would suggest, if you have a Win98 cd, boot from that, select with cd rom support, at the prompt type in fdisk, Fdisk will display all fixed disks present, select your new HD and configure it, with large disk support, etc.
If you don't have a win98cd download GParted live cd and burn on cd. and boot with that it will display all hard drives and you can select your new HD and format it to fat 32 or ntfs or linux ext partitions/swap files.
Mar 31, 2008 | Computers & Internet
SCSI and IDE HDs, can they work together?
This next solution is viable in win 98, and I don?t see any reason why it shouldn?t work for you too. If you know of anything I?m missing you should consult someone else. The solution is slightly complex, so I hope I can explain it properly: 1. Create a startup disk so you can format and install windows. 2. Set the new HD as master and connect it to Primary IDE. 3. Disconnect the SCSI and remove it. 4. Restart the computer with the disk you created (with the new HD connected). 5. Go to the Bios settings in order to make sure that the computer does recognize the new HD as the primary drive in the first IDE. 6. Now, FDisk the new HD, set the partitions, restart and format it. Install the OS and make sure it is working properly. 7. Insert the SCSI and restart again. 8. At this stage the computer would reboot into the IDE and see the SCSI/ You may have to change something in the OS settings for that, but I don?t know where. Good luck.
Feb 22, 2006 | Adaptec SCSI 29160 POWERDOMAIN MAC KIT...
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
135 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
