WASHING MACHINE NOT TURNING ON
I WASHED CLOTHES AS USUAL WHEN I WENT TO TAKE THEM OUT THE MACHINE WAS OFF. I WAITED A FEW MINUTES INCASE IT WOULD CAME BACK ON BUT NO LUCK. I CHANGED THE FUSE BUT STILL NO LUCK. I DONT KNOW WHAT TO DO NEXT PLEASE HELP IF YOU CAN.
  • Washing Mach... Master
  • 3,463 Answers
Check socket is o/k by trying something else that yoiu know is o/k.
if no joy you need to call an engineer.
Posted on Nov 18, 2008
My washing machine started as usual, but after going to empty the machine it seems to be stuck in the spin cycle. Any ideas? Can the machine be reset?
Have you tried unplugging the power and leaving it unplugged for a few minutes to try and reset itself? If that doesn't help then please provide the model number - should be located on the door somewhere.
Sep 16, 2014 | Maytag Washing Machines
Hoover dyn8164d washing machine, when the last load washed I went to remove the clothes and there was a 'buzzing' coming from the top right area of the machine, I turned it off as usual, and t
Possible that the main power has failed , the power supply of the unit had packed up or there is a serious fault in the controller unit. You need to open the control panel unit to trace this case specially using a multimeter, check for the AC power to the unit and check for the DC to the circuit. If not the panel is a suspect.
Dec 31, 2012 | Hoover Washing Machines
Had ld reading on screen which is nicked or clogged hose repairman came and replaced pump. i washed 1 rug and it was fine, went to wash another load and got the same ld reading as before, called and was...
You should not wash rugs in this machine. The Long Drain is caused by rubber backing from the rugs flaking off and jamming the pressure tubing. The control cannot detect if water is leaving the machine ok. Take that tubing off the control and blow it out. This washer uses a small amount of water which is continually dumped over the clothes. The pump is strong on these washers. The problem is gonna be sediment in the base of the tub clogging that tubing.
Repair photos and manual are HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 03, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Want drain
hi..
sounds like the coupler has stripped on you kenmore ? if so go to sears.com and you can pull up a diagram of the machine and see its placement
Jul 21, 2009 | Kenmore 24032\24036 Top Load Washer
Leaking maytag
it could be the pump but there is a seal in the tube where the transmissin goes through the tub that seal has a common problem of leaking but if it 10 years old i would replace the machine
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My washing machine is leaking water everywhere when rinsing
you are over filling it!!!!!!!!!!!!!!!!!!!! when you use the rinse cycle it just fills the washer up to get all the soap out of the clothes. try just rinsing less clothes then usual. if that is not the problem then on the bottom of your washer is either rusted out or there is a rubber seal that could be over used!
let me know if that helped at all
zac
Apr 20, 2008 | Ariston Technologies AWD121WH
My amanda washing machine
My amana washing machine will not unlock
Mar 21, 2008 | Washing Machines
Washing Machine Door won't open
did that work?? you may have a bad or stuck door lock
Dec 08, 2007 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
