Question about Philips 9P5034C 50" Rear Projection Television
Picture surges It started out when I would turn set on,complete picture would surge in and out(about 50% of screen)Then after a few minutes would stablize full screen.Has gotten worse,until now picture doesnt come on at all,no enitial snap on power up.Have been told I.C.chip(recommended change all 3)or possible Opto-Isolators.Any help on part numbers & locations? Thanks, Jim
  • Jim Fry Dec 09, 2006
    Havent changed the I.C. chips yet,was just told that is what problem is.Picture was just fine before this started.
  • 65 Answers
Forget anything you ever told about this product if you unsolder the convergence ics stk pack and the tv stays on then just the beginning of your problems the vast majority of these tvs have burned fluid in the picture tubes and restoring the elctronics to working is time not well spent the panel for the deflection circuit ( in the middle)? would have to replaced if the tv does not power on
Posted on Dec 09, 2006
Se47fy19. Has sound, but why no picture?
as there are 2 completely different circuits for sound and picture in a tv set it is possible that the picture board has been damaged by the power surge . it could be as simple as a blown fuse for that board or you may have to take it to a repair shop for a proper diagnosis and a quote
Oct 11, 2015 | Seiki Televison & Video
Power surge to Ns 24E200NA14 Insignia tv. Has power, backlight, sound but no picture
Yes it received a massive surge from the transfer. You would need to replace your Insignia or try taking it to a Bestbuy which is a Bestbuy brand to have them fix the unit. Also try putting it on a really good surge protector as well.
Oct 13, 2014 | Insignia Televison & Video
"panasonic pt 50dl54 50 in rear screen does no show a picture
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 13, 2013 | Panasonic PT-50DL54 50" Rear Projection...
TV goes to blank screen after turning it on (about 3 to 4 minutes) but I can still hear it fine. I turn it off and wait a few minutes(5) then turn it back on everything is normal then it goes back to blank...
This tv the LCD inverter board is dead,that why is not sustanning backlight for the LCD screen light to have the picture.Call Polaroid for warrenty repair,this tv under a year old.
Jun 07, 2010 | Polaroid TLA-01511C 15 in. LCD Television
Flat screen tv power surged
Is it just the cable? Do you have a DVD player or game system connected? If so, how do they look? Ofter a momentary power loss can cause cableboxes to loss picture, loss sound, and even cause the picture to be distorted. Try unpluggind the AC power from the cablebox and TV. Wait about 5 minutes and reconnect both. Leave the cablebox alone for about another 5 minute after you reconnect it so that it can fully boot up. Then see if you still have the problem.
Mar 15, 2010 | Olevia LT37HVS 37 in. LCD HDTV
50 inch Sanyo Vizon Plasma TV. Has sound but no picture for last few days. 2 years old
This set has LG insides, it will have failed on either the Y-Sustain PCB or the Z-Sustain PCB.
Quite common.
Repair estimates should be $250 - £350 depending on which has failed.
Stick it on eBay, it will fetch good money faulty.
Sep 06, 2009 | Sanyo Televison & Video
After loud cracking noise no picture on plasma
The most likely the TV has a power supply related problem. A power surge can cause the problem. Last thing you want ot do is void the warranty by opening up the TV. Here's info to get your warranty started:
http://www.lge.com/us/support/repair/support-warranty-claims.jsp
Jun 28, 2009 | LG 50PG6000 50 in. HD-Ready Plasma TV
No stable picture, due to power surge.
You have an impending power supply failure.
I would not leave the set on and unattended. There are mulitple protective measures against bursting into flame but I trust none of them completely.
I just answered a few other complaints similar to yours and pasted some of my response below-
I'm afraid you are right suspecting the power supply; most modern sets use switching power supplies and they often fail when the source AC is screwy.
It might not have been the low-normal-low-normal swings but an unseen, short term surge that killed it.
The cycling is occurring to prevent a potential fire or more severe damage; a component has been whacked and the supply is detecting a fault condition, probably excessive current from some circuit.
I'm afraid you are stuck with a repair, if it was mine, I'd look inside first but some basic instruments are needed and technical background.
I highly recommend to homeowners that they install a 'whole house" surge protector. Especially in lightning prone areas.
With installation, around $200-300 US although an intelligent person can do it, it will require shutting down the home.
The surge protectors range from ~$110-200; most have a long warranty and many include insurance to cover items damaged despite the protection.
Jun 10, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Tv won't turn on
I suggest you unplug the set for about 15 minutes and then plug it in and try again. Sounds like you may have had a power surge/bump in the middle of the night. Althoguh you are using a surge protector, doesn'r mean the devise hooked to it can't lock up during a power surge.( Surge Protectors are an insurance policy only, not a garrentee ). If unplugging the set and waiting doesn't fix it, it will need to have the power supply section of the board repaired. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Protron PLTV-32 Television
Picture problems
Sounds like a problem in the main power regulator circuit, such as a bad capacitor or regulator IC or transisitor. There are no user serviceable parts inside these sets and every thing is soldered into place. I recomend that you call in a trained service tech to assist you with this repair.
Sep 25, 2006 | Proscan PS50670 50" Rear Projection...
Philips 9P5034C 50" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
