Question about Indesit WA 125 Front Load Washer
F08 keeps flashing
Can anybody tell me what fault F08 means and would it be worth my while fixing the problem or buying a new one????? thanks
  • Indesit Master
  • 3,463 Answers
Probably heater relay cannot be actived, you will need an engineer.
Posted on Nov 18, 2008
Bosch WTE86303 Electric Dryer fault F08
I found this elsewhere on the net: "F08 means the door was opened mid cycle."
Nov 03, 2014 | Bosch WTE86300 Electric Dryer
What is F08 error means in Ariston washing Machine
You did not specify model!
F08 - Heater relay cannot be activated
  • Check wiring
  • Check pressure switch and connections
  • Tap relays as they can jam on new boards
  • Check electronic control PCB
  • Check heating element
Dado
Jun 21, 2014 | Ariston Technologies Washing Machines
Fault f08
The heating element is gone open circuit. Replace element.
Error F08 means that the heater relay cannot be activated. Check connections on:
- pressure switch.
- heater element.
- control module.
If you still cannot get it to work, then you are probably going to have to call an technician service.
Hope this helps.
May 25, 2011 | Washing Machines
My hotpoint WD640 is flashing F08 error message. What do I need to do to fix it? Thanks N
For most Hotpoint (and other named) models 'F08' means 'heater relay (possibly) stuck'. 'Check power supply connections to the heater, wiring and module (i.e. PCB) connections' (apparently poor PCB connections are often the cause)
So- if you are not electrically confident and competent yourself, which you may be, you need to employ the skills of a partner, friend or service engineer ;-0)
Sorry we cannot be of more help!
Good luck, John C
Mar 14, 2011 | Washing Machines
Hi I have a hotpoint wf630 washing machine and it keeps flashing error codes f08. Could you tell me what this codes means. many thanks, Stuart
Most Hotpoint, Ariston and Indesit (who make the other two) use similar fault codes. Although I cannot confirm it on your particular machine, f08 means there is a problem with the heater/its relay/its control. Often a cure is to re-seat the cables/wiring to and from these items.
REMOVE POWER BEFORE ATTEMPTING ANYTHING OF COURSE.
Good luck,
John C
Mar 09, 2011 | Washing Machines
What does "f08" mean on
The error F08 indicates that the heater relay is stuck. This could be a fault with either the pressure switch, heater or the module connections.
Think you need to book a service call from engineer.
Feb 06, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima WT965A fault code F08 what do i need to do to fix it please. wachine is full of water and i cant select any cycle to empty it.
To empty the washer, remove the drain hose from the outlet, and lay it down to floor level, this will let the water run out into a bucket or similar.
Code F08 is indicating means heater relay cann ot be activated.
Check all connectios to and from the pressure switch, the module, and the heater.
Hope this helps.
Jan 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
Fault code '' F08'' what does this mean
The fault code F08 means that the heater relay cannot be activated. I would you check heater, and the thermostat for a fault. Replace them if required.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 05, 2009 | Kenmore Elite 45986 Front Load Washer
Error F08 on a fagor washing machine FU-6146
F08 on my FAGOR means a new motor is required we've had 3 failed motors in the past 2 years , total rubbish machine , would never buy FAGOR again . Mr M Freeman.
Jul 14, 2009 | Washing Machines
Indesit WA 125 Front Load Washer Logo
2,182 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
