Question about GE Spectra JGBP35 Gas Kitchen Range
GE LR44 model JGBP34 doesn't sense Bake/Broil/Clean buttons
If I push any of the Bake/Broil/Clean buttons on the keypad there's no response. Needless to say, you can't set a temperature and none of those functions work. Cook time and stop time buttons work and you can set the times, but of course no cooking is done, and the unit starts beeping a few seconds after those times are set. Clock and timer functions work, and increase/decrease arrows work for those functions. Stovetop burners work fine.
(another) Kim
  • Anonymous Mar 26, 2014
    Problem whith the temperature. It not working un less it turn on broil
    Problem Solver:
  • 7 Answers
Circuit board repair is your only alternative to shelling out $200 for a replacement. Take the control box out of the stove and remove the top board, which is just relays and interface connectors to the AC power and bake/broil burners. Under this is a complex circuit board, also to be removed. You have to unbend tabs to do these removals, and make sure that all the inter-board connector pins are properly mated when reassembling and rebending tabs. On the underside of the circuit board I found corroded spots under each of the 3 electrolytic capacitors on the board. Very suspicious. I replaced the caps and had to patch two traces on the board with jumpers, and this fixed the problem! You may as well try this (or have a nerdly pal try it) since you have nothing to lose and possibly $200 to save.
Posted on Nov 20, 2008
Why does only broil come on when i push the bake button?
Bake and broil elements can be tested with an ohm meter for continuity. There is a relay in control / clock for both bake and broil elements. If elements test good, then those relays need to be tested for voltage.
Sep 16, 2017 | Ovens
Oven not heating- both baking and broil elements
It may be possible that the electronic control is bad. On some models there are three relays one for the bake and one for the broil and one for the common. This one goes out and the bake and broil will not work. The control is fairly expensive you may want to have a tech check it out.
Nov 10, 2013 | GE JTP15 Electric Single Oven
Ge wall oven will not heat up on bake,boil or clean cycle
GE JKP86BF3BB COMBO MICRO/ELECT OVEN
NO HEAT ON BROIL OR BAKE ELEMENTS
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
Mar 16, 2009 | GE JTP15 Electric Single Oven
Bake mode will not work
Is the bake igniter working ? There are two igniters one for bake and one for broil My guess is that the bake igniter is bad and only the broil igniter is working. part #WB2X9154.
Jan 10, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Bake button doesn't work even after ignitor replaced
While unlikely, the ignitor in theory could have damaged the ERC (main oven control) it is more likely you have a bad keypad. Try pressing and holding bake and broil pads at the same time for 5 seconds and see if the display shows SF (will look like 5F). If it does, press the start button and try again bake again
Dec 02, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
"F-1" flashing code
My tech. data sheet for a GE type LR44, model JGBP34 says F0 and F1 mean a failed transistor on the electronic control board. If that's your problem, you're probably out $100-200 for the replacement part.
(another) Kim
Aug 08, 2008 | GE Spectra JGBP35 Gas Kitchen Range
GE Profile JGB97 Self Cleaning Oven Controls won't work
It sounds like the controls have been placed into a lockout mode. If your model is a JGBP79 do the following:
1) Press the BAKE and BROIL HI/LO pads at the same time for 3 seconds until the
display shows SF.
2) Press the SELF CLEAN pad. The display will show LOC OFF.
Now here is where the directions are kind of confusing, I will give it as they say it:
3) Press the SELF CLEAN pad again. The display will show LOC.
4) Press the START pad to activate the control lockout feature and leave
the control set in this special features mode.
Seems to me if its locked already, you would just do steps 1 and 2. And if you wish to lock it do steps 1 thru 4.
Jan 26, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Digital Control (for oven temp and clock adjustment) not working
Puzzeled, usually when there is a stuck or shorted keypad there will be an error code. First let's see if we can tell if we are in Centigrade or Ferenhiet. Press the bake and broil button together for 2 or 3 seconds. SF should appear in the display. Press the broil pad again and C or F will be displayed. Toggle to F and press start. See if that was the problem. If not try to increase the speed of the + and - keypads. Press bake and broil together for 2 seconds until SF displays. Press the + keypad increase the speed of the control. It should toggle from 1 to 5, 5 being the fastest. Press start and see if that works. If niether works..then have someone remove the keypad ribbon cable from the control board and clean the ends with an eraser. See if that solves the issue...Catriver..post back and let me know.
May 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra JGBP35 Gas Kitchen Range Logo
197 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
