Question about IOGear COMBO ION GHD135C160 160 GB Hard Drive
Firewire interface fails sporadically
I have been using this drive for a while now over the USB interface without any problems. However, the two times that I've tried to use the Firewire port, it has failed miserably. In both cases, drive has appeared to work fine for a while (maybe 10-15 minutes), but that the interface would just die unexpectedly at some point. This most recent time, the power appeared to cut out on the drive (i.e. the blue light went out) when the interface went dead. I confirmed that the drive was still getting power by checking the LED on the power adapter, so it appears that the drive just shut itself down for some reason. The first time this happened, a couple years ago when I originally bought the drive, I assumed it was a problem with the Adaptec Firewire board that I had just installed, since I didn't have any other Firewire devices to use to test it. Now that the same problem has occurred on two separate machines, I have to believe that it's a problem with the Firewire port on the drive itself. Has anyone else experienced problems like this? It's very frustrating since it means that I can't use the Firewire port at all for fear of losing data. Thanks, Paul
2 Suggested Answers
  • 70 Answers
SOURCE: IOGEAR COMBO not recognised
Is your hard drive detected by the computer? Did you try changing the USB ports? You can check if the drive is detected by Right click on taskbar > properties > startmenu > customize > advanced > scroll down completely and select system administration tools "Display on the all programs menu" > ok. Click on start > all programs > administrative tools > computer management > double click on storage. click on disk management(local) here you should see your drive. If you dont then the drive is probably not detected. If you see, you can just re-format it from here and it will appear in your my computer.
Posted on Dec 24, 2007
Hdd i/o firewire port won't work when connected with my hp probook laptop. do i have to install some drivers or firmware. when i use just hdd, things are just fine, evrything works fine. i need...
You cannot use the drive without external power, specially with the 4-pin firewire: there are some USB models that allow it (usually 2,5" drives), but you need 2 USB outlet oth the PC (one for the data and power, the second for power supply). About the compatibility you shouldn't have problems.
Aug 07, 2011 | Focus Enhancement FSHDD-1 (ASYF070701) 40...
Hi, i want to no, what is 1394 on motherboard and if the usb cable in the front write 1394, i install it like a regular usb cable?????
It is Firewire port/ Interface. The IEEE 1394 interface is a serial bus interface standard for high-speed communications and real-time data transfer, frequently used by personal computers, as well as in digital audio, digital video applications etc. The interface is also known by the brand names of FireWire (Apple), i.LINK (Sony), and Lynx (Texas Instruments). This is not as widely used.It works just like USB but it is meant for connecting Firewire capable devices. If you have any firewire capable device (like video camera)and firewire cable, you can connect the device to your PC and use it for high speed data transfer.
Hope it helps! Good Luck!
CreativeTECH
Apr 18, 2011 | Foxconn 661MX Motherboard (FOX661MXMB)
MY Seagate Free Agent Pro 750GB External Hard drive is no longer registering on my computer. It's only about 1/3 full and I need to recover the data. The software on my computer does not detect a free...
Sounds like the enclosure has a problem. If this is one of those free agent go flex drives with the removable USB to Sata interface you might try getting another drive like it and borrow the interface from that drive when you need to use this one. That's something I have to do now because one of my interfaces died also.
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
Jun 30, 2017 | Seagate ST307504FPA1E3-RK FreeAgent Pro...
I have windows server 2003 professional edition installated.Cannot access seagate external hadrdrive
If you were able to access it before and the drive powers up when you turn it on, the most likely cause is that the USB connector is broken. If your drive came with a Firewire adapter and you have a firewire connector for your computer. Then swap the usb with firewire interface and confirm that the drive is still working. If it works then the USB adapter is broken. The second alternative is to try the eSATA connector if you have an eSata interface on your computer get a cable and check that the drive works. Third way to check is to puchase an eSata adapter the allows you to plug the eSata to the usb port on the computer. Forth is to try and open the usb module and solder the usb connector back on. Fifth is to try tearing open the drive case (difficult but not impossible) and put the drive into a different case (purchase at Best Buy, Staples, online, etc)
Sep 15, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a LaCie Rugged Drive, with multiple interfaces (USB, Firewire 400/800). Firewire interface works fine. When I plug the drive in the USB port, it won't mount (MacBook Pro OS X), and a faint beeping...
the problem is that your lacie drive operates using the NTFS (New Technology File System) under USB which is the standard file system of Windows. Apple mac is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac if you wish to use it via the USB connection.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Jul 31, 2010 | LaCie (300951U) 500 GB Hard Drive
Drive will not mount; simply not recognised on a PC and on Mac, fails to reformat. Have tried connecting via USB and Firewire. Same problem. Is this the end for this drive?
It might be the drive itself, or the problem might be on the interface circuit board in the case. It's possible (not easy, but possible) to open the case and take the drive out. There are hidden snap tabs holding the case together and it's hard to open without damage, but if you don't care you can simply pry the thing open.
Once the drive is out, install it as a secondary drive in another computer. If the drive is OK you'll be able to read it and access your data. Otherwise you'll know the drive itself is bad.
Apr 10, 2010 | Western Digital 500GB My Book World...
My Apple G5 and WD Passport 500Gb don't mount
You need to determine whether the problem is at the disk interface or at the computer interface. Will the drive mount on ANOTHER machine using FireWire? Will your computer mount ANOTHER device using FireWire? This will tell you which machine is at fault. It's not unheard of for the FireWire channels in a Mac to just go bad, and (unless it is a Mac Pro) it typically requires a logic board replacement to address. For a G5, this would not be cost-effective. On the other hand, as I say, it could just be a bad interface in the drive itself. It's up to you to determine which it is.
Sep 20, 2009 | Apple iMac G5 Desktop
Problem when connected to the e-sata port of two dif. computers
I think we a re talking about SMART technology, that is disk is telling you that something's wrong. If you have a guarantee, return it to reseller and ask for another one.
Jan 15, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I recently purchased an external hard drive, and how do connect it to my computer.
External Hard Drive is mostly of the USB interfacing type. If urs one is the same, then it is just as simple as plugging in a pen drive in the USB port. If it has external power supplies then u can easily figure out how to connect. There are two parts in the power supply (if external power supply cable is provided), 3-pin main power supply connector and other is the adapter which goes to the external hard drive.plug in the other end of the adapter into the hard drive (there is a hole in it). connect the main power cable to the adapter extension. now for the usb Hard Drive, connect the USB cable to the USB port of the computer. Switch on the power supply to the Hard drive and u r ready to use ur brand new External Hard Drive. If it is a Firewire interfacing one then u may need to open the CPU box, and then connect the firewire connector on to the motherboard firewire port. It is easy to identify, it is a red colored port/connector.
Oct 11, 2008 | Western Digital 500GB My Book World...
Saying disk not readable
you could try a repartition / reformat, if the drive is detected at all, or you could try running scandisk/disktools, to try and recover / repair the TOC/ FAT
Apr 11, 2007 | Ultra 1 Bay USB 2.0 External Drive Case
IOGear COMBO ION GHD135C160 160 GB Hard Drive Logo
55 people viewed this question
Top IOGear Computers & Internet Experts
Damen Wong
Damen Wong
Jose Velazquez
Jose Velazquez
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
