Acer at3201wt tv the colours on the televison are all off and the picture has a "cartoon" effect to it. Tried to reset all parameters did not fix
  • Anonymous Apr 06, 2009
    Same problem, donno what to do !
    Genius:
  • 2,920 Answers
You need to have it converged by a professional
Posted on Nov 18, 2008
What has caused the characters on the TV to resemble cartoons? Have tried to adjust the setting but nothing works. Is it fixable?
Hi There
Would you be able to post a picture of this on the site? I am not sure what cartoon pictures mean, but sure I can help if you take a picture of this and post it.
Good Luck!
Aug 29, 2014 | Sony Bravia KDL-40Z4100 40 in. LCD TV
My sister wanted to change our Toshiba TV to her favorite cartoon, Tom and Jerry. But after she entered the channel number, the TV went black and white. I've tried to get the TV working again but then I...
use the remote to punch in Channel 4. Or use the menu to do a channel scan. unless you were on a video input. If that is possible, try pressing hte input button until you see a picture.
Also, Tom and Jerry is the best cartoon ever. Tell your sister she is awesome for me.
Jan 10, 2018 | Toshiba Televison & Video
The picture has a "cartoon" like colour apearance to it
The video output section to your TV is faulty. This section board can be located at the neck of the picture tube, directly plugged on to it. If any loose solder terminals, especially to the red output section, in this case; can poise this problem.
Nov 24, 2012 | Televison & Video
Color setting for Sony XBR Trinitron 36" any settings
Hello
I thinks that you need to set its colour and other parameters, and posted this problem. If so there is adjustment at the first "Menu" option itself.
Press "Menu" button on your TVs remote control. You will see "Video" function as first selection on the screen. Use "Prog Up or Prog Down" keys to select and hilight the desired parameter. Use "Vol up or Vol down" keys to change it as your taste. That is all.
Normally the "Contrast should be more that 55% to 60% of its total value to get a clear and vivid picture. Colour and brightness are according your individual taste. Ok
If you wants to reset your TV to factory settings,
Turn on the TV.
Hold down "Reset" button on your remote handset and keep it pressed.
Press and release the power button on your TV front panel. the TV will turn itself off.
Release the "Reset key". Ok
Oct 26, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a LG tv and now i can´t get any colour???
Do a hard reset, there is a setting in the menu to put the set in monochrome mode, i think that is what has happened
Jan 07, 2018 | LG 37LE2R 37 in. LCD TV
Bush RFT TV
The picture tube of the tv has 3 color in CRT Red, Green, Blue. The red cathodeof tv set has no function, its either the resistor become higt resistance, that why u need a repairman to replace it.
Apr 10, 2008 | Televison & Video
My picture looks like cartoon characters from new commercials
I had recently noticed the same thing happening with mine.Then the left half of the screen turned black and has various red, green, and blue vertical lines. The right half of the screen shows has the picture just fine. It's exactly right down the middle of the screen.
Nov 18, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
Oritron no picture
Phase Alternating Line (PAL) is a colour encoding system for analogue television used in broadcasttelevision systems in most countries broadcasting at 625-line / 50 field (25 frame) per second (576i)
NTSC is the video system or standard used in North America and most of South America. In NTSC, 30 frames are transmitted each second. Each frame is made up of 525 individual scan lines.
You might try disconnecting all power from the system. unplug it.
disconnect the TV. Power back up. Maybe it will reset to factory settings. See if your TV will have a switch to NTSC.
Oct 04, 2017 | Oritron Televison & Video
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
