Question about Oster 3072 20-Cup Rice Cooker
Digital oster 20 cup capacity rice cooker wont turn on
I turned on the rice cooker, it cooked the rice until it was almost done, then the digital panel turned off. Now, I can't turn it on. The on/off button doesn't trigger the digital panel to turn on. Usually a double zero will appear showing that it is ready to start cooking. I've checked the power sorce and everything is connected.
  • 1 more comment
  • femisco_99 Dec 14, 2008
    The rice cooker panel light turned off during cooking even though there was some water in the unit. For some reason, the unit has not been operative since this happened.
  • Anonymous Jan 18, 2009
    the problem is that the thermal fuse is open. It remained open after the last operation therefore is defective. This then will not provide the hot 120vac to the unit. This is inline with the voltage that will source power to your front panel. the thermal fuse is a microtemp fuse STFAQF 64a01.
    Hope this helps.
  • Anonymous Feb 06, 2009
    I only used the rice cooker once. Now I plug it in and nothing happens no lights no coooking, it is like it is not turning on. I know I have power from the wall. What can I do?
    Problem Solver:
  • 9 Answers
Rice cookers will only cook if you have enough water in it. If all the water has cooked out, then the cooker will turn off. Remember when you put your rice in the cooker, make sure you level it off. Then add twice as much water so that it will over cover the rice.
Posted on Nov 18, 2008
How to used to cook white rice?
Hi
my rule for cooking rice is 1 part rice: 2 parts water big pinch of salt. This can we'll be done in the micro. Set it for 10 minutes, open the door and wander how the rice is doing. Take a fork. Put into the rice and find out how cooked it is. You will probably need another 10-15 minutes. Depends on the micro.
With a rice cooker it is much more accurate. Look inside the inner pot ,on the one side there could be numbers for cups of rice and on the other side for cups of water.
I hope you can find your answer here Food Steamers Rice Cookers Oster
all the best
kolbrun
May 03, 2016 | Oster Kitchen Appliances - Others
Need directions on how make rice on my oster rice cooker
There are many types of rice. Follow specific directions for variety used.
2. Accurately measure rice and water then combine in rice bowl.
Pour specified amount of water in water reservoir. Cover and steam.
3. For softer rice, increase by 1 – 2 tablespoons the water mixed with rice
by the specified amount of water on the chart. For firmer rice decrease
water mixed with rice by the same amount.
4. Check doneness and consistency of rice at minimum time specified
for each type, stirring rice at the same time.
5. When checking/stirring rice, be careful not to drip the condensate into the
rice bowl which would reduce the quality and flavor of the steamed rice.
6. Use only clean water in water reservoir
7. Rice may be seasoned with salt, pepper or butter after steaming.
Combined In Rice Bowl Approx. Time
Type of Rice Rice Amount Water
(Minutes)
Brown
Regular 1/2 cup 1 cup 42 – 45
Parboiled 1 cup 1-1/2 cups 45 – 50
Long Grain and Wild Rice Mix
Regular (6 oz. pkg.) Mix 1-1/2 cups 50 – 55
Quick Cooking (6-1/2 oz. pkg.) Mix 1-3/4 cups 18 – 20
Instant 1 cup 1-1/2 cups 15 – 18
White
Regular 1 cup 1-1/2 cups 45 – 50
Long Grain 1 cup 1-2/3 cups 50 – 55
Oct 25, 2009 | Oster 5712 10-Cup Rice Cooker
I am looking for a new pan for oster 4707 10 cup rice cooke
You can probably get one from the Oster website or do a Google search of the part and see if that brings up a dealer that carries one.
May 28, 2009 | Oster 4707 10-Cup Rice Cooker
Cooking PLAIN rice
Here is my recipe - enjoy and please rate my answer as a fixya!
Raw Rice - 2 Cups (400 gms.)
Water - 6 Cups.
(The ratio of rice to water is 1:3)
PROCEDURE
Step 1:First wash the rice in water thoroughly and drain the water.
Step 2:Take a vessel ,the capacity of which is double the quantity of raw rice that is to be taken.
Step 3:Now,add the washed rice into this vessel and pour 6 cups of water into it .
Step 4:Now, place this vessel containing rice with water in a pressure cooker and add the pressure weight on the cooker top.
Step 5:Heat the pressure cooker for 20 minutes only.
Rice has been cooked.
NOTE:
*After heating the cooker for 20 minutes,donot open the cooker immediately.Wait for 15 minutes and then open ,otherwise the cooker would burst open.
Feb 16, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Some one gave me a new rice cooker but the instruction manual was missing how to use it. its a sunbeam-oster model 4713/0
you add 2cups medium grain rice and three cups water ( yields about 6 cups cooked rice) you should have a lever Cook/ done push lever down and it will come back up when the rice if done, allow about 4-5 min to let it finish steaming
Jan 27, 2009 | Rival RC160 16-Cup Rice Cooker
Won't turn on after 1 time use
Mine did the same thing.. They said to return unit for replacement
Jan 04, 2009 | Oster 3072 20-Cup Rice Cooker
Rice cooker unit does not turn on after ading rice and water.
This unit has had many recalls. Oster got a bad unit and is telling customers to return for free replacement. The 3072 model has a bad computer board. Take it back for free replacement.
Dec 14, 2008 | Oster 3072 20-Cup Rice Cooker
Oster 4704 rice cooker
you dont need manual... it a rice cooker.. 6 cups of rice = 6 cups water... no need for manual. press cook then the rice cooker will do the rest
Sep 20, 2007 | Oster 4704 7-Cup Rice Cooker
Rice burning at bottom of cooker
Your cooker, along with mine, cooks very hot. If it is new then you can take it back, but if you want to cook with it then you need to stir the rice often. About every 5 minutes should be good. As soon as it is done you need to remove it from the cooker. Let's see how that works.
Aug 30, 2007 | Oster 4724 Rice Cooker
Oster 3072 20-Cup Rice Cooker Logo
856 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
