Question about RCA P56923BL 56" Rear Projection Television
Where is the convergence control?
I have a 1999 RCA rear projection TV, local repairman recommended adjusting convergence but I am unable to locate in menu.
Unplug the set wait five minutes then try again go to menu where closed caption is............
Posted on Dec 03, 2007
SOURCE:
I don't have my original remote for my rca rear projection tv can i still adjust my convergence
mine is in the set-up menu accessed from the buttons on the front of the tv
Jan 19, 2013 | RCA Televison & Video
Have three different color images (red,blue,green)
It is symptom of convergence output ICs failure, replace convergence output ICs located on D board to fix this problem.
Call local tv repairman to replace defective ICs if you do not have prior experience of electronics stuff repair.
Thanks.
Dec 15, 2010 | Sony KP-51WS500 51" Rear Projection...
Have a projection tv...RCA model 61830BL. Had
Hi the green cross it cant move that the reference for red and blue adjustement ;just try to put the red and blue cross over the green pattern then quit/
if that doesnt work you probly have the stk-xxx ic
who control the color alignment ,are blow/
you will have to replaced and make the convergence
check if you have an auto adjustement for that most projection tv have one...
hope that help..
Mar 28, 2010 | RCA P61830BL 61" Rear Projection...
I WANT TO CONVERGE MY RCA REAR PROJECTION TV. HOW?
Here is a link to the detailed instructions for the RCA ITC222 convergence adjustment proceedure CD with detailed photos.
http://servicemanuals.vstore.ca/product_info.php/pName/itc222-convergence-and-geometry-adjustment-cd/cName/rca
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
Convergence Issue on Toshiba TN50X81 - Service Manual & Parts Source?
Replace the convergence IC's - P/N STK192-110 with part STK192-150 or 180. Then you can go back in and make the detailed convergence settings and get your picture back in alignement. Also check the flame-resistant resistors around the ICs to make sure that none of them have opened up.
Jan 11, 2009 | Toshiba TN50X81 50" Rear Projection...
The colors are out of alignment causing the screen to appear 3D.
yes you can try.
goto convergence setings
slect menue on your remote
goto Convergence option 4 under (screen)
if this mode is mising you have an open resitor 750k ohm location on main pcb board is R19722
your tv set is also an RCA tpk195, if this helps
ptk195.
you might want to have a TV repairman look at the red blue and green convergence amp's.
hope this helps you.
regards,
daniel.
Jan 11, 2009 | GE 46GW 948 46" Rear Projection Television
RCA HD Projection TV Model HD52W59
you have a fusible link that has blown. This is what causes the convergence option no be erased from the menu. You will need to locate the blown link and replace it. They are identified by FLpreceeding the location number on the circuit board such FL221 and etc.
Mar 23, 2008 | RCA P61927 61" Rear Projection Television
Convergence
The actual process is fairly easy. However, you must open the TV cabinet. You can access the CRTs (there are three) and adjust position and power for each color. This is not recommended and you should call a local repair shop. Find an independent service center and you may find someone to do this for under $120.00
Jan 27, 2008 | RCA D61W130 61" Rear Projection Television
RCA 46" Rear Projection TV-How do you adjust the convergence colors
are you looking to correct the problem or make and adjustment
adjustments you can do from the remote once you in the menu
however if that doesn't fix your problem most likely it need convergence ic's
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | RCA P60921 60" Rear Projection Television
Adjusting convergence
try unplugging and waiting over night and then repluging it in this will reset the computer
Feb 20, 2007 | RCA P52928 52" Rear Projection Television
Televison & Video Logo
99 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
